嗯,是这样的,生成的代码有这么一句,编译报结构体中没有这个成员
#define LCD_DC_HIGH() WRITE_REG(GPIOA->BRR, GPIO_PIN_6)
结构体定义:
#define GPIOA ((GPIO_TypeDef *) GPIOA_BASE)
typedef struct
__IO uint32_t MODER; /*!< GPIO port mode register, Address offset: 0x00 */
__IO uint32_t OTYPER; /*!< GPIO port output type register, Address offset: 0x04 */
__IO uint32_t OSPEEDR; /*!< GPIO port output speed register, Address offset: 0x08 */
__IO uint32_t PUPDR; /*!< GPIO port pull-up/pull-down register, Address offset: 0x0C */
__IO uint32_t IDR; /*!< GPIO port input data register, Address offset: 0x10 */
__IO uint32_t ODR; /*!< GPIO port output data register, Address offset: 0x14 */
__IO uint32_t BSRR; /*!< GPIO port bit set/reset registerBSRR, Address offset: 0x18 */
__IO uint32_t LCKR; /*!< GPIO port configuration lock register, Address offset: 0x1C */
__IO uint32_t AFR[2]; /*!< GPIO alternate function register, Address offset: 0x20-0x24 */
} GPIO_TypeDef;
所以BRR不是结构体成员,所以报错。。。
嗯,我用stm32时间不长,还不熟悉。。。这个可能是什么原因?有bug?
谢谢~~ |
