[MM32软件]
【EV Board (MM32L0136C7P)测评】+彩色LCD屏驱动及图片显示
430|0
EVB-L0130开发板所使用的MM32L0136C7P 多达 64KB Flash 存储器和8KB SRAM,这使其足以支持相应的图片存储及显示。
为此,为它配置了一个彩色的LCD屏来显示字符信息和图片的显示。
LCD屏为0.96寸屏,其分辨率为160*80像素点,它以SPI方式工作,其与开发板的连接关系如下:
CLK---PB9
DIN---PB10
RES--- PB11
DC --- PB5
CS --- PB2
BLK--- VDD
LCD屏的引脚配置初始化函数为:
void APP_Init(void)
    gpio_init.Pins  = GPIO_PIN_9;
    gpio_init.PinMode  = GPIO_PinMode_Out_PushPull;
    gpio_init.Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB, &gpio_init);
    GPIO_PinAFConf(GPIOB, gpio_init.Pins, GPIO_AF_15);
    gpio_init.Pins  = GPIO_PIN_10;
    gpio_init.Pins  = GPIO_PIN_11;
    gpio_init.Pins  = GPIO_PIN_2;
    gpio_init.Pins  = GPIO_PIN_5;
LCD屏的初始化函数为:
void Lcd_Init(void)
  OLED_RST_Clr();
  delay_ms(200);
  OLED_RST_Set();
  delay_ms(200);
  LCD_WR_REG(0x11);
  delay_ms(100);
  LCD_WR_REG(0x21);
  LCD_WR_REG(0xB1);
  LCD_WR_DATA8(0x05);
  LCD_WR_DATA8(0x3A);
  LCD_WR_DATA8(0x3A);
  LCD_WR_REG(0xB2);
  LCD_WR_DATA8(0x05);
  LCD_WR_DATA8(0x3A);
  LCD_WR_DATA8(0x3A);
  LCD_WR_REG(0xB3);
  LCD_WR_DATA8(0x05);
  LCD_WR_DATA8(0x3A);
  LCD_WR_DATA8(0x3A);
  LCD_WR_DATA8(0x05);
  LCD_WR_DATA8(0x3A);
  LCD_WR_DATA8(0x3A);
  LCD_WR_REG(0xB4);
  LCD_WR_DATA8(0x03);
  LCD_WR_REG(0xC0);
  LCD_WR_DATA8(0x62);
  LCD_WR_DATA8(0x02);
  LCD_WR_DATA8(0x04);
  LCD_WR_REG(0xC1);
  LCD_WR_DATA8(0xC0);
  LCD_WR_REG(0xC2);
  LCD_WR_DATA8(0x0D);
  LCD_WR_DATA8(0x00);
  LCD_WR_REG(0xC3);
  LCD_WR_DATA8(0x8D);
  LCD_WR_DATA8(0x6A);
  LCD_WR_REG(0xC4);
  LCD_WR_DATA8(0x8D);
  LCD_WR_DATA8(0xEE);
  LCD_WR_REG(0xC5);
  LCD_WR_DATA8(0x0E);
  LCD_WR_REG(0xE0);
  LCD_WR_DATA8(0x10);
  LCD_WR_DATA8(0x0E);
  LCD_WR_DATA8(0x02);
  LCD_WR_DATA8(0x03);
  LCD_WR_DATA8(0x0E);
  LCD_WR_DATA8(0x07);
  LCD_WR_DATA8(0x02);
  LCD_WR_DATA8(0x07);
  LCD_WR_DATA8(0x0A);
  LCD_WR_DATA8(0x12);
  LCD_WR_DATA8(0x27);
  LCD_WR_DATA8(0x37);
  LCD_WR_DATA8(0x00);
  LCD_WR_DATA8(0x0D);
  LCD_WR_DATA8(0x0E);
  LCD_WR_DATA8(0x10);
  LCD_WR_REG(0xE1);
  LCD_WR_DATA8(0x10);
  LCD_WR_DATA8(0x0E);
  LCD_WR_DATA8(0x03);
  LCD_WR_DATA8(0x03);
  LCD_WR_DATA8(0x0F);
  LCD_WR_DATA8(0x06);
  LCD_WR_DATA8(0x02);
  LCD_WR_DATA8(0x08);
  LCD_WR_DATA8(0x0A);
  LCD_WR_DATA8(0x13);
  LCD_WR_DATA8(0x26);
  LCD_WR_DATA8(0x36);
  LCD_WR_DATA8(0x00);
  LCD_WR_DATA8(0x0D);
  LCD_WR_DATA8(0x0E);
  LCD_WR_DATA8(0x10);
  LCD_WR_REG(0x3A);
  LCD_WR_DATA8(0x05);
  LCD_WR_REG(0x36);
  LCD_WR_DATA8(0x78);
  LCD_WR_REG(0x29);
其以色彩清除屏幕的函数为:
void LCD_Clear(u16 Color)
    u16 i,j;
    LCD_Address_Set(0,0,LCD_W-1,LCD_H-1);
    for(i=0;i<LCD_W;i++)
       for (j=0;j<LCD_H;j++)
          LCD_WR_DATA(Color);
依据清屏函数可获得的图片显示函数为:
void LCD_ShowPictureb(u16 x1,u16 y1,u16 x2,u16 y2)
      int i;
      LCD_Address_Set(x1,y1,x2,y2);
      for(i=0;i<12800;i++)
            LCD_WR_DATA8(gImage_RW[i*2]);
            LCD_WR_DATA8(gImage_RW[i*2+1]);
其字符串的显示函数为:
void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 color)
    while(*p!='\0')
        if(x>LCD_W-16){x=0;y+=16;}
        if(y>LCD_H-16){y=x=0;LCD_Clear(RED);}
        LCD_ShowChar(x,y,*p,0,color);
        x+=8;
        p++;
实现图1和图2所示效果的主程序为:
int main(void)
    BOARD_Init();
    APP_Init();
    Lcd_Init();
    LCD_Clear(YELLOW);
    LCD_ShowPictureb(0,0,159,79);
    del_t(60000);
    BACK_COLOR=RED;
    LCD_Clear(RED);
    LCD_ShowString(20,10,"EVB-L0136",YELLOW);
    LCD_ShowString(20,30,"MM32L0136",YELLOW);
    LCD_ShowString(20,50,"jinglixixi",YELLOW);
    while (1);
1 字符信息显示效果
2  图像显示效果
