| 开始是这样的,在移植eCos时遇到一个编译错误,代码如下 //=========================================================================
 // State switch VSR
 // This is called from the init code to switch execution from the main
 // stack to the process stack. We also take the opportunity to do some
 // other things that are best done in asm code such as disabling interrupts
 // and setting the control register.
 // The adjustment to MSP by 1/2 interrupt stack size allows code to
 // throw exceptions without corrupting the execution stack. This is
 // only necessary for non-kernel configurations (e.g. RedBoot, Stubs)
 // since kernel configurations will switch to a thread stack before
 // they should throw an exception.
 .global hal_switch_state_vsr
 .thumb
 .thumb_func
 .type   hal_switch_state_vsr, %function
 hal_switch_state_vsr:
 mov     r0,#CYGNUM_HAL_CORTEXM_PRIORITY_MAX
 msr     basepri,r0
 mov     r0,#2                   // Set CONTROL register to 2
 msr     control,r0
 isb                             // Insert a barrier
 msr     psp,sp                  // Copy SP to PSP
 #if !defined(CYGPKG_KERNEL)
 sub     sp,#(CYGNUM_HAL_COMMON_INTERRUPTS_STACK_SIZE/2)
 #endif
 orr     lr,#0xD                 // Adjust return link
 bx      lr                      // Return to init code on PSP now
 #endif
