就算是原文也是同样的原理啊,
If the primary power supply (Vin1) is present, the N-channel MOSFET transistor T3 is ON, which pulls down the gate of the P-channel MOSFET T2 and turns T2 ON.Transistor T1 sees as its gate-to-source voltage (Vgs) the drain-to-source voltage (Vds) of T2, which is only tens of mV. So, T1 is OFF and the external supply path (Vin2) is open.这个相当于我开关按下时的情况
in the case of an intermittent Vin1 blackout, T3 turns OFF because its gate is pulled down through R1, which turns T1 ON. The transistor T2 is turned OFF as its gate is pulled up thru R2 (Vgs of T2 is almost null).这个就是我开关断开时的情况
按这个说法应该是能实现的啊,关键我现在实现不了啊,原理图一样啊,只不过是MOS型号有差异而已,但不影响原理分析吧
