今天搞了一下AD采集热敏电阻值。
原理图:
代码:
- #include "main.h"
- /** @addtogroup Examples
- /** @addtogroup ADC_ContinuousConversion
- /** @defgroup ADC_ContinuousConversion_Macros Macros
- /* printf function configs to USART1 */
 - #define DEBUG_USART  USART1
- /**@} end of group ADC_ContinuousConversion_Macros*/
- /** @defgroup ADC_ContinuousConversion_Functions Functions
- void ADC_Init(void);
 - void Delay(uint32_t count);
 -  * [url=home.php?mod=space&uid=247401]@brief[/url]       Main program
 -  * @param       None
 -  * @retval      None
 - int main(void)
 -     USART_Config_T USART_ConfigStruct;
 -     /* USART config */
 -     USART_ConfigStruct.baudRate = 115200;
 -     USART_ConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
 -     USART_ConfigStruct.mode = USART_MODE_TX;
 -     USART_ConfigStruct.parity = USART_PARITY_NONE;
 -     USART_ConfigStruct.stopBits = USART_STOP_BIT_1;
 -     USART_ConfigStruct.wordLength = USART_WORD_LEN_8B;
-     APM_MINI_COMInit(COM1, &USART_ConfigStruct);
 -     /* ADC1 initialization */
 -     ADC_Init();
 -     while(1)
 -                         printf("\r\n voltage : mV\r\n");
 -  * @brief     ADC Init
 -  * @param     None
 -  * @retval    None
 -     GPIO_Config_T           gpioConfig;
 -     ADC_Config_T            adcConfig;
-     /* Enable GPIOA clock */
 -     RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOA);
-     /* ADC channel 0 configuration */
 -     GPIO_ConfigStructInit(&gpioConfig);
 -     gpioConfig.mode    = GPIO_MODE_ANALOG;
 -     gpioConfig.pin     = GPIO_PIN_0;
 -     GPIO_Config(GPIOA, &gpioConfig);
-     /* ADCCLK = PCLK2/4 */
 -     RCM_ConfigADCCLK(RCM_PCLK2_DIV_4);
 -     /* Enable ADC clock */
 -     RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
-     /* ADC configuration */
 -     ADC_Reset(ADC1);
 -     ADC_ConfigStructInit(&adcConfig);
 -     adcConfig.mode                  = ADC_MODE_INDEPENDENT;
 -     adcConfig.scanConvMode          = DISABLE;
 -     adcConfig.continuosConvMode     = ENABLE;
 -     adcConfig.externalTrigConv      = ADC_EXT_TRIG_CONV_None;
 -     adcConfig.dataAlign             = ADC_DATA_ALIGN_RIGHT;
 -     /* channel number */
 -     adcConfig.nbrOfChannel          = 1;
 -     ADC_Config(ADC1, &adcConfig);
-     /* ADC channel Convert configuration */
 -     ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_13CYCLES5);
 -     /* Enable complete conversion interupt */
 -     ADC_EnableInterrupt(ADC1, ADC_INT_EOC);
-     /* NVIC configuration */
 -     NVIC_EnableIRQRequest(ADC1_2_IRQn, 1, 1);
 -     /* Enable ADC */
 -     ADC_Enable(ADC1);
-     /* Enable ADC1 reset calibration register */
 -     ADC_ResetCalibration(ADC1);
 -     /* Check the end of ADC1 reset calibration register */
 -     while(ADC_ReadResetCalibrationStatus(ADC1));
-     /* Start ADC1 calibration */
 -     ADC_StartCalibration(ADC1);
 -     /* Check the end of ADC1 calibration */
 -     while(ADC_ReadCalibrationStartFlag(ADC1));
-     /* Start ADC1 Software Conversion */
 -     ADC_EnableSoftwareStartConv(ADC1);
 -  * @brief       ADC1 Isr
 -  * @param       None
 -  * @retval      None
 -  * [url=home.php?mod=space&uid=536309]@NOTE[/url]        This function need to put into ADC1_2_IRQHandler in apm32f10x_int.c
 - void ADC1_Isr(void)
 -     uint16_t adcData = 0;
 -     uint16_t voltage = 0;
 -     if (ADC_ReadIntFlag(ADC1, ADC_INT_EOC) == SET)
 -         ADC_ClearIntFlag(ADC1, ADC_INT_EOC);
 -         /* Read ADC Conversion value */
 -         adcData = ADC_ReadConversionValue(ADC1);
 -         /* voltage(mV) = adcData * (3300mV / 4095) */
 -         voltage = (adcData * 3300) / 4095;
 -         printf("\r\n voltage : %d mV\r\n", voltage);
 -  * @brief     Delay
 -  * @param     count:  delay count
 -  * @retval    None
 -     uint16_t i = 0;
 -     while (count--)
 -         i = 7995;
 -         while (i--);
- #if defined (__CC_ARM) || defined (__ICCARM__) || (defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050))
 - * @brief       Redirect C Library function printf to serial port.
 - *              After Redirection, you can use printf function.
 - * @param       ch:  The characters that need to be send.
 - * @param       *f:  pointer to a FILE that can recording all information
 - *              needed to control a stream
 - * @retval      The characters that need to be send.
 - * @note
 - int fputc(int ch, FILE* f)
 -     /* send a byte of data to the serial port */
 -     USART_TxData(DEBUG_USART, (uint8_t)ch);
-     /* wait for the data to be send */
 -     while (USART_ReadStatusFlag(DEBUG_USART, USART_FLAG_TXBE) == RESET);
-     return (ch);
- #elif defined (__GNUC__)
 - * @note
 - int __io_putchar(int ch)
 -     USART_TxData(DEBUG_USART, ch);
-     return ch;
 - * @param       file:  Meaningless in this function.
 - * @param       *ptr:  Buffer pointer for data to be sent.
 - * @param       len:  Length of data to be sent.
 - * @note
 - int _write(int file, char* ptr, int len)
 -     int i;
 -     for (i = 0; i < len; i++)
 -         __io_putchar(*ptr++);
-     return len;
- #else
 - #warning Not supported compiler type
 - #endif
- /**@} end of group ADC_ContinuousConversion_Functions */
 - /**@} end of group ADC_ContinuousConversion */
 - /**@} end of group Examples */
  效果图:
不摸热敏电阻
用手摸热敏电阻
