[STM32F1] 定时器无法再60S后退出中断
550|10
 楼主| liuzaiy 发表于 2022-12-1 20:43 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include"led.h"
#include "sys.h"
#define LED13 PCout(13)
#define LED14 PCout(14)
void delay_ms(u32 i)
   u32 temp;
   SysTick->LOAD=9000*i;      //设置重装数值, 72MHZ时
   SysTick->CTRL=0X01;        //使能,减到零是无动作,采用外部时钟源
   SysTick->VAL=0;            //清零计数器
   do
       temp=SysTick->CTRL;       //读取当前倒计数值
   while((temp&0x01)&&(!(temp&(1<<16))));    //等待时间到达
  SysTick->CTRL=0;    //关闭计数器
  SysTick->VAL=0;        //清空计数器
void LED_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);//使能PB,PE端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14;                                 //LED0-->PB.5 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度为50MHz
GPIO_Init(GPIOC, &GPIO_InitStructure);                                         //根据设定参数初始化GPIOB.5
GPIO_SetBits(GPIOC,GPIO_Pin_14|GPIO_Pin_13);                                                 //PB.5 输出高
void TIM3_Int_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //时钟使能
        //定时器TIM3初始化
        TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中断,允许更新中断
        //中断优先级NVIC设置
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中断
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //从优先级3级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //初始化NVIC寄存器
TIM_Cmd(TIM3, ENABLE);  //使能TIMx
//定时器3中断服务程序
void TIM3_IRQHandler(u8 t)   //TIM3中断
         t=0;
        t++;
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)  //检查TIM3更新中断发生与否
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //清除TIMx更新中断标志
    //   delay_ms(1000);
                        LED13=!LED13;
                if(t==60)
                        TIM_ITConfig(TIM3,TIM_IT_Update,DISABLE);
                                 TIM_Cmd(TIM3, DISABLE);
                        t=0;
                        LED13=1;
int main(void)
  LED_Init();                             //LED端口初始化
        TIM3_Int_Init(9999,7199);//10Khz的计数频率,计数到5000为500ms
  while(1)
          LED14=!LED14;
                delay_ms(1000);
dengdc 发表于 2022-12-1 20:45 | 显示全部楼层
程序跟踪下看看:设个断点,能不能进到这里面:
  if(t==60)
                        t=0;
                        LED13=1;
 楼主| liuzaiy 发表于 2022-12-1 20:48 | 显示全部楼层
谢谢,不行
pengf 发表于 2022-12-1 20:50 | 显示全部楼层
//定时器3中断服务程序
         t=0;
        t++;
这样t能加到60吗?
 楼主| liuzaiy 发表于 2022-12-1 20:52 | 显示全部楼层
这样是一直加,但是if(t==60)不能进入这个语句,LED还是在闪烁
dengdc 发表于 2022-12-1 20:56 | 显示全部楼层
用for嵌套循环计时
stly 发表于 2022-12-1 20:58 | 显示全部楼层
是不是中断向量定义的有问题
dengdc 发表于 2022-12-1 21:00 | 显示全部楼层
代码 有问题
wyjie 发表于 2022-12-1 21:12 | 显示全部楼层
中断函数的意思是:计数器累加到arr值就进一次中断函数,你每次进中断都把t=0了 永远加不到60。
SantaBunny 发表于 2023-2-20 22:29 | 显示全部楼层
定时器时钟只要不关闭就一直运行,但是如果中断服务程序处理过多语句,可能会导致丢失中断
