[MM32软件] 【EV Board (MM32L0136C7P)测评】红外遥控器完整作品
1938|14
 楼主| wuxiubo 发表于 2022-12-17 13:59 | 显示全部楼层 |阅读模式
本次开发板提供的丰富外设还未体验完,暂时就把自己体验的几个外设功能给完善了下,然后通过一些外设做了一个遥控器的功能,同时兼具温湿度传感器的显示功能。
13114935c8f322525d99dbd85f23b4ae
最主要的是这个液晶显示,目前是段码屏。所以我们可以显示一些字母还有特殊定制的字符。
  1. void LCD_DisplayDataUpdate(void)
  3. static u32 TemValue1,RhValue1;
  4. t++;
  5. if(t<15)
  6. {
  7. TemValue1 = TemValue*100;
  8. LCD_DisplayNumber1(0, ' ', 0);
  9. LCD_DisplayNumber1(1, ' ', 0);
  10. LCD_DisplayNumber1(2, '0' + ((TemValue1 / 1000) % 10), 0);
  11. LCD_DisplayNumber1(3, '0' + ((TemValue1 / 100 ) % 10), 1);
  12. LCD_DisplayNumber1(4, '0' + ((TemValue1 / 10 ) % 10), 0);
  13. LCD_DisplayNumber1(5, '0' + ((TemValue1 / 1 ) % 10), 0);
  14. LCD_DisplayUnit(4,1);
  15. LCD_DisplayNumber2(0, ' ', 0);
  16. }
  17. else if(t<30)
  18. {
  19. RhValue1 = RhValue*100;
  20. LCD_DisplayNumber1(0, 'H', 0);
  21. LCD_DisplayNumber1(1, ' ', 0);
  22. LCD_DisplayNumber1(2, '0' + ((RhValue1 / 1000) % 10), 0);
  23. LCD_DisplayNumber1(3, '0' + ((RhValue1 / 100 ) % 10), 1);
  24. LCD_DisplayNumber1(4, '0' + ((RhValue1 / 10 ) % 10), 0);
  25. LCD_DisplayNumber1(5, '0' + ((RhValue1 / 1 ) % 10), 0);
  26. LCD_DisplayUnit(4,0);
  27. LCD_DisplayNumber2(0, ' ', 0);
  28. }
  29. else
  30. {
  31. t=0;
  32. }
  33. }
  34. void LCD_Show_Heating_Temp(uint8_t temp)
  35. {
  36. LCD_DisplayNumber1(0, ' ', 0);
  37. LCD_DisplayNumber1(1, 'H', 0);
  38. LCD_DisplayNumber1(2, '-', 0);
  39. LCD_DisplayNumber1(3, '0' + ((temp / 10 ) % 10), 0);
  40. LCD_DisplayNumber1(4, '0' + ((temp / 1 ) % 10), 0);
  41. LCD_DisplayNumber1(5, 'C', 0);
  42. LCD_DisplayUnit(4,0);
  43. }
  44. void LCD_Show_Refrigeration_Temp(uint8_t temp)
  45. {
  46. LCD_DisplayNumber1(0, ' ', 0);
  47. LCD_DisplayNumber1(1, 'C', 0);
  48. LCD_DisplayNumber1(2, '-', 0);
  49. LCD_DisplayNumber1(3, '0' + ((temp / 10 ) % 10), 0);
  50. LCD_DisplayNumber1(4, '0' + ((temp / 1 ) % 10), 0);
  51. LCD_DisplayNumber1(5, 'C', 0);
  52. LCD_DisplayUnit(4,0);
  53. }
  54. void LCD_Show_Wind_Speed(uint8_t Wind_Speed)
  55. {
  56. switch(Wind_Speed)
  57. {
  58. case 0: //自动
  59. {
  60. LCD_DisplayNumber2(0, 'A', 0);
  61. break;
  62. }
  63. case 1: //低速
  64. {
  65. LCD_DisplayNumber2(0, 'L', 0);
  66. break;
  67. }
  68. case 2://中速
  69. {
  70. LCD_DisplayNumber2(0, 'I', 0);
  71. break;
  72. }
  73. case 3://高速
  74. {
  75. LCD_DisplayNumber2(0, 'H', 0);
  76. break;
  77. }
  78. }
  79. }
这里面我用了好几个函数封装了要显示的内容,首先传感器显示数据,保留了两位小数,同时对于其温湿度采用了不同的显示方法,温度由于其段码上有一个字符,所以直接显示字符就行了,湿度我用了最开头一个数码管进行显示H。然后包括后面显示风俗也是一样,用数码管拼凑字母。紧接着的是显示制冷制热模式下的温度。
34d94d581379d788f82dcd5d58c0852c
之后是红外,这个在上篇中说了,产生38Khz方波,然后进行编码。
337f065eab04d43c3f602e25158d7104
按键的话只能用前面三个进行测试,最后的和段码屏冲突了,所以我们未使用,不过我们可以用组合按键方式进行新增功能。
  1. if(KEY1&&!KEY2)
  3. delay_ms(15);
  4. if(KEY1&&!KEY2) //关机
  5. {
  6. AUX_SET_OFF();
  7. mode = 0;
  8. }
  9. }
  10. else if(KEY1) //制热
  11. {
  12. delay_ms(15);
  13. if(KEY1)
  14. {
  15. send_flag = 1;
  16. mode = 1;
  17. }
  18. }
