在Arm architecture里,经常提到Context synchronization event(CSE)和Explicit synchronization,Context synchronization events在之前是叫作context synchronization operations。Explicit synchronization是Context synchronization event的结果,也就是CSE发生时,会伴随着Explicit synchronization。从概念上将,Explicit synchronization发生在每个CSE event的第一步,因此,如果CSE event使用之前已更改但在CSE event发生时尚未同步的状态,则保证CSE event使用已同步的状态。另外,任何导致写system registers的system instructions都必须同步,然后才能保证写的结果对该system register的后续direct read可见。
CSE的触发来源有:
One of:
Performing an ISB operation. An ISB operation is performed when an ISB instruction is executed and does not fail its condition code check.
Exception entry, if FEAT_ExS is not implemented or the exception is taken to AArch32 or if FEAT_ExS is implemented and the appropriate SCTLR_ELx.EIS bit is set.
Return from an exception, if FEAT_ExS is not implemented, or the exception is returning from AArch32 or if FEAT_ExS is implemented and the appropriate SCTLR_ELx.EOS bit is set.
Exit from Debug state.
Executing a DCPS instruction in Debug state.
Executing a DRPS instruction in Debug state.
以上这些源头中,4,5,6这三个和debug state相关的。ISB和exception entry events可用于Debug state和Non-debug state。
