[STM32G0]
CodeMark跑分测试STM32G070
293|1
elephant00|  楼主 | 2023-1-16 09:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
系统时钟配置64M,MDK优化选择了 -O3 -Otime,跑分结果是102,百度官方是142,差挺多,不知道是不是哪里没弄对,求指点。
工程使用 Projects\NUCLEO-G070RB\Examples_LL\USART\USART_Communication_Tx_Init
栈设置4K
Stack_Size      EQU     0x00001000
以下是一些函数接口代码
  • void SystemClock_Config(void)
  •   LL_FLASH_SetLatency(LL_FLASH_LATENCY_2);
  •   /* HSI configuration and activation */
  •   LL_RCC_HSI_Enable();
  •   while(LL_RCC_HSI_IsReady() != 1)
  •   /* Main PLL configuration and activation */
  •   LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSI, LL_RCC_PLLM_DIV_4, 80, LL_RCC_PLLR_DIV_5);
  •   LL_RCC_PLL_Enable();
  •   LL_RCC_PLL_EnableDomain_SYS();
  •   while(LL_RCC_PLL_IsReady() != 1)
  •   /* Set AHB prescaler*/
  •   LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  •   /* Sysclk activation on the main PLL */
  •   LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  •   while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  •   /* Set APB1 prescaler*/
  •   LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  • //  LL_Init1msTick(56000000);
  •   /* Update CMSIS variable (which can be updated also through SystemCoreClockUpdate function) */
  •   LL_SetSystemCoreClock(64000000);
  •         NVIC_SetPriority(SysTick_IRQn, 0);
  •   NVIC_EnableIRQ(SysTick_IRQn);
复制代码
  • void start_time(void)
  •     //GETMYTIME(&start_time_val);
  •         Tick = 0;   //每次初始化时让tick数从0开始
  •         start_time_val = Tick;  //当前tick数保存到全局变量start_time_val
  •         SysTick_Config(SystemCoreClock/1000); //配置并启动SysTick,这里配置Systick每隔1ms中断一次
复制代码
  • void stop_time(void)
  •    // GETMYTIME(&stop_time_val);
  •         SysTick->CTRL = 0; //停止SysTick
  •         stop_time_val = Tick; //当前tick数保存到全局变量stop_time_val
复制代码
  • void SysTick_Handler(void)
  •   Tick++;
复制代码
  • volatile ee_s32 seed4_volatile = 2000;
复制代码
天天向善| | 2023-1-17 14:34 | 只看该作者
说不定官方超频了,你没超。
