[活动专区]
【AT-START-WB415测评】跑一下USB HID例程
1303|12
USB HID是USB的应用之一,它的好处是不用驱动程序就可以同上位机通讯。
我打开了USB HID鼠标的那个例程,看了一下,USB总是同中断相联系的要不然处理不了那么烦索的协议。
而关于USB0先启动然后转到USB1口的过程在应用笔记中已经写得很明确了。我想要说的是如果用到mouse例程在例程基础之上改一下,这样就达到了应用的目地。
mouse例程通过一些回调函数来实现HID的,
static usb_sts_type class_init_handler(void *udev);
static usb_sts_type class_clear_handler(void *udev);
static usb_sts_type class_setup_handler(void *udev, usb_setup_type *setup);
static usb_sts_type class_ept0_tx_handler(void *udev);
static usb_sts_type class_ept0_rx_handler(void *udev);
static usb_sts_type class_in_handler(void *udev, uint8_t ept_num);
static usb_sts_type class_out_handler(void *udev, uint8_t ept_num);
static usb_sts_type class_sof_handler(void *udev);
static usb_sts_type class_event_handler(void *udev, usbd_event_type event);
而处理事件的集中在这里:
void usb_hid_mouse_send(void *udev, uint8_t op)
  usbd_core_type *pudev = (usbd_core_type *)udev;
  mouse_type *pmouse = (mouse_type *)pudev->class_handler->pdata;
  int8_t posx = 0, posy = 0, button = 0;
  switch(op)
    case LEFT_BUTTON:
      button = 0x01;
      break;
    case RIGHT_BUTTON:
      button = 0x2;
      break;
    case UP_MOVE:
      posy -= MOVE_STEP;
      break;
    case DOWN_MOVE:
      posy += MOVE_STEP;
      break;
    case LEFT_MOVE:
      posx -= MOVE_STEP;
      break;
    case RIGHT_MOVE:
      posx += MOVE_STEP;
      break;
    default:
      break;
  pmouse->mouse_buffer[0] = button;
  pmouse->mouse_buffer[1] = posx;
  pmouse->mouse_buffer[2] = posy;
  usb_mouse_class_send_report(udev, pmouse->mouse_buffer, 4);
程序下载到开发板也只在USER键好用,相当于确认键。
上位机软件可以识别HID-Mouse
接着又跑一下custom_hid,用镊子直接短PB7,PB8,PB9,则上位机软件有指示,这时按下按键按键灯亮。
而键值处理是在:
static void usb_hid_buf_process(void *udev, uint8_t *report, uint16_t len)
  uint32_t i_index;
  custom_hid_type *pcshid = (custom_hid_type *)pudev->class_handler->pdata;
  switch(report[0])
    case HID_REPORT_ID_2:
      if(pcshid->g_rxhid_buff[1] == 0)
        at32_led_off(LED2);
      else
        at32_led_on(LED2);
      break;
    case HID_REPORT_ID_3:
        at32_led_off(LED3);
      else
        at32_led_on(LED3);
      break;
    case HID_REPORT_ID_4:
        at32_led_off(LED4);
      else
        at32_led_on(LED4);
      break;
    case HID_REPORT_ID_6:
      for(i_index = 0; i_index < len; i_index ++)
        pcshid->g_txhid_buff[i_index] = report[i_index];
      usbd_ept_send(pudev, USBD_CUSTOM_HID_IN_EPT, pcshid->g_txhid_buff, len);
      break;
    default:
      break;
运行结果如下:
kevensz| | 2023-2-14 16:25 | 只看该作者
上位机软件,还有调试的代码可否分享,多谢!
muyichuan2012| | 2023-2-14 19:39 | 只看该作者
雅特力官网可以下载 :https://www.arterytek.com/cn/product/AT32F437.jsp
ddllxxrr|  楼主 | 2023-2-15 12:59 | 只看该作者
才看到,楼上正解
macpherson| | 2023-6-6 12:47 | 只看该作者
可以通过USB HID升级程序吗
ArterySW| | 2023-6-6 13:15 | 只看该作者
可以的
yeates333| | 2023-6-6 14:05 | 只看该作者
usb hid 需要开哪些中断
beacherblack| | 2023-6-6 15:02 | 只看该作者
如何定义AT32 USB HID设备缓冲区地址?
uiint| | 2023-6-6 15:20 | 只看该作者
如何使用AT32 2的USB非控制端点发送多个数据包
beacherblack| | 2023-6-6 17:12 | 只看该作者
usb-hid开发 上位机必须装驱动吗
iyoum| | 2023-6-6 17:51 | 只看该作者
怎么获取usb设备hid描述符
jtracy3| | 2023-6-6 18:11 | 只看该作者
如何使用AT32 的USB库支持延迟HID的GET
ccook11| | 2023-6-8 14:17 | 只看该作者
usb hid通信速度太慢是什么原因
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2400
