- void Adj_HSI_Value(void)
- int32_t hsi_opt;
- int32_t hsi_trim;
- int8_t hsi_opt_temp;
- int8_t hsi_trim_temp;
- int8_t temp;
- uint32_t time_out = 0xFFFFF;
- RCC_ConfigLse(RCC_LSE_ENABLE,0x28);
- while (RCC_GetFlagStatus(RCC_LDCTRL_FLAG_LSERD) == RESET)
- /* Enable Clock Security System(CSS): this will generate an NMI exception
- when HSE clock fails */
- TIM9_ConfigForLSE();
- RCC_EnableClockSecuritySystem(ENABLE);
- #if 0 //使用 PA8调试查看波形
- /*调试时先用该函数把频率调偏,然后用下面的函数自动调回来*/
- AFEC_ConfigHSITrim(AFEC_HSI_OPT_NUM5,AFEC_HSI_TRIM_NUM0);
- /* Output HSE clock on MCO pin
- RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
- GPIO_InitType GPIO_InitStructure;
- GPIO_InitStruct(&GPIO_InitStructure);
- GPIO_InitStructure.Pin = GPIO_PIN_8;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Alternate = GPIO_AF8_MCO;
- GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
- RCC_ConfigMcoClkPre(RCC_MCO_CLK_NUM0);
- RCC_ConfigMco(RCC_MCO_HSI);
- #endif
- //等待中断完成
- while((adj_flag == 0) && (time_out != 0))
- time_out--; //超时
- if(time_out != 0)
- //afec_hsi_opt[24:21]位粗调 HSI 频率,步长约为 700kHz,afec_hsi_trim[20:16]细调 HSI 频率,步长约为40kHz。
- //(TIM工作频率 - 计算频率)*2得到 16M主频差值
- hsi_opt_temp = ((int32_t)16000000 - Capture / 0.0029296875) / 1000 / 700;
- hsi_trim_temp = (((int32_t)16000000 - Capture / 0.0029296875) / 1000 - 700 * hsi_opt_temp) / 40;
- AFEC_GetHSITrim(&hsi_opt, &hsi_trim);
- if(hsi_trim_temp > 0)
- hsi_trim += hsi_trim_temp;
- if(hsi_trim > 31) //如果调整增加超过细调范围,增加粗调一次700K
- temp = hsi_trim / 17; // 700/40 = 17.5
- hsi_opt_temp += temp;
- hsi_trim = hsi_trim - 17*temp;
- if(hsi_trim_temp < 0)
- if(hsi_trim + hsi_trim_temp < 0) //如果小于0则向粗调借位
- temp = hsi_trim_temp / 17; // 700/40 = 17.5
- hsi_trim_temp = hsi_trim_temp - 17*temp; //temp为负数
- temp = - 1; // 700/40 = 17.5
- hsi_trim += hsi_trim_temp; //最后为正数
- hsi_opt += hsi_opt_temp;
- hsi_opt &= 0xF;
- hsi_trim &= 0x1F;
- AFEC_ConfigHSITrim(hsi_opt << 21, hsi_trim << 16);
- TIM9_Deinit();
这个是找的国民官方技术,他们帮忙用外部LSE校准了HSI,感谢
