[DemoCode下载]
M480通过I2S驱动NAU88L25解码音频
566|1
jiekou001|  楼主 | 2022-12-22 16:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    This is an I2S demo using NAU8822/88L25 audio codec, and used to play
*           back the input from line-in or MIC interface..
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <string.h>
#include "NuMicro.h"
#include "config.h"
#define NAU8822     0
uint32_t PcmBuff[BUFF_LEN] = {0};
uint32_t volatile u32BuffPos = 0;
#if NAU8822
/*  Write 9-bit data to 7-bit address register of NAU8822 with I2C2                                        */
void I2C_WriteNAU8822(uint8_t u8addr, uint16_t u16data)
    I2C_START(I2C2);
    I2C_WAIT_READY(I2C2);
    I2C_SET_DATA(I2C2, 0x1A<<1);
    I2C_SET_CONTROL_REG(I2C2, I2C_CTL_SI);
    I2C_SET_DATA(I2C2, (uint8_t)((u8addr << 1) | (u16data >> 8)));
    I2C_SET_DATA(I2C2, (uint8_t)(u16data & 0x00FF));
    I2C_STOP(I2C2);
/*  NAU8822 Settings with I2C interface        */
void NAU8822_Setup()
    printf("\nConfigure NAU8822 ...");
    I2C_WriteNAU8822(0,  0x000);   /* Reset all registers */
    CLK_SysTickDelay(10000);
    I2C_WriteNAU8822(1,  0x02F);
    I2C_WriteNAU8822(2,  0x1B3);   /* Enable L/R Headphone, ADC Mix/Boost, ADC */
    I2C_WriteNAU8822(3,  0x07F);   /* Enable L/R main mixer, DAC */
    I2C_WriteNAU8822(4,  0x010);   /* 16-bit word length, I2S format, Stereo */
    I2C_WriteNAU8822(5,  0x000);   /* Companding control and loop back mode (all disable) */
    I2C_WriteNAU8822(6,  0x1AD);   /* Divide by 6, 16K */
    I2C_WriteNAU8822(7,  0x006);   /* 16K for internal filter coefficients */
    I2C_WriteNAU8822(10, 0x008);   /* DAC soft mute is disabled, DAC oversampling rate is 128x */
    I2C_WriteNAU8822(14, 0x108);   /* ADC HP filter is disabled, ADC oversampling rate is 128x */
    I2C_WriteNAU8822(15, 0x1EF);   /* ADC left digital volume control */
    I2C_WriteNAU8822(16, 0x1EF);   /* ADC right digital volume control */
    I2C_WriteNAU8822(44, 0x000);   /* LLIN/RLIN is not connected to PGA */
    I2C_WriteNAU8822(47, 0x050);   /* LLIN connected, and its Gain value */
    I2C_WriteNAU8822(48, 0x050);   /* RLIN connected, and its Gain value */
    I2C_WriteNAU8822(50, 0x001);   /* Left DAC connected to LMIX */
    I2C_WriteNAU8822(51, 0x001);   /* Right DAC connected to RMIX */
    printf("[OK]\n");
#else   // NAU88L25
uint8_t I2cWrite_MultiByteforNAU88L25(uint8_t chipadd,uint16_t subaddr, const uint8_t *p,uint32_t len)
    /* Send START */
    I2C_START(I2C2);
    /* Send device address */
    I2C_SET_DATA(I2C2, chipadd);
    /* Send register number and MSB of data */
    I2C_SET_DATA(I2C2, (uint8_t)(subaddr>>8));
    I2C_SET_DATA(I2C2, (uint8_t)(subaddr));
    /* Send data */
    I2C_SET_DATA(I2C2, p[0]);
    /* Send data */
    I2C_SET_DATA(I2C2, p[1]);
    /* Send STOP */
    I2C_STOP(I2C2);
    return  0;
uint8_t I2C_WriteNAU88L25(uint16_t addr,uint16_t dat)
    uint8_t Tx_Data0[2];
    Tx_Data0[0] = (uint8_t)(dat >> 8);
    Tx_Data0[1] = (uint8_t)(dat & 0x00FF);
    return ( I2cWrite_MultiByteforNAU88L25(0x1A << 1,addr,&Tx_Data0[0],2) );
void NAU88L25_Reset(void)
    I2C_WriteNAU88L25(0,  0x1);
    I2C_WriteNAU88L25(0,  0);   // Reset all registers
    printf("NAU88L25 Software Reset.\n");
