[STM32H7] 为啥我的人体姿态的训练模型运行不起来
6796|30
 楼主| 土司Apple 发表于 2023-4-19 15:55 | 显示全部楼层 |阅读模式
AD, se, ar, RS, PA, 模型
https://github.com/Shahnawax/HAR-CNN-Keras
这是ST给的模型训练的py脚本,为啥我运行不起来呢
#!/usr/bin/envpython3
# -*-coding: utf-8 -*-
Createdon Wed Sep 27 14:34:20 2017
Thisis a small project for CNN in KERAS.
Thisfile creates, trains and save a convolutional neural network for
HumanAcitivity Recognition. The data we used for this file is released and providedby
WirelessSensor Data Mining (WISDM) lab and can be found on this link.
http://www.cis.fordham.edu/wisdm/dataset.php
Feelfree to use this code and site this repositry if you use it for your reports orproject.
@author:Muhammad Shahnawaz
#importing libraries and dependecies
import os
import pandas as pd
import numpy as np
importmatplotlib.pyplot as plt
from scipy import stats
from keras.models import Sequential
from keras.layers import Dense, Conv2D,MaxPooling2D, Flatten, Dropout
#fromkeras import backend as K
from keras import optimizers
#K.set_image_dim_ordering('th')
#setting up a random seed for reproducibility
random_seed = 611
np.random.seed(random_seed)
#matplotlib inline
plt.style.use('ggplot')
#defining function for loading the dataset
def readData(filePath):
    #attributes of the dataset
    columnNames = ['user_id','activity','timestamp','x-axis','y-axis','z-axis']
    data = pd.read_csv(filePath,header = None, names=columnNames,na_values=';')
    return data
#defining a function for feature normalization
#(feature - mean)/stdiv
def featureNormalize(dataset):
    mu = np.mean(dataset,axis=0)
    sigma = np.std(dataset,axis=0)
    return (dataset-mu)/sigma
#defining the function to plot a single axis data
def plotAxis(axis,x,y,title):
   axis.plot(x,y)
   axis.set_title(title)
    axis.xaxis.set_visible(False)
    axis.set_ylim([min(y)-np.std(y),max(y)+np.std(y)])
    axis.set_xlim([min(x),max(x)])
    axis.grid(True)
#defining a function to plot the data for a given activity
def plotActivity(activity,data):
    fig,(ax0,ax1,ax2) = plt.subplots(nrows=3, figsize=(15,10),sharex=True)
    plotAxis(ax0,data['timestamp'],data['x-axis'],'x-axis')
    plotAxis(ax1,data['timestamp'],data['y-axis'],'y-axis')
    plotAxis(ax2,data['timestamp'],data['z-axis'],'z-axis')
    plt.subplots_adjust(hspace=0.2)
   fig.suptitle(activity)
    plt.subplots_adjust(top=0.9)
   plt.show()
#defining a window function for segmentation purposes
def windows(data,size):
    start = 0
    while start< data.count():
        yield int(start), int(start + size)
        start+= (size/2)
#segmenting the time series
def segment_signal(data, window_size = 90):
    segments = np.empty((0,window_size,3))
    labels= np.empty((0))
    for (start, end) in windows(data['timestamp'],window_size):
        x = data['x-axis'][start:end]
        y = data['y-axis'][start:end]
        z = data['z-axis'][start:end]
        if(len(data['timestamp'][start:end])==window_size):
           segments =np.vstack([segments,np.dstack([x,y,z])])
            labels =np.append(labels,stats.mode(data['activity'][start:end])[0][0])
    return segments, labels
'''Main Code '''
# # ## # # # # #   reading the data   # # # # # # # # # #
#Path of file #
dataset = readData('actitracker_raw.txt')
#plotting a subset of the data to visualize
for activity in np.unique(dataset['activity']):
    subset = dataset[dataset['activity']==activity][:180]
   plotActivity(activity,subset)
#segmenting the signal in overlapping windows of 90 samples with 50% overlap
segments,labels = segment_signal(dataset)
#categoricallydefining the classes of the activities
labels = np.asarray(pd.get_dummies(labels),dtype = np.int8)
#defining parameters for the input and network layers
# weare treating each segmeent or chunk as a 2D image (90 X 3)
numOfRows = segments.shape[1]
numOfColumns = segments.shape[2]
numChannels = 1
numFilters = 128 # number of filters in Conv2D layer
#kernal size of the Conv2D layer
kernalSize1 = 2
# maxpooling window size
poolingWindowSz = 2
#number of filters in fully connected layers
numNueronsFCL1 = 128
numNueronsFCL2 = 128
#split ratio for test and validation
trainSplitRatio = 0.8
#number of epochs
Epochs = 10
#batchsize
batchSize = 10
#number of total clases
numClasses = labels.shape[1]
#dropout ratio for dropout layer
dropOutRatio = 0.2
#reshaping the data for network input
