[其他ST产品] STM32串口通信原理及HAL库代码stm32f1xx
2696|38
 楼主| 一点点0321 发表于 2023-9-20 14:57 | 显示全部楼层
HAL_StatusTypeDef HAL_UART_Receive_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
{//串口中断接收函数
  /* Check that a Rx process is not already ongoing */
  if(huart->RxState == HAL_UART_STATE_READY)
    if((pData == NULL) || (Size == 0U))
      return HAL_ERROR;
  /* Process Locked */
    __HAL_LOCK(huart);
    huart->pRxBuffPtr = pData;//接收的数据缓存指针
    huart->RxXferSize = Size;//接收的最大数据量字节数
    huart->RxXferCount = Size;//还剩余的要接收的数据量字节数
    huart->ErrorCode = HAL_UART_ERROR_NONE;
    huart->RxState = HAL_UART_STATE_BUSY_RX;
    /* Process Unlocked */
    __HAL_UNLOCK(huart);
    /* Enable the UART Parity Error Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_PE);//校验错误中断使能
    /* Enable the UART Error Interrupt: (Frame error, noise error, overrun error) */
    __HAL_UART_ENABLE_IT(huart, UART_IT_ERR);//错误中断使能-帧错误,噪错误,满溢错误
    /* Enable the UART Data Register not empty Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_RXNE);//接收中断使能【如果串口收到数据,则进入到串口处理函数HAL_UART_IRQHandler】
    return HAL_OK;
else
    return HAL_BUSY;
如果串口收到数据,则进入到串口处理函数HAL_UART_IRQHandler的下面部分执行
    if(((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET))
    {//打开串口中断,且有数据收到-RXNE被置位
      UART_Receive_IT(huart);
      return;
static HAL_StatusTypeDef UART_Receive_IT(UART_HandleTypeDef *huart)
  uint16_t* tmp;
  /* Check that a Rx process is ongoing */
  if(huart->RxState == HAL_UART_STATE_BUSY_RX)
    if(huart->Init.WordLength == UART_WORDLENGTH_9B)
    {//带有校验
      tmp = (uint16_t*) huart->pRxBuffPtr;
      if(huart->Init.Parity == UART_PARITY_NONE)
        *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x01FF);
        huart->pRxBuffPtr += 2U;
else
        *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x00FF);
        huart->pRxBuffPtr += 1U;
    else
    {//不带校验
        *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x00FF);//接收数据寄存器RDR被读取【保存数据到接收buf,并指向下一个】,RXNE标志复位。【当下1字节数据8位全部都从接收移位寄存器转移到接收数据寄存器RDR后,RXNE再次被置位,将再次触发RXNE中断,再次到此处执行,如此循环直到收完全部数据】
 楼主| 一点点0321 发表于 2023-9-20 14:58 | 显示全部楼层
else
        *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x007F);
    if(--huart->RxXferCount == 0U)
    {//收完全部数据后
      /* Disable the IRDA Data Register not empty Interrupt */
      __HAL_UART_DISABLE_IT(huart, UART_IT_RXNE);//关闭RXNE中断
      /* Disable the UART Parity Error Interrupt */
      __HAL_UART_DISABLE_IT(huart, UART_IT_PE);//关闭校验错误中断
        /* Disable the UART Error Interrupt: (Frame error, noise error, overrun error) */
        __HAL_UART_DISABLE_IT(huart, UART_IT_ERR);//关闭错误中断
/* Rx process is completed, restore huart->RxState to Ready */
      huart->RxState = HAL_UART_STATE_READY;
      HAL_UART_RxCpltCallback(huart);//接收完成中断回调函数,用户可以再这里做操作
      return HAL_OK;
    return HAL_OK;
  else
    return HAL_BUSY;
中国龙芯CDX 发表于 2024-4-28 18:14 | 显示全部楼层
楼主是使用的HAL库进行的开发?
楼主是使用的HAL库进行的开发?
Wordsworth 发表于 2024-9-6 07:29 | 显示全部楼层
电阻属于一个普通的元件
Clyde011 发表于 2024-9-6 08:32 | 显示全部楼层
并且考虑到TVS相同的尺寸
公羊子丹 发表于 2024-9-6 09:25 | 显示全部楼层
板与板(或空板)之间用邮票孔连接
万图 发表于 2024-9-6 10:28 | 显示全部楼层
当异常过压消失,恢复至高阻态
Uriah 发表于 2024-9-6 11:31 | 显示全部楼层
微控制器、数字信号控制器和处理器都具有内部的ESD钳位二极管
帛灿灿 发表于 2024-9-6 13:27 | 显示全部楼层
ESD电压一般超过导通电压
Bblythe 发表于 2024-9-6 14:30 | 显示全部楼层
模块电源选购灌封材料的时候,需要注意导热系数要能达到电子部件散热的需求,不过粘接能力不太强
周半梅 发表于 2024-9-6 16:26 | 显示全部楼层
可能击穿开关器件,
Pulitzer 发表于 2024-9-6 17:29 | 显示全部楼层
如果想要让它正常工作且不会损坏
童雨竹 发表于 2024-9-6 19:25 | 显示全部楼层
变压器副边同时对负载供电。
