[第三方配套工具]
rt_tick_increase() 在SMP时只增加当前核的TICK?
272|1
cr315|  楼主 | 2023-4-24 14:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看代号好象目标前是增加当前核的tick,但是是对imx6q这种四核的话,其他核的线程是不是就不能新tick了?
This function will notify kernel there is one tick passed. Normally, this function is invoked by clock ISR.
void rt_tick_increase(void)
struct rt_thread thread;
/ increase the global tick /
#ifdef RT_USING_SMP
rt_cpu_self()->tick ++;
#else
++ rt_tick;
#endif
/ check time slice /
thread = rt_thread_self();
-- thread->remaining_tick;
if (thread->remaining_tick == 0)
/ change to initialized tick /
thread->remaining_tick = thread->init_tick;
/ yield /
rt_thread_yield();
/ check timer */
rt_timer_check();
Bowclad| | 2023-5-8 23:45 | 只看该作者
OS tick计数,整个系统只有一个的
