[DemoCode下载]
CRC校验使用方法
330|1
xinxianshi|  楼主 | 2022-12-24 17:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 15/07/02 11:18a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Perform CRC-8 operation and get the CRC checksum result.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <string.h>
#include "NUC123.h"
#define HCLK_CLOCK           72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
    SYS->GPF_MFP &= ~(SYS_GPF_MFP_PF0_Msk | SYS_GPF_MFP_PF1_Msk);
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external 12 MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    while(!CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(PDMA_MODULE); /* For CRC channel opearte */
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD, TXD and TM1 */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk | SYS_GPB_MFP_PB9_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD | SYS_GPB_MFP_PB9_TM1;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    const uint8_t acCRCSrcPattern[] = "123456789";
    uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
    uint8_t *p8SrcAddr;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+---------------------------------+\n");
    printf("|    CRC CRC-8 Mode Sample Code   |\n");
    printf("+---------------------------------+\n\n");
    printf("# Calculate string \"123456789\" CRC-8 checksum value by CRC CPU mode.\n");
    printf("    - Seed value is 0x5A            \n");
    printf("    - CPU Write Length is 8-bit     \n");
    printf("    - Checksum Complement disable   \n");
    printf("    - Checksum Reverse disable      \n");
    printf("    - Write Data Complement disable \n");
    printf("    - Write Data Reverse disable    \n");
    printf("    - Checksum should be 0x%X       \n\n", u32TargetChecksum);
    /* Set CRC source buffer address for CRC-8 CPU mode */
    p8SrcAddr = (uint8_t *)acCRCSrcPattern;
    /* Configure CRC operation settings for CRC-8 CPU mode */
    CRC_Open(CRC_8, 0, 0x5A, CRC_CPU_WDATA_8);
    /* Start to execute CRC-8 CPU operation */
    for(i = 0; i < strlen((char *)acCRCSrcPattern); i++)
        CRC_WRITE_DATA((p8SrcAddr[i] & 0xFF));
    /* Get CRC-8 checksum value */
    u32CalChecksum = CRC_GetChecksum();
    printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
    /* Disable CRC function */
    CRC->CTL &= ~CRC_CTL_CRCCEN_Msk;
    while(1);
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
小夏天的大西瓜| | 2022-12-24 20:39 | 只看该作者
楼主这个校验直接用的自带的CRC函数嘛?一般我们都是自己编写和校验
