ADC—独立模式-多通道-DMA scan模式 三根个引脚采集
- #ifndef __BSP_ADC_H
- #define __BSP_ADC_H
- #include "stm32f4xx.h"
- #define RHEOSTAT_NOFCHANEL 3
- /*=====================通道1 IO======================*/
- // PB0 通过调帽接电位器
- // ADC IO宏定义
- #define RHEOSTAT_ADC_GPIO_PORT1 GPIOB
- #define RHEOSTAT_ADC_GPIO_PIN1 GPIO_Pin_0
- #define RHEOSTAT_ADC_GPIO_CLK1 RCC_AHB1Periph_GPIOB
- #define RHEOSTAT_ADC_CHANNEL1 ADC_Channel_8
- /*=====================通道2 IO ======================*/
- // PB1 通过调帽接光敏电阻
- // ADC IO宏定义
- #define RHEOSTAT_ADC_GPIO_PORT2 GPIOB
- #define RHEOSTAT_ADC_GPIO_PIN2 GPIO_Pin_1
- #define RHEOSTAT_ADC_GPIO_CLK2 RCC_AHB1Periph_GPIOB
- #define RHEOSTAT_ADC_CHANNEL2 ADC_Channel_9
- /*=====================通道3 IO ======================*/
- // PA6 悬空,可用杜邦线接3V3或者GND来实验
- // ADC IO宏定义
- #define RHEOSTAT_ADC_GPIO_PORT3 GPIOA
- #define RHEOSTAT_ADC_GPIO_PIN3 GPIO_Pin_6
- #define RHEOSTAT_ADC_GPIO_CLK3 RCC_AHB1Periph_GPIOA
- #define RHEOSTAT_ADC_CHANNEL3 ADC_Channel_6
- // ADC 序号宏定义
- #define RHEOSTAT_ADC ADC1
- #define RHEOSTAT_ADC_CLK RCC_APB2Periph_ADC1
- // ADC DR寄存器宏定义,ADC转换后的数字值则存放在这里
- #define RHEOSTAT_ADC_DR_ADDR ((u32)ADC1+0x4c)
- // ADC DMA 通道宏定义,这里我们使用DMA传输
- #define RHEOSTAT_ADC_DMA_CLK RCC_AHB1Periph_DMA2
- #define RHEOSTAT_ADC_DMA_CHANNEL DMA_Channel_0
- #define RHEOSTAT_ADC_DMA_STREAM DMA2_Stream0
- void Rheostat_Init(void);
- #endif /* __BSP_ADC_H */
- * @file bsp_bsp_adc.c
- * @author fire
- * @version V1.0
- * @date 2015-xx-xx
- * @brief adc驱动
- * @attention
- * 实验平台:野火 STM32 F407 开发板
- * 论坛 :http://www.firebbs.cn
- * 淘宝 :https://fire-stm32.taobao.com
- #include "./adc/bsp_adc.h"
- __IO uint16_t ADC_ConvertedValue[RHEOSTAT_NOFCHANEL]={0};
- static void Rheostat_ADC_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /*=====================通道1======================*/
- // 使能 GPIO 时钟
- RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK1,ENABLE);
- // 配置 IO
- GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN1;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- //不上拉不下拉
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
- GPIO_Init(RHEOSTAT_ADC_GPIO_PORT1, &GPIO_InitStructure);
- /*=====================通道2======================*/
- // 使能 GPIO 时钟
- RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK2,ENABLE);
- // 配置 IO
- GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN2;
- //不上拉不下拉
- GPIO_Init(RHEOSTAT_ADC_GPIO_PORT2, &GPIO_InitStructure);
- /*=====================通道3=======================*/
- // 使能 GPIO 时钟
- RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK3,ENABLE);
- // 配置 IO
- GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN3;
- //不上拉不下拉
- GPIO_Init(RHEOSTAT_ADC_GPIO_PORT3, &GPIO_InitStructure);
- static void Rheostat_ADC_Mode_Config(void)
- DMA_InitTypeDef DMA_InitStructure;
- ADC_InitTypeDef ADC_InitStructure;
- ADC_CommonInitTypeDef ADC_CommonInitStructure;
- // ------------------DMA Init 结构体参数 初始化--------------------------
- // ADC1使用DMA2,数据流0,通道0,这个是手册固定死的
- // 开启DMA时钟
- RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_DMA_CLK, ENABLE);
- // 外设基址为:ADC 数据寄存器地址
- DMA_InitStructure.DMA_PeripheralBaseAddr = RHEOSTAT_ADC_DR_ADDR;
- // 存储器地址,实际上就是一个内部SRAM的变量
- DMA_InitStructure.DMA_Memory0BaseAddr = (u32)ADC_ConvertedValue;
- // 数据传输方向为外设到存储器
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
- // 缓冲区大小为,指一次传输的数据量
- DMA_InitStructure.DMA_BufferSize = RHEOSTAT_NOFCHANEL;
- // 外设寄存器只有一个,地址不用递增
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- // 存储器地址固定
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- // // 外设数据大小为半字,即两个字节
