[STM32F1]
流水灯还有人会写吗?
627|13
小明的同学|  楼主 | 2023-3-23 15:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stm32f1xx_hal.h"
#define LED_PIN GPIO_PIN_13
#define LED_GPIO_PORT GPIOC
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
int main(void)
  HAL_Init();  // 初始化HAL库
  SystemClock_Config();  // 配置系统时钟
  MX_GPIO_Init();  // 配置GPIO
  while (1)
    HAL_GPIO_TogglePin(LED_GPIO_PORT, LED_PIN);  // 翻转LED
    HAL_Delay(500);  // 延时500ms
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  __HAL_RCC_GPIOC_CLK_ENABLE();
  GPIO_InitStruct.Pin = LED_PIN;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LED_GPIO_PORT, &GPIO_InitStruct);
void Error_Handler(void)
  // 错误处理函数,可以在此处添加代码处理错误
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t *file, uint32_t line)
  // 断言失败处理函数,可以在此处添加代码处理错误
#endif /* USE_FULL_ASSERT */
在此代码中,我们使用了HAL库函数来控制LED灯的亮灭。具体地,我们定义了LED灯的引脚号和端口号,然后在主循环中不断翻转LED灯的状态,同时延时500ms。
该程序的基本流程如下:
初始化HAL库
配置系统时钟
配置GPIO
进入主循环
在主循环中翻转LED灯状态,并延时500ms
注意,在程序中还需要定义和实现错误处理的函数。如果出现错误,可以在 Error_Handler() 函数中添加代码来进行处理。在这个示例代码中,我们只是简单地定义了 Error_Handler() 函数,但是在实际的应用中,你可能需要根据具体的情况来实现该函数,以便更好地处理错误。另外,还有一个可选的函数 assert_failed(),用于处理断言失败的情况,也可以根据具体需要进行定义和实现。
需要注意的是,对于不同的STM32芯片,可能需要使用不同的HAL库函数,或者需要进行不同的配置。在编写代码时,一定要仔细查阅相关的资料,以确保代码的正确性。
AloneKaven| | 2023-3-23 22:35 | 只看该作者
哈哈,确实已经很久不写流水灯了
Clyde011| | 2024-4-22 07:32 | 只看该作者
环氧树脂、聚胺脂、有机硅灌封胶
万图| | 2024-4-22 09:28 | 只看该作者
保护被保护IC或线路
Uriah| | 2024-4-22 10:31 | 只看该作者
电源模块的灌封用的胶是可以根据需求而调制的
帛灿灿| | 2024-4-22 12:27 | 只看该作者
所以不会通过地损耗
Bblythe| | 2024-4-22 13:30 | 只看该作者
相当于积分,用于滤波
Pulitzer| | 2024-4-22 16:29 | 只看该作者
使该元器件不超过正常值范围
Wordsworth| | 2024-4-22 19:28 | 只看该作者
ESD静电保护器工作特性与TVS管一致。
