用non-os代码进行internal loop back测试是可以达到TRM 所描述的数值,而在Linux我们测试情况是FIFO trigger level 设置为0x30,波特率为6Mbps,在IoT板子 UART10把rx和tx短接进行2K Bytes自发自收100次是正常的。 FIFO trigger level 设置为0x30方法: 1. 驱动 output/build/linux-custom/drivers/tty/serial/ma35d1_serial.c ma35d1serial_startup()里面 serial_out(up, UART_REG_FCR, serial_in(up,UART_REG_FCR) | 0x10 | 0x20000); 改为 serial_out(up, UART_REG_FCR, serial_in(up,UART_REG_FCR) | 0x30 | 0x20000); 2. 设备树 output/build/linux-custom/arch/arm64/boot/dts/nuvoton/ma35d1.dtsi里面做以下修改 assigned-clocks = <&clk UART10_MUX>; assigned-clock-parents = <&clkSYSCLK1_DIV2>; uart10:serial@407A0000 { compatible = "nuvoton,ma35d1-uart"; reg = <0x0 0x407A0000 0x0 0x10000>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk UART10_GATE>; port-number = <10>; pdma-enable = <0>; assigned-clocks = <&clk UART10_MUX>; assigned-clock-parents = <&clk SYSCLK1_DIV2>; status = "disabled"; }; 3. 波特率修改方式: static int open_port(const char *portname) { structsigaction sa; intportfd; structtermios to; if((portfd=open(portname,O_RDWR | O_NOCTTY)) < 0 ) { printf("open serial port %s fail \n ",portname); return portfd; } /*getserial port parnms,save away */ tcgetattr(portfd,&newtios); memcpy(&oldtios,&newtios,sizeof newtios); /*configure new values */ cfmakeraw(&newtios); /*see man page */ newtios.c_iflag |=IGNPAR; /*ignore parity on input */ newtios.c_iflag &= ~(IXON | IXOFF | IXANY); //newtios.c_iflag |= (INPCK | ISTRIP); // for test newtios.c_oflag &= ~(OPOST | ONLCR | OLCUC | OCRNL | ONOCR | ONLRET| OFILL); newtios.c_cflag = CS8 | CLOCAL | CREAD; //newtios.c_cc[VMIN]=1; /* block until 1 char received */ newtios.c_cc[VMIN]=0xff; newtios.c_cc[VTIME]=0; /*no inter-character timer */ newtios.c_iflag |= CRTSCTS; /*register cleanup stuff */ atexit(reset_tty_atexit); memset(&sa,0,sizeof sa); sa.sa_handler = reset_tty_handler; sigaction(SIGHUP,&sa,NULL); sigaction(SIGINT,&sa,NULL); sigaction(SIGPIPE,&sa,NULL); sigaction(SIGTERM,&sa,NULL); /*applymodified termios */ saved_portfd=portfd; tcflush(portfd,TCIFLUSH); tcsetattr(portfd,TCSADRAIN,&newtios); ioctl(portfd, TCGETS2, &tio); tio.c_cflag &= ~CBAUD; tio.c_cflag |= BOTHER; tio.c_ispeed = 6000000; tio.c_ospeed = 6000000; ioctl(portfd, TCSETS2, &tio); returnportfd; } 执行/uart_demo_rx_tx
脚本:
#!/bin/sh
for i in $(seq 1 100)
do
echo "Running command: $i"
/uart_demo_rx_tx
sleep 1
done
