[技术问答] MA35D1的I2C无法正常使用问题
533|2
 楼主| elephant00 发表于 2023-3-17 14:40 | 显示全部楼层 |阅读模式
要用到I2C0 (PM8/PM9),在设备树中
\MA35D1_Buildroot\output\build\linux-custom\arch\arm64\boot\dts\nuvoton\ma35d1-iot-512m.dts增加以下内容:(调整内容移动到ma35d1.dtsi也是一样现象)
      i2c0: i2c@40800000 {
            compatible = "nuvoton,ma35d1-i2c";
            reg = <0x0 0x40800000 0x0 0x10000>;
            interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
            clocks = <&clk I2C0_GATE>;
            clock-frequency = <100000>;
            resets = <&reset MA35D1_RESET_I2C0>;
            status = "disable";
            #address-cells = <1>;
            #size-cells = <0>;
&i2c0 {
      status = "okay";
后启动错误。
timerc 发表于 2023-3-17 16:04 | 显示全部楼层
错误提示啥。。。
cr315 发表于 2023-3-18 14:00 | 显示全部楼层
I2C0默认是给pmic使用,因此需要修改TFA两个设备树如下。需要按照下面方式配置。
output/build/arm-trusted-firmware-custom/fdts/ma35d1.dtsi ,修改如下,增加<I2C0_TZNS>
sspcc: sspcc@404F0000 {
                compatible = "nuvoton,ma35d1-sspcc";
                reg = <0x0 0x404F0000 0x0 0x1000>;
                config = <UART0_TZNS>,
                        <SDH0_TZNS>,
                        <SDH1_TZNS>,
                        <NAND_TZNS>,
                        <QSPI0_TZNS>,
                        <CRYPTO_TZNS>,
                        <WDTWWDT1_TZNS>,
                        <HSUSBD_TZNS>,
                        <PDMA0_TZNS>,
                        <PDMA1_TZNS>,
                        <TIMER01_TZNS>,
                        <UART16_SUBM>,
                        <I2C0_TZNS>,
                        <TRNG_TZNS>;
output/build/arm-trusted-firmware-custom/fdts/ma35d1-cpu800-wb-128m.dts 屏蔽以下代码
/*&sspcc {
        gpio_s = <PD6_S>,
                <PD7_S>;