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- // 存储器数据大小也为半字,跟外设数据大小相同
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- // 循环传输模式
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- // DMA 传输通道优先级为高,当使用一个DMA通道时,优先级设置不影响
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- // 禁止DMA FIFO ,使用直连模式
- DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
- // FIFO 大小,FIFO模式禁止时,这个不用配置
- DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
- DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
- DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- // 选择 DMA 通道,通道存在于流中
- DMA_InitStructure.DMA_Channel = RHEOSTAT_ADC_DMA_CHANNEL;
- //初始化DMA流,流相当于一个大的管道,管道里面有很多通道
- DMA_Init(RHEOSTAT_ADC_DMA_STREAM, &DMA_InitStructure);
- // 使能DMA流
- DMA_Cmd(RHEOSTAT_ADC_DMA_STREAM, ENABLE);
- // 开启ADC时钟
- RCC_APB2PeriphClockCmd(RHEOSTAT_ADC_CLK , ENABLE);
- // -------------------ADC Common 结构体 参数 初始化------------------------
- // 独立ADC模式
- ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
- // 时钟为fpclk x分频
- ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;
- // 禁止DMA直接访问模式
- ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
- // 采样时间间隔
- ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
- ADC_CommonInit(&ADC_CommonInitStructure);
- // -------------------ADC Init 结构体 参数 初始化--------------------------
- ADC_StructInit(&ADC_InitStructure);
- // ADC 分辨率
- ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
- // 扫描模式,多通道采集需要
- ADC_InitStructure.ADC_ScanConvMode = ENABLE;
- // 连续转换
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
- //禁止外部边沿触发
- ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
- //外部触发通道,本例子使用软件触发,此值随便赋值即可
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
- //数据右对齐
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- //转换通道 1个
- ADC_InitStructure.ADC_NbrOfConversion = RHEOSTAT_NOFCHANEL;
- ADC_Init(RHEOSTAT_ADC, &ADC_InitStructure);
- // 配置 ADC 通道转换顺序和采样时间周期
- ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL1, 1,
- ADC_SampleTime_3Cycles);
- ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL2, 2,
- ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL3, 3,
- // 使能DMA请求 after last transfer (Single-ADC mode)
- ADC_DMARequestAfterLastTransferCmd(RHEOSTAT_ADC, ENABLE);
- // 使能ADC DMA
- ADC_DMACmd(RHEOSTAT_ADC, ENABLE);
- // 使能ADC
- ADC_Cmd(RHEOSTAT_ADC, ENABLE);
- //开始adc转换,软件触发
- ADC_SoftwareStartConv(RHEOSTAT_ADC);
- Rheostat_ADC_GPIO_Config();
- Rheostat_ADC_Mode_Config();
- * @file main.c
- * @author fire
- * @version V1.0
- * @brief ADC例程
- * @attention
- #include "./usart/bsp_debug_usart.h"
- // ADC转换的电压值通过MDA方式传到SRAM
- extern __IO uint16_t ADC_ConvertedValue[RHEOSTAT_NOFCHANEL];
- // 局部变量,用于保存转换计算后的电压值
- float ADC_ConvertedValueLocal[RHEOSTAT_NOFCHANEL]={0};
- static void Delay(__IO uint32_t nCount) //简单的延时函数
- for(; nCount != 0; nCount--);
- * @brief 主函数
- * @param 无
- * @retval 无
- int main(void)
- /*初始化USART 配置模式为 115200 8-N-1,中断接收*/
- Debug_USART_Config();
- Rheostat_Init();
- while (1)
- ADC_ConvertedValueLocal[0] =(float) ADC_ConvertedValue[0]/4096*(float)3.3;
- ADC_ConvertedValueLocal[1] =(float) ADC_ConvertedValue[1]/4096*(float)3.3;
- ADC_ConvertedValueLocal[2] =(float) ADC_ConvertedValue[2]/4096*(float)3.3;
- printf("\r\n CH1_C3 value = %f V \r\n",ADC_ConvertedValueLocal[0]);
- printf("\r\n CH2_PA4 value = %f V \r\n",ADC_ConvertedValueLocal[1]);
- printf("\r\n CH3_PA6 value = %f V \r\n",ADC_ConvertedValueLocal[2]);
- printf("\r\n\r\n");
- Delay(0xffffff);
- /*********************************************END OF FILE**********************/
