[AT32F421] AT32F421使用内部低速时钟如何每5分钟一次唤醒,可以有偿
1574|18
 楼主| yh1634803087 发表于 2023-6-11 17:16 | 显示全部楼层 |阅读模式
目前我如图配置只能实现进入一次时钟中断,如何配置ertc_alarm_value_set(3)这个函数实现每5分钟进一次ERTC闹钟中断,有没有大神指点一下。
1、
static void ERTC_AlarmConfig(void)
  EXTI_InitType EXTI_InitStructure;
//  ERTC_AlarmType ERTC_AlarmStructure;
  NVIC_InitType NVIC_InitStructure;
  /* EXTI configuration */
  EXTI_ClearIntPendingBit(EXTI_Line17);
  EXTI_InitStructure.EXTI_Line = EXTI_Line17;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineEnable = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable the ERTC Alarm Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = ERTC_IRQn;//ERTCAlarm_IRQn
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Set the alarm A Masks */
  ERTC_AlarmStructure.ERTC_AlarmMask = ERTC_AlarmMask_DateWeek | ERTC_AlarmMask_Hours | ERTC_AlarmMask_Seconds;
  ERTC_AlarmStructure.ERTC_AlarmDateWeekSel = ERTC_AlarmDateWeekSel_Date;
  ERTC_AlarmStructure.ERTC_AlarmDateWeek = ERTC_Week_MON;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Hours = 0X0;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Minutes = 0X5;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Seconds = 0X0;
  ERTC_SetAlarmValue(ERTC_Format_BCD, ERTC_AlA, &ERTC_AlarmStructure);
  /* Enable alarm A interrupt */
  ERTC_INTConfig(ERTC_INT_ALA, ENABLE);
  /* Enable the alarmA */
  ERTC_AlarmCmd(ERTC_AlA, ENABLE);
2、static void ERTC_Config(void)
  /* Enable the PWR clock */
//  RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_PWR, ENABLE);
  /* Allow access to ERTC */
  PWR_BackupAccessCtrl(ENABLE);
  /* Reset ERTC Domain */
  RCC_BackupResetCmd(ENABLE);
  RCC_BackupResetCmd(DISABLE);
  /* Enable the LSE OSC */
//  RCC_HSEConfig(RCC_HSE_ENABLE);  //启用HSE
    RCC_LSICmd(ENABLE);             //启用LSI
  /* Wait till LSE is ready */
  while(RCC_GetFlagStatus(RCC_FLAG_LSISTBL) == RESET)
  /* Select the ERTC Clock Source */
  RCC_ERTCCLKConfig(RCC_ERTCCLKSelection_LSI);
  /* Enable the ERTC Clock */
  RCC_ERTCCLKCmd(ENABLE);
  /* Deinitializes the ERTC registers */
  ERTC_Reset();
  /* Wait for ERTC APB registers synchronisation */
  ERTC_WaitForSynchro();
  /* Configure the ERTC data register and ERTC prescaler */
  /* ck_spre(1Hz) = ERTCCLK(LSI) /(AsynchPrediv + 1)*(SynchPrediv + 1)*/
  ERTC_InitStructure.ERTC_AsynchPrediv = 0x7F;
  ERTC_InitStructure.ERTC_SynchPrediv  = 0x13F;//0xFF;
  ERTC_InitStructure.ERTC_HourFormat   = ERTC_HourFormat_24;
  ERTC_Init(&ERTC_InitStructure);
  /* Set the time to 00h 00mn 00s AM */
  ERTC_TimeStruct.ERTC_AMPM     = ERTC_H12_AM;
  ERTC_TimeStruct.ERTC_Hours   = 0;
  ERTC_TimeStruct.ERTC_Minutes = 0;
  ERTC_TimeStruct.ERTC_Seconds = 0;
  ERTC_SetTimeValue(ERTC_Format_BCD, &ERTC_TimeStruct);
3、
int main(void)
    __IO uint32_t systick_index = 0;
        System_Init();        //硬件初始化
    Init_Function();                 //功能部件初始化
        init_sucess_flag = 1;
//    bsp_StartAutoTimer(3, 30000);          //50ms定时器
                            //初始化看门狗,时间3S左右
    //stop
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    ERTC_Config();
    ERTC_AlarmConfig();
    EXTI9_Config();
    EXTI15_Config();
        //进入主程序循环体
//    _IWDG_Init();
        while (1)
                //UpdateJudge();                 //判断是否有更新程序
                bsp_Idle();                                                         //调用MODS_Poll()
                Modbus_Data_P();
                RCC_GetClocksFreq(&get_rcc_clock);
                PLC_Function();
                LED_RUN_Function();
//                Sys_Reboot_Count_Function();
        ConfigModuleNoBlock();
//        ertc_alarm_value_set(3);
        len = rbCanRead(&rb_t_usart1_read);//读取数据
        if(len > 0)
            memset(usart1_read_buff_copy, 0, rb_t_usart1_read_buff_len);
            rbRead(&rb_t_usart1_read, usart1_read_buff_copy, len);//!!!!!!!!!!!!!!!!!!!!!!!!!!
