[51单片机] 蓝桥杯单片机学习感悟【02-蜂鸣器与继电器的基本应用】
1834|0
 楼主| 华罗聪 发表于 2023-1-4 23:00 | 显示全部楼层 |阅读模式
那&符号是表示与的意思, &只有1&1的时候才是1,其他都是0,而 | 则相反,只有0 | 0的时候才是0
电路图
ULN2003达林顿管——输入和输出是相反的
代码呈现:
#include "reg52.h"
sbit HC138_A=P2^5;
sbit HC138_B=P2^6;
sbit HC138_C=P2^7;
void Delay(unsigned int t)
        while(t--);
        while(t--);
void HC138(unsigned char n)
        switch(n)
                case 4:            //P2=(P2&0xlf)|0x80;
                        HC138_C=1;
                        HC138_B=0;
                        HC138_A=0;
                break;
                case 5:            //P2=(P2&0xlf)|0xa0;
                        HC138_C=1;
                        HC138_B=0;
                        HC138_A=1;
                break;
                case 6:            //P2=(P2&0xlf)|0xc0;
                        HC138_C=1;
                        HC138_B=1;
                        HC138_A=0;
                break;
                case 7:            //P2=(P2&0xlf)|0xe0;
                        HC138_C=1;
                        HC138_B=1;
                        HC138_A=1;
                break;
void abcdef(unsigned char channel,unsigned char dat)
        HC138(channel);
        P0=dat;
void LEDRunning()
        unsigned char i;
        for(i=0;i<3;i++)
                abcdef(4,0x00);
                Delay(60000);
                Delay(60000);
                abcdef(4,0xff);
                Delay(60000);
                Delay(60000);
        for(i=1;i<=8;i++)
                P0=0xff<<i;
                Delay(60000);
                Delay(60000);
        abcdef(5,0x10);
        Delay(60000);
        Delay(60000);
        abcdef(5,0x00);
        for(i=1;i<=8;i++)
                abcdef(4,~(0xff<<i));
                Delay(60000);
                Delay(60000);
        abcdef(5,0x40);
        Delay(60000);
        Delay(60000);
  abcdef(5,0x00);
        Delay(60000);
        Delay(60000);
void InitSystem()
        abcdef(5,0x00);
void main()
        InitSystem();
        while(1)
                LEDRunning();
