[DemoCode下载]
M031的串口自动波特率使用方法
811|26
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 5 $
* $Date: 18/07/16 10:28a $
* @brief
*           Show how to use auto baud rate detection function.
*           This sample code needs to work with UART_AutoBaudRate_Slave.
* @note
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define PLLCTL_SETTING  CLK_PLLCTL_96MHz_HXT
#define PLL_CLOCK       96000000
/* Define functions prototype        */
extern char GetChar(void);
void AutoBaudRate_TestItem(void);
void AutoBaudRate_TxTest(void);
void AutoBaudRate_RxTest(void);
uint32_t GetUartBaudrate(UART_T *uart);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK->PWRCTL |= CLK_PWRCTL_HIRCEN_Msk;
    /* Wait for HIRC clock ready */
    while(!(CLK->STATUS & CLK_STATUS_HIRCSTB_Msk));
    /* Select HCLK clock source as HIRC and HCLK clock divider as 1 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_HIRC;
    CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_HCLKDIV_Msk)) | CLK_CLKDIV0_HCLK(1);
    /* Set PLL to Power-down mode */
    CLK->PLLCTL |= CLK_PLLCTL_PD_Msk;
    /* Set both PCLK0 and PCLK1 as HCLK */
    CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV1 | CLK_PCLKDIV_APB1DIV_DIV1;
    /* Enable UART module clock */
    CLK->APBCLK0 |= (CLK_APBCLK0_UART0CKEN_Msk | CLK_APBCLK0_UART1CKEN_Msk);
    /* Select UART module clock source as HIRC and UART module clock divider as 1 */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UART0SEL_Msk)) | CLK_CLKSEL1_UART0SEL_HIRC;
    CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_UART0DIV_Msk)) | CLK_CLKDIV0_UART0(1);
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UART1SEL_Msk)) | CLK_CLKSEL1_UART1SEL_HIRC;
    CLK->CLKDIV0 = (CLK->CLKDIV0 & (~CLK_CLKDIV0_UART1DIV_Msk)) | CLK_CLKDIV0_UART1(1);
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |  \
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set PA multi-function pins for UART1 TXD and RXD */
    SYS->GPA_MFPL = (SYS->GPA_MFPL & ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk)) |    \
                    (SYS_GPA_MFPL_PA2MFP_UART1_RXD | SYS_GPA_MFPL_PA3MFP_UART1_TXD);
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS->IPRST1 |=  SYS_IPRST1_UART0RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_UART0RST_Msk;
    /* Configure UART0 and set UART0 baud rate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 115200);
    UART0->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 */
    SYS->IPRST1 |=  SYS_IPRST1_UART1RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_UART1RST_Msk;
    /* Configure UART1 and set UART1 baud rate */
    UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 115200);
    UART1->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/* MAIN function        */
int main(void)
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\nUART Sample Program\n");
    /* UART auto baud rate sample master function */
    AutoBaudRate_TestItem();
    while(1);
/*  Auto Baud Rate Function Test Menu        */
void AutoBaudRate_TestItem()
    uint32_t u32Item;
    printf("\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|     Pin Configure                                         |\n");
    printf("|  ______                                            _____  |\n");
    printf("| |      |                                          |     | |\n");
    printf("| |Master|--UART1_TXD    <=========>     UART1_RXD--|Slave| |\n");
    printf("| |______|                                          |_____| |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|     Auto Baud Rate Function Test                          |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code needs two boards. One is Master and    |\n");
    printf("|    the other is slave.  Master will send input pattern    |\n");
    printf("|    0x1 with different baud rate. It can check if Slave    |\n");
    printf("|    calculates correct baud rate.                          |\n");
    printf("|  Please select Master or Slave test                       |\n");
    printf("|  [0] Master    [1] Slave                                  |\n");
    u32Item = getchar();
    if(u32Item == '0')
        AutoBaudRate_TxTest();
    else
        AutoBaudRate_RxTest();
/*  Auto Baud Rate Function Tx Test        */
void AutoBaudRate_TxTest()
    uint32_t u32Item;
    do
        printf("\n");
        printf("|     Auto Baud Rate Function Test (Master)                 |\n");
        printf("| [1] baud rate 38400 bps                                   |\n");
