初始化及配置如下
#define UART2_TX_DMA_CH 6
//初始化
SYS_ResetModule(UART2_RST);
PDMA_UART2_Init();
UART_Open(UART2, u32baudrate);
UART2->FIFO = (UART2->FIFO & (~ UART_FIFO_RFITL_Msk)) | UART_FIFO_RFITL_14BYTES;
UART_SetTimeoutCnt(UART2, 60);
UART_EnableInt(UART2, (UART_INTEN_RDAIEN_Msk | UART_INTEN_RXTOIEN_Msk));
NVIC_EnableIRQ(UART2_IRQn);//打开接收中断
void PDMA_UART2_Init(void){
PDMA_Open( /*(1 << UART2_RX_DMA_CH) | */ (1 << UART2_TX_DMA_CH));
/* UART Tx PDMA channel configuration */
PDMA->DSCT[UART2_TX_DMA_CH].CTL =
(1 - 1) << PDMA_DSCT_CTL_TXCNT_Pos | /* Transfer count */
PDMA_WIDTH_8 |/* Transfer width 8 bits */
PDMA_DAR_FIX| /* Fixed destination address */
PDMA_SAR_INC| /* Increment source address */
PDMA_DSCT_CTL_TBINTDIS_Msk | /* Table interrupt disabled */
PDMA_REQ_SINGLE| /* Single request type */
PDMA_OP_BASIC; /* Basic mode */
PDMA->DSCT[UART2_TX_DMA_CH].SA = (uint32_t)uart2_dma_buffer;/* Source address */
PDMA->DSCT[UART2_TX_DMA_CH].DA = (uint32_t)&UART2->DAT;/* Destination address */
/* Request source selection */
PDMA_SetTransferMode(UART2_TX_DMA_CH, PDMA_UART2_TX, FALSE, 0);
/* Enable PDMA Transfer Done Interrupt */
PDMA_EnableInt(UART2_TX_DMA_CH, PDMA_INT_TRANS_DONE);
NVIC_EnableIRQ(PDMA_IRQn);
NVIC_SetPriority(PDMA_IRQn,4);
void PDMA_UART2_TxTest(uint16_t num){
(num - 1) << PDMA_DSCT_CTL_TXCNT_Pos | /* Transfer count */
UART2->INTEN = UART2->INTEN | (1<<14);//UARTO DMA send enable
void PDMA_IRQHandler(void){
/* Get PDMA interrupt status */
uint32_t status = PDMA_GET_INT_STATUS();
if (status & PDMA_INTSTS_ABTIF_Msk){ /* Target Abort */
PDMA_CLR_ABORT_FLAG(PDMA_ABTSTS_ABTIFn_Msk);
else if(status & PDMA_INTSTS_TDIF_Msk){ /* Transfer Done */
/* UART Tx PDMA transfer done interrupt flag */
if (PDMA_GET_TD_STS() & (1<<UART3_TX_DMA_CH)){
/* Clear PDMA transfer done interrupt flag */
PDMA_CLR_TD_FLAG( (1<<UART3_TX_DMA_CH) );
/* Disable UART Tx PDMA function */
UART3->INTEN &= ~UART_INTEN_TXPDMAEN_Msk;
if (PDMA_GET_TD_STS() & (1<<UART2_TX_DMA_CH)){
PDMA_CLR_TD_FLAG( (1<<UART2_TX_DMA_CH) );
UART2->INTEN &= ~UART_INTEN_TXPDMAEN_Msk;
void UART2_IRQHandler(void){
uint32_t u32IntSts = UART2->INTSTS;
uint8_t i;
memset(rx_buff, 0, UART_RX_BUFF_SIZE_MAX);
if(u32IntSts & UART_INTSTS_RXTOINT_Msk){//空闲中断
rx_buff[0] = UART_READ(UART2);
if((bsp_uart_ctx.uart2_rx_cb != NULL)){
bsp_uart_ctx.uart2_rx_cb(rx_buff, 1);
/*i = 0;
while(UART_GET_RX_EMPTY(UART2) == 0){
if(i >= UART_RX_BUFF_SIZE_MAX){
//正常不可能进入这里,因为FIFO是14字节
i = 0;
if(bsp_uart_ctx.uart2_rx_cb != NULL){
bsp_uart_ctx.uart2_rx_cb(rx_buff, UART_RX_BUFF_SIZE_MAX);
}else{
rx_buff[i++] = UART_READ(UART2);
if((i > 0) && (bsp_uart_ctx.uart2_rx_cb != NULL)){
bsp_uart_ctx.uart2_rx_cb(rx_buff, i);
if(u32IntSts & UART_INTSTS_RDAINT_Msk){//14字节FIFI 满的中断
i = 0;
for(i=0; i<13; i++) {
if(UART_GET_RX_EMPTY(UART2) != 0){//再判断一下fifo是否为空吧
break;
rx_buff[i] = UART_READ(UART2);
