STM32F417, 我的代码Usart1为什么没反应呢?
4981|9
 楼主| javenreal 发表于 2012-4-28 12:06 | 显示全部楼层 |阅读模式
淘宝上花100元买了一个STM32F417,怎么调,Usart1都无法输出数据,请大家指教。(注1:串口硬件是好的,因为程序也是通过Usart1下载的。)
(注2:芯片里的程序已经正常运行,因为用万用表可以量出PA0的电平变化)
int main(void)
GPIO_InitTypeDef    GPIO_InitStructure;
USART_InitTypeDef   USART_InitStructure;
//rcc
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
                           RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD |
                           RCC_AHB1Periph_GPIOE, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
//gpio
GPIO_DeInit(GPIOA);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
//COM1 相关管脚
// Connect PXx to USARTx_Tx
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
// Connect PXx to USARTx_Rx
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
// Configure USART1_Rx
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
USART_DeInit(USART1);
//初始化第一个串口
USART_InitStructure.USART_BaudRate = 57600;  //波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //8位数据
USART_InitStructure.USART_StopBits = USART_StopBits_1;  //1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;     //无校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //不用RTS、CTS等
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;   //发送、接收使能
// Configure USART1
USART_Init(USART1, &USART_InitStructure);
// Enable the USART1
USART_Cmd(USART1, ENABLE);
char i = 0;
volatile unsigned int delay;
volatile int delay2;
while (1)
delay2 = 0;
while(delay2 < 3)
delay = 0;
while(delay < 0xFFFFF)
delay++;
//__asm("NOP");
delay2++;
if(i)
GPIO_ResetBits(GPIOA, GPIO_Pin_0);
i = 0;
else
GPIO_SetBits(GPIOA, GPIO_Pin_0);
i = 0x0F;
//USART_SendData(USART1, i);
USART1->DR = i;
fq1110 发表于 2012-4-28 12:47 | 显示全部楼层
增加这句试试,
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_AFIO, ENABLE);
 楼主| javenreal 发表于 2012-4-28 13:43 | 显示全部楼层
2# fq1110 你好,在F2和F4中,已经没有 “RCC_AHB1Periph_AFIO”了。
airwill 发表于 2012-4-28 13:54 | 显示全部楼层
不赞成没有示波器和 JTAG 调试器的调试方法.
小米加步枪的仅靠一个万用表调试 32 系统, 太累了
logokfu 发表于 2012-4-28 16:18 | 显示全部楼层
严重同意楼上的
fq1110 发表于 2012-4-28 17:10 | 显示全部楼层
嗯,刚看了,确实这样。
fq1110 发表于 2012-4-28 17:19 | 显示全部楼层
请问你是如何判断usart1无法输出数据的?
你是接电脑上RS232吗?还是两块板子连接?
如果是接RS232,中间请连接ttl->rs232,
建议如楼上两位所说,先弄个示波器测量一下。
PowerSource 发表于 2012-4-29 14:39 | 显示全部楼层
RS232电平转换芯片的TX脚虚焊了吗?
wxd123com 发表于 2012-9-6 15:51 | 显示全部楼层
遇到同样的问题。关注中。。。。。。。。。。
wxd123com 发表于 2012-9-6 18:51 | 显示全部楼层
今天仿真了一下,发现程序死在等待发送完毕的标志处。感觉奇怪。。。。。