        printf("| [2] baud rate 57600 bps                                   |\n");
        printf("| [3] baud rate 115200 bps                                  |\n");
        printf("|                                                           |\n");
        printf("| Select baud rate and master will send 0x1 to slave ...    |\n");
        printf("| Quit                                              - [ESC] |\n");
        printf("+-----------------------------------------------------------+\n\n");
        printf("%c\n", u32Item);
        /* Set different baud rate */
        switch(u32Item)
        case '1':
            UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 38400);
            break;
        case '2':
            UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 57600);
            break;
        default:
            break;
        /* Send input pattern 0x1 for auto baud rate detection bit length is 1-bit */
        UART1->DAT = 0x1;
    while(u32Item != 27);
/*  Get UART Baud Rate Function        */
uint32_t GetUartBaudrate(UART_T* uart)
    uint8_t u8UartClkSrcSel=0, u8UartClkDivNum=0;
    uint32_t u32ClkTbl[5] = {__HXT, 0ul, __LXT, __HIRC, 0ul};
    uint32_t u32Baud_Div;
    uint32_t PCLK0Div, PCLK1Div ;
    /* Get UART clock source selection and UART clock divider number */
    switch((uint32_t)uart)
    case UART0_BASE:
        u8UartClkSrcSel = (CLK->CLKSEL1 & CLK_CLKSEL1_UART0SEL_Msk) >> CLK_CLKSEL1_UART0SEL_Pos;
        u8UartClkDivNum = (CLK->CLKDIV0 & CLK_CLKDIV0_UART0DIV_Msk) >> CLK_CLKDIV0_UART0DIV_Pos;
        break;
    case UART1_BASE:
        u8UartClkSrcSel = (CLK->CLKSEL1 & CLK_CLKSEL1_UART1SEL_Msk) >> CLK_CLKSEL1_UART1SEL_Pos;
        u8UartClkDivNum = (CLK->CLKDIV0 & CLK_CLKDIV0_UART1DIV_Msk) >> CLK_CLKDIV0_UART1DIV_Pos;
        break;
    case UART2_BASE:
        u8UartClkSrcSel = (CLK->CLKSEL3 & CLK_CLKSEL3_UART2SEL_Msk) >> CLK_CLKSEL3_UART2SEL_Pos;
        u8UartClkDivNum = (CLK->CLKDIV4 & CLK_CLKDIV4_UART2DIV_Msk) >> CLK_CLKDIV4_UART2DIV_Pos;
        break;
    /* Get PLL clock frequency if UART clock source selection is PLL */
    if(u8UartClkSrcSel == 1)
        u32ClkTbl[u8UartClkSrcSel] = CLK_GetPLLClockFreq();
    /* Get PCLK clock frequency if UART clock source selection is PCLK */
    else if (u8UartClkSrcSel == 4ul)
        SystemCoreClockUpdate();
        if (uart == (UART_T *)UART0 || uart == (UART_T *)UART2)
            PCLK0Div = (CLK->PCLKDIV & CLK_PCLKDIV_APB0DIV_Msk) >> CLK_PCLKDIV_APB0DIV_Pos;
            u32ClkTbl[u8UartClkSrcSel] =  SystemCoreClock / PCLK0Div;
        else if (uart == (UART_T *)UART1)
            PCLK1Div = (CLK->PCLKDIV & CLK_PCLKDIV_APB1DIV_Msk) >> CLK_PCLKDIV_APB1DIV_Pos;
            u32ClkTbl[u8UartClkSrcSel] =  SystemCoreClock /PCLK1Div;
    /* Get UART baud rate divider */
    u32Baud_Div = (uart->BAUD & UART_BAUD_BRD_Msk) >> UART_BAUD_BRD_Pos;
    /* Calculate UART baud rate if baud rate is set in MODE 0 */
    if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE0)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32Baud_Div + 2)) >> 4;
    /* Calculate UART baud rate if baud rate is set in MODE 2 */
    else if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE2)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32Baud_Div + 2));
    /* Calculate UART baud rate if baud rate is set in MODE 1 */
    else if((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_BAUDM1_Msk)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1) / (u32Baud_Div + 2)) / (((uart->BAUD & UART_BAUD_EDIVM1_Msk) >> UART_BAUD_EDIVM1_Pos) + 1);
    /* Unsupported baud rate setting */
    else
        return 0;
/*  Auto Baud Rate Function Rx Test        */
void AutoBaudRate_RxTest()
    /* Enable auto baud rate detect function */
    UART1->ALTCTL |= UART_ALTCTL_ABRDEN_Msk;
    printf("\nreceiving input pattern... ");
    /* Wait until auto baud rate detect finished or time-out */
    while((UART1->ALTCTL & UART_ALTCTL_ABRIF_Msk) == 0);
    if(UART1->FIFOSTS & UART_FIFOSTS_ABRDIF_Msk)
        /* Clear auto baud rate detect finished flag */
        UART1->FIFOSTS = UART_FIFOSTS_ABRDIF_Msk;
        printf("Baud rate is %dbps.\n", GetUartBaudrate(UART1));
    else if(UART1->FIFOSTS & UART_FIFOSTS_ABRDTOIF_Msk)
        /* Clear auto baud rate detect time-out flag */
        UART1->FIFOSTS = UART_FIFOSTS_ABRDTOIF_Msk;
        printf("Time-out!\n");
    printf("\nUART Sample Code End.\n");
/*** (C) COPYRIGHT 2017 Nuvoton Technology Corp. ***/
天灵灵地灵灵|  楼主 | 2023-2-26 19:38 | 只看该作者
* @file     main.c
* @version  V1.00
* @brief    Show how to use auto baud rate detection function.
