[PCB] Wallys\\wifi5 routerboard/802.11ac IPQ4019/IPQ4029 2x2 2.4Ghz&5G support MT7915/QCA9880 mini pcie moudle
522|0
 楼主| wirelesswifi6 发表于 2023-2-9 14:20 | 显示全部楼层 |阅读模式
hz, ip, TE, 4G, AC
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Max Power
48.1V x 0.180A= 8.658W
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB~512MB
Radio TXSpecifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11a
6 Mbps
27dBm
30dbm
±2dB
54 Mbps
23dBm
26dbm
±2dB
802.11n HT20
MCS0, MCS8
26dBm
29dbm
±2dB
MCS7, MCS15
22dBm
25dbm
±2dB
802.11n HT40
MCS0, MCS8
25dBm
28dbm
±2dB
MCS7, MCS15
21dBm
24dbm
±2dB
802.11ac
MCS0, MCS10,MCS20
25dBm
28dbm
±2dB
MCS9,MCS19,MCS29
19dBm
22dbm
±2dB
Radio RXSpecifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Sensitivity
802.11a
6 Mbps
-96dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-93dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
802.11AC HT40
MCS0, MCS10,MCS20
-90dBm
MCS9,MCS19,MCS29
-67dBm
802.11AC HT80
MCS0, MCS10,MCS20
-88dBm
MCS9,MCS19,MCS29
-62dBm
Radio TXSpecifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11g
6 Mbps
27dbm
30dbm
±2dB
54 Mbps
25dbm
28dbm
±2dB
802.11n HT20
MCS0, MCS8
26dbm
29dbm
±2dB
MCS7, MCS15
25dbm
28dbm
±2dB
802.11n HT40
MCS0, MCS8
26dbm
29dbm
±2dB
MCS7, MCS15
24dbm
27dbm
±2dB
Radio RXSpecifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Sensitivity
802.11g
6 Mbps
-96dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-93dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
Interface MAP
Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