            if(ConfigConnectDispose != NULL)
               ConfigConnectDispose((char*)usart1_read_buff_copy, len);
        if(Stop_Flag == 0 && SYS_start == 0)
//            systick_index = SysTick->CTRL;
//            systick_index &= ~((uint32_t)0xFFFFFFFE);
//            SysTick->CTRL &= (uint32_t)0xFFFFFFFE;
//          ERTC_TimeStruct.ERTC_AMPM     = ERTC_H12_AM;
//          ERTC_TimeStruct.ERTC_Hours   = 0;
//          ERTC_TimeStruct.ERTC_Minutes = 0;
//          ERTC_TimeStruct.ERTC_Seconds = 0;
//          ERTC_SetTimeValue(ERTC_Format_BCD, &ERTC_TimeStruct);
            PWR_EnterSTOPMode(PWR_Regulator_LowPower_Extra, PWR_STOPEntry_WFI);
//            SysTick->CTRL |= 0x1;
//            SysTick->CTRL |= systick_index;
            SYSCLKConfig_STOP();
4、
void ertc_alarm_value_set(uint32_t alam_index)
//    ERTC_InitType  ERTC_InitStructure;
    ERTC_TimeType  ERTC1_TimeStruct;
//  ERTC_TimeType ERTC_TimeStruct;
  /* disable the alarm */
//  ertc_alarm_enable(ERTC_ALA, FALSE);
  ERTC_AlarmCmd(ERTC_AlA, DISABLE);
  //ertc_calendar_get(&ertc_time_struct);
  ERTC_GetTimeValue(ERTC_Format_BCD, &ERTC1_TimeStruct);
//ertc_alarm_set(ERTC_ALA, ertc_time_struct.day, ertc_time_struct.hour, ertc_time_struct.min, (ertc_time_struct.sec + alam_index)% 60, ertc_time_struct.ampm);
//  ERTC_AlarmStructure.ERTC_AlarmDateWeek = ERTC_Week_MON;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Hours = ERTC1_TimeStruct.ERTC_Hours;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Minutes = (ERTC1_TimeStruct.ERTC_Minutes+alam_index) % 60;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_Seconds = ERTC1_TimeStruct.ERTC_Seconds;
  ERTC_AlarmStructure.ERTC_AlarmTime.ERTC_AMPM    = ERTC1_TimeStruct.ERTC_AMPM;
void SYSCLKConfig_STOP(void)
  HSEStartUpStatus = RCC_WaitForHSEStable();
  if(HSEStartUpStatus == SUCCESS)
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLSTBL) == RESET)
    RCC_SYSCLKConfig(RCC_SYSCLKSelction_PLL);
    while(RCC_GetSYSCLKSelction() != 0x08)
5、
oid ERTC_IRQHandler(void)
    if(ERTC_GetINTStatus(ERTC_INT_ALA) != RESET)
        /* Clear ERTC AlarmA Flags */
        Stop_Flag = 1;
        Report_5min_flag = 1;
        ERTC_ClearINTPendingBINT(ERTC_INT_ALA);
    /* Clear the EXTI line 17 */
chenqianqian 发表于 2023-6-11 22:19 来自手机 | 显示全部楼层
定时器计时中断唤醒。
 楼主| yh1634803087 发表于 2023-6-12 08:50 | 显示全部楼层
定时器计时中断唤醒。
你好,请问有例程吗?我这个ertc_alarm_value_set()的函数是看最新的库里有个调整闹钟时间的函数仿写的。我这个库怎么才能进入低功耗前重新设置闹钟时间+5分钟?