void NAU88L25_Setup(void)
    I2C_WriteNAU88L25(0x0003,  0x8053);
    I2C_WriteNAU88L25(0x0004,  0x0001);
    I2C_WriteNAU88L25(0x0005,  0x3126);
    I2C_WriteNAU88L25(0x0006,  0x0008);
    I2C_WriteNAU88L25(0x0007,  0x0010);
    I2C_WriteNAU88L25(0x0008,  0xC000);
    I2C_WriteNAU88L25(0x0009,  0x6000);
    I2C_WriteNAU88L25(0x000A,  0xF13C);
    I2C_WriteNAU88L25(0x000C,  0x0048);
    I2C_WriteNAU88L25(0x000D,  0x0000);
    I2C_WriteNAU88L25(0x000F,  0x0000);
    I2C_WriteNAU88L25(0x0010,  0x0000);
    I2C_WriteNAU88L25(0x0011,  0x0000);
    I2C_WriteNAU88L25(0x0012,  0xFFFF);
    I2C_WriteNAU88L25(0x0013,  0x0015);
    I2C_WriteNAU88L25(0x0014,  0x0110);
    I2C_WriteNAU88L25(0x0015,  0x0000);
    I2C_WriteNAU88L25(0x0016,  0x0000);
    I2C_WriteNAU88L25(0x0017,  0x0000);
    I2C_WriteNAU88L25(0x0018,  0x0000);
    I2C_WriteNAU88L25(0x0019,  0x0000);
    I2C_WriteNAU88L25(0x001A,  0x0000);
    I2C_WriteNAU88L25(0x001B,  0x0000);
    I2C_WriteNAU88L25(0x001C,  0x0002);
    I2C_WriteNAU88L25(0x001D,  0x301a);   //301A:Master, BCLK_DIV=12.288M/8=1.536M, LRC_DIV=1.536M/32=48K
    I2C_WriteNAU88L25(0x001E,  0x0000);
    I2C_WriteNAU88L25(0x001F,  0x0000);
    I2C_WriteNAU88L25(0x0020,  0x0000);
    I2C_WriteNAU88L25(0x0021,  0x0000);
    I2C_WriteNAU88L25(0x0022,  0x0000);
    I2C_WriteNAU88L25(0x0023,  0x0000);
    I2C_WriteNAU88L25(0x0024,  0x0000);
    I2C_WriteNAU88L25(0x0025,  0x0000);
    I2C_WriteNAU88L25(0x0026,  0x0000);
    I2C_WriteNAU88L25(0x0027,  0x0000);
    I2C_WriteNAU88L25(0x0028,  0x0000);
    I2C_WriteNAU88L25(0x0029,  0x0000);
    I2C_WriteNAU88L25(0x002A,  0x0000);
    I2C_WriteNAU88L25(0x002B,  0x0012);
    I2C_WriteNAU88L25(0x002C,  0x0082);
    I2C_WriteNAU88L25(0x002D,  0x0000);
    I2C_WriteNAU88L25(0x0030,  0x00CF);
    I2C_WriteNAU88L25(0x0031,  0x0000);
    I2C_WriteNAU88L25(0x0032,  0x0000);
    I2C_WriteNAU88L25(0x0033,  0x009E);
    I2C_WriteNAU88L25(0x0034,  0x029E);
    I2C_WriteNAU88L25(0x0038,  0x1486);
    I2C_WriteNAU88L25(0x0039,  0x0F12);
    I2C_WriteNAU88L25(0x003A,  0x25FF);
    I2C_WriteNAU88L25(0x003B,  0x3457);
    I2C_WriteNAU88L25(0x0045,  0x1486);
    I2C_WriteNAU88L25(0x0046,  0x0F12);
    I2C_WriteNAU88L25(0x0047,  0x25F9);
    I2C_WriteNAU88L25(0x0048,  0x3457);
    I2C_WriteNAU88L25(0x004C,  0x0000);
    I2C_WriteNAU88L25(0x004D,  0x0000);
    I2C_WriteNAU88L25(0x004E,  0x0000);
    I2C_WriteNAU88L25(0x0050,  0x2007);
    I2C_WriteNAU88L25(0x0051,  0x0000);
    I2C_WriteNAU88L25(0x0053,  0xC201);
    I2C_WriteNAU88L25(0x0054,  0x0C95);
    I2C_WriteNAU88L25(0x0055,  0x0000);
    I2C_WriteNAU88L25(0x0058,  0x1A14);
    I2C_WriteNAU88L25(0x0059,  0x00FF);
    I2C_WriteNAU88L25(0x0066,  0x0060);
    I2C_WriteNAU88L25(0x0068,  0xC300);
    I2C_WriteNAU88L25(0x0069,  0x0000);
    I2C_WriteNAU88L25(0x006A,  0x0083);
    I2C_WriteNAU88L25(0x0071,  0x0011);
    I2C_WriteNAU88L25(0x0072,  0x0260);
    I2C_WriteNAU88L25(0x0073,  0x332C);
    I2C_WriteNAU88L25(0x0074,  0x4502);
    I2C_WriteNAU88L25(0x0076,  0x3140);
    I2C_WriteNAU88L25(0x0077,  0x0000);
    I2C_WriteNAU88L25(0x007F,  0x553F);
    I2C_WriteNAU88L25(0x0080,  0x0420);
    I2C_WriteNAU88L25(0x0001,  0x07D4);
    printf("NAU88L25 Configured done.\n");
#endif