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2017 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
/* Global variables        */
void SYS_Init(void);
void UART0_Init(void);
void UART1_Init(void);
void AutoBaudRate_Test(void);
void SYS_Init(void)
    SYS_UnlockReg();
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Select IP clock source */
    /* Select UART0 clock source is HIRC and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Select UART1 clock source is HIRC and UART module clock divider as 1*/
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART1SEL_HIRC, CLK_CLKDIV0_UART1(1));
    /* Enable UART0 peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable UART1 peripheral clock */
    CLK_EnableModuleClock(UART1_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SYS_LockReg();
/* Init UART0        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    UART_Open(UART0, 115200);
/* Init UART1        */
    /* Reset UART1 */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int32_t main(void)
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    UART0_Init();
    /* Init UART1 */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    /* UART auto baud rate sample function */
    AutoBaudRate_Test();
    printf("\nUART Sample Program End\n");
    while(1);
/*  Auto Baud Rate Function Test                                                            */
    uint32_t u32Item;
    printf("\n");
    printf("| |Master|--UART1_TXD(PA.3) <====> UART1_RXD(PA.2)--|Slave| |\n");
    printf("|                                                           |\n");
    printf("\n");
    if(u32Item == '0')
    else
    uint32_t u32Item;
    do
        printf("\n");
        printf("|                                                           |\n");
        switch(u32Item)
        case '1':
            break;
        case '2':
            break;
        default:
            break;
        UART_WRITE(UART1, 0x1);
    case UART0_BASE:
        break;
    case UART1_BASE:
        break;
    case UART2_BASE:
        break;
    if (u8UartClkSrcSel == 1ul)
            u32ClkTbl[u8UartClkSrcSel] =  CLK_GetPCLK0Freq();
            u32ClkTbl[u8UartClkSrcSel] =  CLK_GetPCLK1Freq();
    if ((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE0)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1ul) / (u32Baud_Div + 2ul)) >> 4;
    else if ((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_MODE2)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1ul) / (u32Baud_Div + 2ul));
    else if ((uart->BAUD & (UART_BAUD_BAUDM1_Msk | UART_BAUD_BAUDM0_Msk)) == UART_BAUD_BAUDM1_Msk)
        return ((u32ClkTbl[u8UartClkSrcSel]) / (u8UartClkDivNum + 1ul) / (u32Baud_Div + 2ul)) / (((uart->BAUD & UART_BAUD_EDIVM1_Msk) >> UART_BAUD_EDIVM1_Pos) + 1ul);
    else
        return 0;
dongnanxibei| | 2023-2-26 20:10 | 只看该作者
是不是硬件本身就支持这个功能
mintspring| | 2023-2-26 21:24 | 只看该作者
以前都是用固定波特率,如果双方都是自动会不会有问题
OKAKAKO| | 2023-2-27 15:41 | 只看该作者
串口的波特率不能设太高,要不不稳定
星辰大海不退缩| | 2023-2-27 15:58 | 只看该作者
串口自动波特率检测功能(ABR)可以让设备在进行串口通信时不用提前设置好波特率,根据对方的波特率实时更改自己的波特率,可以大大提高己方设备的兼容性
szt1993| | 2023-2-28 12:55 | 只看该作者
是有的硬件自带,但不带的多吧?
中国龙芯CDX| | 2023-2-28 14:08 | 只看该作者
自动波特率设置是不是对于MCU硬件要求比较高?
LOVEEVER| | 2023-2-28 14:37 | 只看该作者
自动波特率一方去适应另一个让设备稳定,哪都自动是不是也不好,还是没事?
AloneKaven| | 2023-3-1 20:03 | 只看该作者
自动波特率是几个固定值之间切换还是可以适应任意值
sanfuzi| | 2023-4-16 22:24 | 只看该作者
M031 系列单片机的串口具有自动波特率检测功能,可以自动识别外部设备的波特率并进行通讯。
jackcat| | 2023-4-18 13:18 | 只看该作者
需要选择一个适当的指定字符或字符串,以确保其能够在各种波特率下得到正确的识别和接收。
fengm| | 2023-4-18 13:43 | 只看该作者
在进行自动波特率检测时,应保证外部设备发送的数据符合 UART 协议规范,并且要考虑到干扰信号和误码率等因素对波特率检测的影响。
bartonalfred| | 2023-4-18 18:49 | 只看该作者
发送一个指定字符或字符串给外部设备,该字符或字符串的发送时间应足够长,以确保其可以被外部设备正确接收。
Jacquetry| | 2023-4-18 23:08 | 只看该作者
是使用任何频率吗?
星辰大海不退缩| | 2023-4-23 20:58 | 只看该作者
自动波特率应该得看硬件是否支持吧
gejigeji521| | 2023-4-23 21:41 | 只看该作者
是不是也支持DMA。
pmp| | 2023-5-10 21:58 | 只看该作者
在高速传输或者噪声干扰较大的环境下,自动波特率检测可能会出现误判的情况
dspmana| | 2023-5-10 22:18 | 只看该作者
发送一个特定的帧数据,使接收端能够检测到波特率。这通常是发送一个由相同数据位组成的连续字节,直到有足够多的数据被接收并解析出正确的波特率为止。
AloneKaven| | 2023-5-10 22:42 | 只看该作者
那调节波特率的时间会不会很长