  19. else if(!KEY2&&!KEY3) //显示温湿度
  20. {
  21. delay_ms(15);
  22. if(!KEY2&&!KEY3)
  23. {
  24. mode = 0;
  25. }
  26. }
  27. else if(!KEY2)//制冷
  28. {
  29. delay_ms(15);
  30. if(!KEY2)
  31. {
  32. send_flag = 1;
  33. mode = 2;
  34. }
  35. }
  36. else if(!KEY3)//设置风速
  37. {
  38. delay_ms(15);
  39. if(!KEY3)
  40. {
  41. send_flag = 1;
  42. if(wind_speed==3)//高速到自动
  43. {
  44. AUX_ON[4] = 0xE0;//自动
  45. wind_speed = 0;
  46. }
  47. else if(wind_speed == 0)
  48. {
  49. AUX_ON[4] = 0x60;//低速
  50. wind_speed = 1;
  51. }
  52. else if(wind_speed == 1)
  53. {
  54. AUX_ON[4] = 0x20;//中速
  55. wind_speed = 2;
  56. }
  57. else if(wind_speed == 2)
  58. {
  59. AUX_ON[4] = 0xA0;//高速
  60. wind_speed = 3;
  61. }
  62. mode = 3;
  63. }
  64. }
所以整个功能就做了5个,分别是制冷制热模式切换,风速大小切换,以及显示温湿度传感器数据,关闭空调。
ee45311c2d778e4b019f0324da1fad6e
空调控制还需要进行调温,这个是最主要的功能,调温的话我是采用了上面的滑动变阻器,然后其是接入到了ADC功能里面的,我们把ADC采集数据进行平均,然后就能完成温度调节了。
4477a6a77dda51216223f45137dcb691
我把其采集到的值进行了等分,然后只需要除去这个数即可。
  1. ADCVAL = GetAdcAverage(10);
  2. set_temp = ADCVAL/274;
  3. if(temp_change!=set_temp)
  4. {
  5. temp_change = set_temp;
  6. send_flag = 1;
  7. }
这个是代码,首先是采集滤波,然后就是数值改变下才去调整下空调设定温度。
  1. switch(mode)
  3. case 0:
  4. {
  5. //IRM_SetIRMData(1u);
  6. SHT20_SoftReset();
  7. SHT20_ReadValues();
  8. LCD_DisplayDataUpdate();
  9. break;
  10. }
  11. case 1: //制热
  12. {
  13. if(send_flag)
  14. {
  15. send_flag = 0;
  16. AUX_ON[1] = ((0x40>>3)+(set_temp))<<3|0x07;
  17. AUX_ON[6] = 0x80;
  18. AUX_SET_HOT();
  19. LCD_Show_Heating_Temp(set_temp+16);
  20. LCD_Show_Wind_Speed(wind_speed);
  21. }
  22. break;
  23. }
  24. case 2: //制冷
  25. {
  26. if(send_flag)
  27. {
  28. send_flag = 0;
  29. AUX_ON[1] = ((0x40>>3)+(set_temp))<<3|0x07;
  30. AUX_ON[6] = 0x20;
  31. AUX_SET_HOT();
  32. LCD_Show_Refrigeration_Temp(set_temp+16);
  33. LCD_Show_Wind_Speed(wind_speed);
  34. }
  35. break;
  36. }
  37. case 3:
  38. {
  39. if(send_flag)
  40. {
  41. send_flag = 0;
  42. AUX_ON[1] = ((0x40>>3)+(set_temp))<<3|0x07;
  43. LCD_Show_Wind_Speed(wind_speed);
  44. AUX_SET_HOT();
  45. }
  46. break;
  47. }
  48. }
整体最后在函数里进行不同,模式切换就完成了。
演示效果放视频中了,如下。
xld0932 发表于 2022-12-17 20:02 | 显示全部楼层
对着空调实际操作,一下子感觉到效果了
xu@xupt 发表于 2022-12-19 10:30 | 显示全部楼层
博主强大,感谢分享
szt1993 发表于 2022-12-21 21:03 | 显示全部楼层
楼主这个可以,学习到了
tpgf 发表于 2023-1-5 15:09 | 显示全部楼层
正常情况下  红外遥控器的可靠使用距离是多远啊
xiaoqizi 发表于 2023-1-5 15:25 | 显示全部楼层
一般情况下什么原因会导致红外连接的断开呢
木木guainv 发表于 2023-1-5 15:34 | 显示全部楼层
红外发送的这个波 是可以通过什么手段进行捕捉呢
aoyi 发表于 2023-1-5 15:43 | 显示全部楼层
使用红外连接发送数据的最快速度是多少啊
tfqi 发表于 2023-1-5 15:56 | 显示全部楼层
一个红外遥控器 可以同时控制多个红外设备吗
Jacquetry 发表于 2023-1-5 17:01 | 显示全部楼层
红外连接发送数据的最快速度是多少啊
 楼主| wuxiubo 发表于 2023-1-6 16:59 | 显示全部楼层
这个传感器很小,还是贴片的,所以估计得一米以内,其实做个多的一般是5个灯,像最早小米出的那种万能遥控器,就是这样,这样基本做到一个屋子里设备都能控制了
红外连接发送数据的最快速度是多少啊
这个不是看速度的,看协议,协议规定了,就只能按协议速度走,他的38KHZ只是载波
 楼主| wuxiubo 发表于 2023-1-6 17:00 | 显示全部楼层
可以的,就是你要修改代码了,能做成万能遥控器那种,都需要有对应的红外设备库了
可以用逻辑分析仪看,这个最准确,用手机摄像头只能看他亮了
 楼主| wuxiubo 发表于 2023-1-6 17:01 | 显示全部楼层
他这个目前贴片的红外灯,比较受限制,换自己做的板子就会好点,多组红外发射灯就好了
