[其他]
基于官方库函数的点灯操作
770|2
zhuotuzi|  楼主 | 2023-1-30 20:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* Copyright (C) 2020, Huada Semiconductor Co., Ltd. All rights reserved.
* This software component is licensed by HDSC under BSD 3-Clause license
* (the "License"); You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
*                    opensource.org/licenses/BSD-3-Clause
/** \file main.c
** \brief This sample demonstrates how to set GPIO as output function.
**   - 2021-04-16 CDT first version for Device Driver Library of GPIO.
* Include files
#include "hc32_ddl.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
/* LED0 Port/Pin definition */
#define  LED0_PORT        (PortD)
#define  LED0_PIN         (Pin03)
/* LED1 Port/Pin definition */
#define  LED1_PORT        (PortD)
#define  LED1_PIN         (Pin04)
/* LED2 Port/Pin definition */
#define  LED2_PORT        (PortD)
#define  LED2_PIN         (Pin05)
/* LED3 Port/Pin definition */
#define  LED3_PORT        (PortD)
#define  LED3_PIN         (Pin06)
/* LED0~3 toggle definition */
#define  LED0_TOGGLE()    (PORT_Toggle(LED0_PORT, LED0_PIN))
#define  LED1_TOGGLE()    (PORT_Toggle(LED1_PORT, LED1_PIN))
#define  LED2_TOGGLE()    (PORT_Toggle(LED2_PORT, LED2_PIN))
#define  LED3_TOGGLE()    (PORT_Toggle(LED3_PORT, LED3_PIN))
#define  DLY_MS           (100ul)
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
** \brief  Main function of GPIO output
** \param  None
** \retval int32_t Return value, if needed
int32_t main(void)
    stc_port_init_t stcPortInit;
    /* configuration structure initialization */
    MEM_ZERO_STRUCT(stcPortInit);
    stcPortInit.enPinMode = Pin_Mode_Out;
    stcPortInit.enExInt = Enable;
    stcPortInit.enPullUp = Enable;
    /* LED0 Port/Pin initialization */
    PORT_Init(LED0_PORT, LED0_PIN, &stcPortInit);
    /* LED1 Port/Pin initialization */
    PORT_Init(LED1_PORT, LED1_PIN, &stcPortInit);
    /* LED2 Port/Pin initialization */
    PORT_Init(LED2_PORT, LED2_PIN, &stcPortInit);
    /* LED3 Port/Pin initialization */
    PORT_Init(LED3_PORT, LED3_PIN, &stcPortInit);
    while(1)
        LED0_TOGGLE();
        Ddl_Delay1ms(DLY_MS);
        LED1_TOGGLE();
        LED2_TOGGLE();
        LED3_TOGGLE();
        /* de-init if necessary */
        //PORT_DeInit();
* EOF (not truncated)
官方代码命名的风格挺好的,符合我的习惯。
xinpian101| | 2023-1-30 21:01 | 只看该作者
参数传递方法是跟ST很像,应该就是仿照ST的做的。
