尝试自己写的12864
2503|2
 楼主| 奋斗小杰 发表于 2012-4-30 10:42 | 显示全部楼层 |阅读模式
gp, IO, GPIO, pi, pen
#include "NUC1xx.h"
#include "DrvGPIO.h"
#include "DrvSYS.h"
#include "SysInfra.h"
#define  rs_1 DrvGPIO_SetBit(E_GPC,14)
#define  rs_0 DrvGPIO_ClrBit(E_GPC,14)
#define  rw_1 DrvGPIO_SetBit(E_GPC,15)
#define  rw_0 DrvGPIO_ClrBit(E_GPC,15)
#define  en_1 DrvGPIO_SetBit(E_GPC,6)
#define  en_0 DrvGPIO_ClrBit(E_GPC,6)
uint8_t table[]="祝菜地越办越红火";
//uint8_t table1[]="";
void delay_ms(uint32_t count)// 延时函数MS
  uint32_t i,j;
  for(i=count;i>0;i--)
  for(j=2395;j>0;j--);
void RCC_init() //时钟初始化,选择12Ms
    UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;
    delay_ms(100);
    LOCKREG();
void GPIO_init()
DrvGPIO_Open( E_GPA, 2, E_IO_OUTPUT ); //DB0~DB7
DrvGPIO_Open( E_GPA, 3, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 4, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 5, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 6, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 7, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 8, E_IO_OUTPUT );
DrvGPIO_Open( E_GPA, 9, E_IO_OUTPUT );
DrvGPIO_Open( E_GPC, 14, E_IO_OUTPUT ); //RS
DrvGPIO_Open( E_GPC, 15, E_IO_OUTPUT ); //R/W
DrvGPIO_Open( E_GPC, 6, E_IO_OUTPUT ); //EN
void WriteCom(uint32_t in_com)
  int32_t com;
  com=in_com;
  com<<=2;
  rs_0;
  rw_0;
  en_1;
  delay_ms(1);
  GPIOA->DOUT=com;
  delay_ms(1);
  en_0;
void WriteData(uint32_t in_data)
  int32_t data;
  data=in_data;
  data<<=2;
  rs_1;
  rw_0;
  en_1;
  GPIOA->DOUT=data;
  delay_ms(1);
  en_0;
void lcd_init()
WriteCom(0x38);
delay_ms(10);
WriteCom(0x01);
delay_ms(10);
WriteCom(0x0c);
delay_ms(10);
WriteCom(0x06);
delay_ms(10);
WriteCom(0x80);
void display(void)
  uint8_t i;
  WriteCom(0x80);
  for(i=0;i<16;i++)
   WriteData(table[i]);
   delay_ms(5);
int main(void)
//DrvSYS_ResetChip();
GPIO_init();
//DrvGPIO_Open(E_GPA,2,E_IO_OUTPUT);
RCC_init();
lcd_init();
//WriteCom(0x80);
//WriteData('a');
display();
    while(1)
    // DrvGPIO_ClrBit(E_GPA,2);
     DrvGPIO_SetBit(E_GPA,5);
     delay_ms(100);
     DrvGPIO_SetBit(E_GPA,2);
     DrvGPIO_ClrBit(E_GPA,3);
     delay_ms(100);
     DrvGPIO_SetBit(E_GPA,3);
     DrvGPIO_ClrBit(E_GPA,4);
     delay_ms(100);
     DrvGPIO_SetBit(E_GPA,4);
     DrvGPIO_ClrBit(E_GPA,5);
     delay_ms(100);
        DrvSYS_Delay(5000);
    // rs_0;
zhl100 发表于 2012-5-2 11:47 | 显示全部楼层
写延时,刷新屏幕,系统有可能瘫痪
joing1999 发表于 2012-5-3 10:30 | 显示全部楼层
虽然简单,还是支持一下~~
个人签名:不怕做不到,就怕你敢不敢去做