reshapedSegments = segments.reshape(segments.shape[0], numOfRows,numOfColumns,1)
#splitting in training and testing data
trainSplit = np.random.rand(len(reshapedSegments))< trainSplitRatio
trainX= reshapedSegments[trainSplit]
testX= reshapedSegments[~trainSplit]
trainX= np.nan_to_num(trainX)
testX= np.nan_to_num(testX)
trainY= labels[trainSplit]
testY= labels[~trainSplit]
def cnnModel():
   model = Sequential()
    # addingthe first convolutionial layer with 32 filters and 5 by 5 kernal size, usingthe rectifier as the activation function
    model.add(Conv2D(numFilters,(kernalSize1,kernalSize1),input_shape=(numOfRows, numOfColumns,1),activation='relu'))
    # addinga maxpooling layer
    model.add(MaxPooling2D(pool_size=(poolingWindowSz,poolingWindowSz),padding='valid'))
    # addinga dropout layer for the regularization and avoiding over fitting
   model.add(Dropout(dropOutRatio))
    #flattening the output in order to apply the fully connected layer
   model.add(Flatten())
    # addingfirst fully connected layer with 256 outputs
    model.add(Dense(numNueronsFCL1, activation='relu'))
    #addingsecond fully connected layer 128 outputs
    model.add(Dense(numNueronsFCL2, activation='relu'))
    # addingsoftmax layer for the classification
    model.add(Dense(numClasses, activation='softmax'))
    #Compiling the model to generate a model
    adam = optimizers.Adam(lr = 0.001, decay=1e-6)
    model.compile(loss='categorical_crossentropy',optimizer=adam,metrics=['accuracy'])
    return model
model= cnnModel()
for layer in model.layers:
    print(layer.name)
model.fit(trainX,trainY, validation_split=1-trainSplitRatio,epochs=10,batch_size=batchSize,verbose=2)
score = model.evaluate(testX,testY,verbose=2)
print('Baseline Error: %.2f%%' %(100-score[1]*100))
model.save('model.h5')
np.save('groundTruth.npy',testY)
np.save('testData.npy',testX)
运行结果
PS E:\STM32_AI\HAR-CNN-Keras-master\HAR-CNN-Keras-master> & "D:/Program Files/Python311_64/python.exe" e:/STM32_AI/HAR-CNN-Keras-master/HAR-CNN-Keras-master/HAR.py
Traceback (most recent call last):
  File "e:\STM32_AI\HAR-CNN-Keras-master\HAR-CNN-Keras-master\HAR.py", line 81, in <module>
  File "e:\STM32_AI\HAR-CNN-Keras-master\HAR-CNN-Keras-master\HAR.py", line 34, in readData
  File "D:\Program Files\Python311_64\Lib\site-packages\pandas\io\parsers\readers.py", line 912, in read_csv
    return _read(filepath_or_buffer, kwds)
  File "D:\Program Files\Python311_64\Lib\site-packages\pandas\io\parsers\readers.py", line 583, in _read
    return parser.read(nrows)
  File "D:\Program Files\Python311_64\Lib\site-packages\pandas\io\parsers\readers.py", line 1704, in read
    ) = self._engine.read(  # type: ignore[attr-defined]
  File "D:\Program Files\Python311_64\Lib\site-packages\pandas\io\parsers\c_parser_wrapper.py", line 234, in read
    chunks = self._reader.read_low_memory(nrows)
  File "pandas\_libs\parsers.pyx", line 812, in pandas._libs.parsers.TextReader.read_low_memory
  File "pandas\_libs\parsers.pyx", line 873, in pandas._libs.parsers.TextReader._read_rows
  File "pandas\_libs\parsers.pyx", line 848, in pandas._libs.parsers.TextReader._tokenize_rows
  File "pandas\_libs\parsers.pyx", line 859, in pandas._libs.parsers.TextReader._check_tokenize_status
  File "pandas\_libs\parsers.pyx", line 2025, in pandas._libs.parsers.raise_parser_error
pandas.errors.ParserError: Error tokenizing data. C error: Expected 6 fields in line 134634, saw 11
 楼主| 土司Apple 发表于 2023-4-19 15:57 | 显示全部楼层
有懂得大神请给指导一下呗
chenqianqian 发表于 2023-4-19 21:16 来自手机 | 显示全部楼层
还没玩过ST的AI应用
Henryko 发表于 2023-4-19 22:16 | 显示全部楼层
AI应用,这么高端吗
pl202 发表于 2023-5-5 13:12 | 显示全部楼层
直接在stm32上运行吗?
pixhw 发表于 2023-5-5 19:16 | 显示全部楼层
这个训练模型高端了。
wwppd 发表于 2023-5-5 22:21 | 显示全部楼层
这个可以在单片机上运行吗
qiufengsd 发表于 2023-5-7 10:41 | 显示全部楼层
是使用卷积神经网络算法吗
yeates333 发表于 2023-5-7 15:55 | 显示全部楼层
这个接收的是什么数据
Undshing 发表于 2023-5-9 23:25 | 显示全部楼层
目前没多少ai的应用案例
wyjie 发表于 2023-5-10 21:31 | 显示全部楼层
还没玩过ST的AI应用
Pretext 发表于 2023-5-11 09:17 | 显示全部楼层
是不是环境有问题?
天天向善 发表于 2023-5-11 09:17 | 显示全部楼层
该安装的包都安装了吗?版本对得上吗?
芯路例程 发表于 2023-5-11 09:17 | 显示全部楼层
你用得是Python得哪个版本?
zwll 发表于 2023-5-11 19:11 | 显示全部楼层
AI应用,这么高端吗
chuxh 发表于 2023-5-11 19:12 | 显示全部楼层
直接在stm32上运行吗?
langgq 发表于 2023-5-11 19:13 | 显示全部楼层
这个训练模型高端了。
juventus9554 发表于 2023-5-11 19:14 | 显示全部楼层
这个可以在单片机上运行吗
gongche 发表于 2023-5-11 19:15 | 显示全部楼层
是使用卷积神经网络算法吗
stly 发表于 2023-5-11 19:18 | 显示全部楼层
这个接收的是什么数据