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    /* Enable External XTAL (4~24 MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Switch HCLK clock source to HXT */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(FREQ_192MHZ);
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable I2S0 module clock */
    CLK_EnableModuleClock(I2S0_MODULE);
    /* Enable I2C2 module clock */
    CLK_EnableModuleClock(I2C2_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
    SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    SYS->GPF_MFPL = (SYS->GPF_MFPL & ~(SYS_GPF_MFPL_PF6MFP_Msk|SYS_GPF_MFPL_PF7MFP_Msk)) |
                    (SYS_GPF_MFPL_PF6MFP_I2S0_LRCK|SYS_GPF_MFPL_PF7MFP_I2S0_DO);
    SYS->GPF_MFPH = (SYS->GPF_MFPH & ~(SYS_GPF_MFPH_PF8MFP_Msk|SYS_GPF_MFPH_PF9MFP_Msk|SYS_GPF_MFPH_PF10MFP_Msk)) |
                    (SYS_GPF_MFPH_PF8MFP_I2S0_DI|SYS_GPF_MFPH_PF9MFP_I2S0_MCLK|SYS_GPF_MFPH_PF10MFP_I2S0_BCLK );
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_I2C2_SDA | SYS_GPD_MFPL_PD1MFP_I2C2_SCL);
    PF->SMTEN |= GPIO_SMTEN_SMTEN10_Msk;
    PD->SMTEN |= GPIO_SMTEN_SMTEN1_Msk;
void I2C2_Init(void)
    /* Open I2C2 and set clock to 100k */
    I2C_Open(I2C2, 100000);
    /* Get I2C2 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C2));
int32_t main (void)
    uint32_t u32startFlag = 1;
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("+------------------------------------------------------------------------+\n");
    printf("|                   I2S Driver Sample Code with WAU88L25                 |\n");
    printf("  NOTE: This sample code needs to work with WAU88L25.\n");
    /* Init I2C2 to access Codec */
    I2C2_Init();
    // Plug-In DET
    SYS->GPA_MFPL = (SYS->GPA_MFPL & ~(SYS_GPA_MFPL_PA4MFP_Msk));
    GPIO_SetMode(PA, BIT4, GPIO_MODE_OUTPUT);
    PA4 = 1;
#if (!NAU8822)
    /* Reset NAU88L25 codec */
    NAU88L25_Reset();
#endif
    /* Open I2S0 interface and set to slave mode, stereo channel, I2S format */
    I2S_Open(I2S0, I2S_MODE_SLAVE, 16000, I2S_DATABIT_16, I2S_DISABLE_MONO, I2S_FORMAT_I2S);
    NVIC_EnableIRQ(I2S0_IRQn);
    /* Set PE.13 low to enable phone jack on NuMaker board. */
    SYS->GPE_MFPH &= ~(SYS_GPE_MFPH_PE13MFP_Msk);
    GPIO_SetMode(PE, BIT13, GPIO_MODE_OUTPUT);
    PE13 = 0;
    // select source from HXT(12MHz)
    CLK_SetModuleClock(I2S0_MODULE, CLK_CLKSEL3_I2S0SEL_HXT, 0);
    /* Set MCLK and enable MCLK */
    I2S_EnableMCLK(I2S0, 12000000);
#if NAU8822
    /* Initialize NAU8822 codec */
    NAU8822_Setup();
#else
    I2S0->CTL0 |= I2S_CTL0_ORDER_Msk;
    /* Initialize NAU88L25 codec */
    CLK_SysTickDelay(20000);
    NAU88L25_Setup();
#endif
    /* Enable Rx threshold level interrupt */
    I2S_EnableInt(I2S0, I2S_IEN_RXTHIEN_Msk);
    /* Enable I2S Rx function to receive data */
    I2S_ENABLE_RX(I2S0);
    while(1)
        if (u32startFlag)
            /* Enable I2S Tx function to send data when data in the buffer is more than half of buffer size */
            if (u32BuffPos >= BUFF_LEN/2)
                I2S_EnableInt(I2S0, I2S_IEN_TXTHIEN_Msk);
                I2S_ENABLE_TX(I2S0);
                u32startFlag = 0;
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
小明的同学| | 2022-12-22 19:55 | 只看该作者
是不是一般的单片机也可以控制这个芯片
