固件库是如何操作控制寄存器USART_CR1的?
6389|3
 楼主| 程序会不会 发表于 2012-5-1 13:44 | 显示全部楼层 |阅读模式
写了一个STM32的串口实验程序,就是不断的向PC串口发数据,可是在手册里看到控制寄存器USART_CR1中TE和RE分别为发送和接受使能,就是说每次在发送和接受数据的时候必须要置位这两位,可是我在固件库(usart.c这个函数)并没有找到设置这两个控制位的函数,我用的是3.5版本的库,芯片用的是107VC;再问一个关于波特率的问题:
手册上那个关于波特率的计算公式:系统时钟赫兹和波特率的进率为多少啊,这两个量之间有什么关系呢?.........问了这么多苦了大伙了,哈哈
logokfu 发表于 2012-5-1 14:04 | 显示全部楼层
怎么会没有使能 TE和RE的函数呢,楼主看这里。
  * @brief  Initializes the USARTx peripheral according to the specified
  *         parameters in the USART_InitStruct .
  * @param  USARTx: Select the USART or the UART peripheral.
  *   This parameter can be one of the following values:
  *   USART1, USART2, USART3, UART4 or UART5.
  * @param  USART_InitStruct: pointer to a USART_InitTypeDef structure
  *         that contains the configuration information for the specified USART
  *         peripheral.
  * @retval None
void USART_Init(USART_TypeDef* USARTx, USART_InitTypeDef* USART_InitStruct)  //TE 和RE使能就在这个函数里面包含着的
  uint32_t tmpreg = 0x00, apbclock = 0x00;
  uint32_t integerdivider = 0x00;
  uint32_t fractionaldivider = 0x00;
  uint32_t usartxbase = 0;
  RCC_ClocksTypeDef RCC_ClocksStatus;
  /* Check the parameters */
  assert_param(IS_USART_ALL_PERIPH(USARTx));
  assert_param(IS_USART_BAUDRATE(USART_InitStruct->USART_BaudRate));
  assert_param(IS_USART_WORD_LENGTH(USART_InitStruct->USART_WordLength));
  assert_param(IS_USART_STOPBITS(USART_InitStruct->USART_StopBits));
  assert_param(IS_USART_PARITY(USART_InitStruct->USART_Parity));
  assert_param(IS_USART_MODE(USART_InitStruct->USART_Mode));
  assert_param(IS_USART_HARDWARE_FLOW_CONTROL(USART_InitStruct->USART_HardwareFlowControl));
  /* The hardware flow control is available only for USART1, USART2 and USART3 */
  if (USART_InitStruct->USART_HardwareFlowControl != USART_HardwareFlowControl_None)
    assert_param(IS_USART_123_PERIPH(USARTx));
  usartxbase = (uint32_t)USARTx;
/*---------------------------- USART CR2 Configuration -----------------------*/
  tmpreg = USARTx->CR2;
  /* Clear STOP[13:12] bits */
  tmpreg &= CR2_STOP_CLEAR_Mask;
  /* Configure the USART Stop Bits, Clock, CPOL, CPHA and LastBit ------------*/
  /* Set STOP[13:12] bits according to USART_StopBits value */
  tmpreg |= (uint32_t)USART_InitStruct->USART_StopBits;
  /* Write to USART CR2 */
  USARTx->CR2 = (uint16_t)tmpreg;
/*---------------------------- USART CR1 Configuration -----------------------*/
  tmpreg = USARTx->CR1;
  /* Clear M, PCE, PS, TE and RE bits */
  tmpreg &= CR1_CLEAR_Mask;
  /* Configure the USART Word Length, Parity and mode ----------------------- */
  /* Set the M bits according to USART_WordLength value */
  /* Set PCE and PS bits according to USART_Parity value */
  /* Set TE and RE bits according to USART_Mode value */
  tmpreg |= (uint32_t)USART_InitStruct->USART_WordLength | USART_InitStruct->USART_Parity |
            USART_InitStruct->USART_Mode; //这里就是设置TE 和RE使能的地方。
  /* Write to USART CR1 */
  USARTx->CR1 = (uint16_t)tmpreg;
/*---------------------------- USART CR3 Configuration -----------------------*/
  tmpreg = USARTx->CR3;
  /* Clear CTSE and RTSE bits */
  tmpreg &= CR3_CLEAR_Mask;
  /* Configure the USART HFC -------------------------------------------------*/
  /* Set CTSE and RTSE bits according to USART_HardwareFlowControl value */
  tmpreg |= USART_InitStruct->USART_HardwareFlowControl;
  /* Write to USART CR3 */
  USARTx->CR3 = (uint16_t)tmpreg;
/*---------------------------- USART BRR Configuration -----------------------*/
  /* Configure the USART Baud Rate -------------------------------------------*/
  RCC_GetClocksFreq(&RCC_ClocksStatus);
  if (usartxbase == USART1_BASE)
    apbclock = RCC_ClocksStatus.PCLK2_Frequency;
  else
    apbclock = RCC_ClocksStatus.PCLK1_Frequency;
  /* Determine the integer part */
  if ((USARTx->CR1 & CR1_OVER8_Set) != 0)
    /* Integer part computing in case Oversampling mode is 8 Samples */
    integerdivider = ((25 * apbclock) / (2 * (USART_InitStruct->USART_BaudRate)));
  else /* if ((USARTx->CR1 & CR1_OVER8_Set) == 0) */
    /* Integer part computing in case Oversampling mode is 16 Samples */
    integerdivider = ((25 * apbclock) / (4 * (USART_InitStruct->USART_BaudRate)));
  tmpreg = (integerdivider / 100) << 4;
  /* Determine the fractional part */
  fractionaldivider = integerdivider - (100 * (tmpreg >> 4));
  /* Implement the fractional part in the register */
    tmpreg |= ((((fractionaldivider * 8) + 50) / 100)) & ((uint8_t)0x07);
    tmpreg |= ((((fractionaldivider * 16) + 50) / 100)) & ((uint8_t)0x0F);
  /* Write to USART BRR */
  USARTx->BRR = (uint16_t)tmpreg;
 楼主| 程序会不会 发表于 2012-5-1 14:19 | 显示全部楼层
看到了,丢人啊 ,那那个波特率的问题呢?就知道lofokfu大侠会回答我的提问,哈哈,向热心人士致敬 哈哈:kiss: 2# **kfu
logokfu 发表于 2012-5-1 17:02 | 显示全部楼层
这个不应该叫进率问题吧,呵呵。
你看这里,这个手册上说的。
  *         peripheral.
  * @retval None
/*---------------------------- USART BRR Configuration --------*/  //这一段就是上面那个公式的体现,你可以自己debug一下就知道了。这里的算法我没有看懂,但是这个就是按照那个公式算的。
  else
