[WIFI模块] IPQ6010 QCN9074 QCN9024 high power wifi module support openWRT 802.11ax/Wallys
1647|0
 楼主| lilywallys 发表于 2022-12-7 11:44 | 显示全部楼层 |阅读模式
Today lets talk about a routerboard based on Qualcomm IPQ6010 processor from Wallys and the network card could be use on it DR9074-5G.The board called DR6018.Its routerboard support QUECTEL RM500Q-GL and QCN9074 WiFi 6E Card.
DR6018
Key words for DR6018 for your quick knowledge:IPQ6010,802.11AX,WIFI6E CARD,openWRT
The DR6018 routerboard is the perfect solution for high-performance computing (HPC) applications. This routerboard provides dual-band WiFi and Gigabit Ethernet, as well as USB 3.0 host connectivity, to give you a powerful and versatile platform to build your next HPC system on.
Qualcomm IPQ6010 processor can provide up to 16560DMIPS computing power,plus eight independent signal amplifiers,to achieve 6600MB 160MHz high bandwidth,with powerful performance.The Qualcomm-Atheros IPQ6010 quad-core ARM 64bit A53 @1.8GHz processor provides ample performance for most applications, allowing you to run multiple virtual machines simultaneously without any lag or latency issues. The 1GB DDRL3L system memory provides enough memory for your desktop applications, while the 32MB NOR flash and 256MB NAND flash provide storage space for large datasets that would otherwise take up too much space on the hard drive or RAM.
The DR6018 routerboard supports Dynamic Frequency Selection (DFS), which lets you adjust the CPU frequency according to the workload being performed by each virtual machine. This allows you to optimize power consumption while maintaining high performance levels across all of your virtual machines simultaneously, ensuring that your system will perform at peak efficiency regardless of how many tasks need to be run simultaneously on any one machine in turn!
Click below the link for more information about DR6018
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
DR9074-5G
QCN9074,QCN9024,802.11ax,4x4,MU-MIMO,5GHz,WIFI6,M.2
This card equipped Qualcomm Atheros QCN9074,can provide 5GHz, max 23dBm per chain, up to 4949Mbps,with the interface M.2 E Key and PCI Express 3.0,with 4 spatial streams(4SS),with single band 5GHz 4x4 wifi 6 (802.11ax) functions.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
For more information,visit our website:https://www.wallystech.com/