muyichuan2012 发表于 2023-6-12 16:08 | 显示全部楼层
参考BSP中如下案例
AT32F421_Firmware_Library/ project / at_start_f421 / examples / pwc / standby_ertc_alarm
调用如下函数将对应Hour/data进行mask即可。
ertc_alarm_mask_set(ERTC_ALA, ERTC_ALARM_MASK_DATE_WEEK | ERTC_ALARM_MASK_HOUR | ERTC_ALARM_MASK_MIN);
对应RTC应用指南第2.58章节有描述原理
https://www.arterytek.com/downlo ... _Note_ZH_V2.0.2.pdf
Henryko 发表于 2023-6-12 22:58 | 显示全部楼层
直接用定时器计数不就行了
你好,STOP模式下,定时器可以用吗,没试过。  发表于 2023-6-13 08:32
 楼主| yh1634803087 发表于 2023-6-16 08:46 | 显示全部楼层
谢谢各位关注,问题解决了,老版本的库STOP模式是有问题的,加上我图上那段后也能 50368648bb0e29754c.png 用,但还是建议使用STANDBY模式吧。
qcliu 发表于 2023-7-1 15:50 | 显示全部楼层
楼主的意思是 现有代码可以进入中断 但是只能进入一次 不能再次进入了是吗
drer 发表于 2023-7-1 16:05 | 显示全部楼层
楼主的代码里边使能的是哪个模块的中断啊
coshi 发表于 2023-7-1 16:45 | 显示全部楼层
谢谢各位关注,问题解决了,老版本的库STOP模式是有问题的,加上我图上那段后也能用,但还是建议使用STANDB ...
楼主有没有对比 新老版本 他们的差别在哪里啊
kxsi 发表于 2023-7-1 17:04 | 显示全部楼层
也就是说在老版本下 这个定时器的中断是不支持的是吗
wiba 发表于 2023-7-1 17:23 | 显示全部楼层
也就是说得明确各种模式下那么模块是可以正常工作的吧
tpgf 发表于 2023-7-1 17:38 | 显示全部楼层
内部时钟在停止模式下是不是已经完全不能正常工作了啊
 楼主| yh1634803087 发表于 2023-7-10 09:03 | 显示全部楼层
内部低速时钟可以工作的。
 楼主| yh1634803087 发表于 2023-7-10 09:04 | 显示全部楼层
嗯,合理选择模式,我这个是因为库太老了,可能有点问题,好在解决了,都能实现的。
 楼主| yh1634803087 发表于 2023-7-10 09:06 | 显示全部楼层
支持的,只不过要在进入之前再清一下ERTC的初始值,具体啥原因不清楚,自己一直一直试出来的。
我一开始发的就是没解决的版本,后面发的就是解决了修改的地方
 楼主| yh1634803087 发表于 2023-7-10 09:08 | 显示全部楼层
楼主的意思是 现有代码可以进入中断 但是只能进入一次 不能再次进入了是吗 ...
嗯,之前是这个问题,后面加入我最新的修改,就好了,就达到了我的目的,每5分钟唤醒进入一次中断。
chenjun89 发表于 2023-7-11 08:12 来自手机 | 显示全部楼层
中断后有没有重新对定时器进行赋值
