[应用相关] stm32cube中文教程: 用printf代替uart执行串口发送程序
430|0
 楼主| 麻花油条 发表于 2023-1-12 10:49 | 显示全部楼层 |阅读模式
stm32cube生成的驱动代码用printf发送uart的方法
md,每次发都会自动减去好多#**,这个论坛程序不行啊。
#include "stdio.h"
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif / __GNUC__ /
PUTCHAR_PROTOTYPE
HAL_UART_Transmit(&huart1 , (uint8_t *)&ch, 1, 0xFFFF);
return ch;
上面的是完整的,
下面的是以前写的
在头部添加代码
#include "stdio.h"#ifdef __GNUC__  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf     set to 'Yes') calls __io_putchar() */  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)#else  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)#endif / __GNUC__ //**  * @brief  Retargets the C library printf function to the USART.  * @param  None  * @retval None  */PUTCHAR_PROTOTYPE{  / Place your implementation of fputc here /  / e.g. write a character to the EVAL_COM1 and Loop until the end of transmission /  HAL_UART_Transmit(&huart3 , (uint8_t *)&ch, 1, 0xFFFF);   return ch;}
完整的代码例子如下:
#include "stm32f4xx_hal.h"#include "stdio.h"/ Private variables ---------------------------------------------------------/UART_HandleTypeDef huart3;#define BUFFER_SIZE         0x0009//1024uint8_t TxBuffer[BUFFER_SIZE], RxBuffer[BUFFER_SIZE];#ifdef __GNUC__  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf     set to 'Yes') calls __io_putchar() */  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)#else  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)#endif / __GNUC__ // USER CODE BEGIN 0 /void Fill_Buffer(uint8_t *pBuffer, uint16_t BufferLenght, uint32_t Offset);/ USER CODE END 0 // Private function prototypes -----------------------------------------------/static void SystemClock_Config(void);static void MX_GPIO_Init(void);static void MX_USART3_UART_Init(void);int main(void){  / USER CODE BEGIN 1 / uint8_t  message[]="hello world.";  / USER CODE END 1 /  / MCU Configuration----------------------------------------------------------/  / Reset of all peripherals, Initializes the Flash interface and the Systick. /  HAL_Init();  / Configure the system clock /  SystemClock_Config();  / Initialize all configured peripherals /  MX_GPIO_Init();  MX_USART3_UART_Init();  / USER CODE BEGIN 2 /  / USER CODE END 2 /        Fill_Buffer (TxBuffer ,BUFFER_SIZE ,0x40);//    HAL_UART_Transmit_IT(&huart3 ,(uint8_t *)message,sizeof (message));          / Output a message on Hyperterminal using printf function /  //printf("\n\r UART Printf Example: retarget the C library printf function to the UART\n\r");for(uint8_t i=0;i<BUFFER_SIZE ;i++){    printf ("%d \n\r",TxBuffer  );}      / USER CODE BEGIN 3 /  / Infinite loop /  while (1)  {  }  / USER CODE END 3 /}/** System Clock Configuration*/static void SystemClock_Config(void){  RCC_ClkInitTypeDef RCC_ClkInitStruct;  RCC_OscInitTypeDef RCC_OscInitStruct;  __PWR_CLK_ENABLE();  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;  RCC_OscInitStruct.HSEState = RCC_HSE_ON;  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;  RCC_OscInitStruct.PLL.PLLM = 25;  RCC_OscInitStruct.PLL.PLLN = 336;  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;  RCC_OscInitStruct.PLL.PLLQ = 4;  HAL_RCC_OscConfig(&RCC_OscInitStruct);  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1                              |RCC_CLOCKTYPE_PCLK2;  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);}/ USART3 init function /void MX_USART3_UART_Init(void){  huart3.Instance = USART3;  huart3.Init.BaudRate = 9600;  huart3.Init.WordLength = UART_WORDLENGTH_8B;  huart3.Init.StopBits = UART_STOPBITS_1;  huart3.Init.Parity = UART_PARITY_NONE;  huart3.Init.Mode = UART_MODE_TX_RX;  huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;  huart3.Init.OverSampling = UART_OVERSAMPLING_16;  HAL_UART_Init(&huart3);}/** Configure pins as         * Analog         * Input         * Output        * EVENT_OUT        * EXTI*/void MX_GPIO_Init(void){  / GPIO Ports Clock Enable /  __GPIOH_CLK_ENABLE();  __GPIOC_CLK_ENABLE();}/ USER CODE BEGIN 4 //**  *   Function name : Fill_Buffer  * @brief  Fill the buffer  * @param  pBuffer: pointer on the Buffer to fill  * @param  BufferSize: size of the buffer to fill  * @param  Offset: first value to fill on the Buffer  */void Fill_Buffer(uint8_t *pBuffer, uint16_t BufferLenght, uint32_t Offset){  uint16_t IndexTmp = 0;  / Put in global buffer same values /  for (IndexTmp = 0; IndexTmp < BufferLenght; IndexTmp++ )  {    pBuffer[IndexTmp] = IndexTmp + Offset;  }}/**  * @brief  Retargets the C library printf function to the USART.  * @param  None  * @retval None  */PUTCHAR_PROTOTYPE{  / Place your implementation of fputc here /  / e.g. write a character to the EVAL_COM1 and Loop until the end of transmission /  HAL_UART_Transmit(&huart3 , (uint8_t *)&ch, 1, 0xFFFF);   return ch;}/ USER CODE END 4 /#ifdef USE_FULL_ASSERT/**   * @brief Reports the name of the source file and the source line number   * where the assert_param error has occurred.   * @param file: pointer to the source file name   * @param line: assert_param error line source number   * @retval None   */void assert_failed(uint8_t* file, uint32_t line){  /* User can add his own implementation to report the file name and line number,    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */}#endif
