[DemoCode下载]
新唐M0A21的PDMA使用起来很容易
532|4
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 2 $
* $Date: 20/06/01 1:35p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use PDMA channel 1 to transfer data from memory to memory.
* @note
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2020 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define PDMA_CH    1
/* Global variables        */
uint32_t PDMA_TEST_LENGTH = 64;
uint8_t au8SrcArray[256];
uint8_t au8DestArray[256];
uint32_t volatile g_u32IsTestOver = 0;
* @brief       DMA IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The DMA default IRQ, declared in startup_M0A21.s.
void PDMA_IRQHandler(void)
    uint32_t status = PDMA_GET_INT_STATUS(PDMA);
    if (status & PDMA_INTSTS_ABTIF_Msk)   /* abort */
        /* Check if channel 1 has abort error */
        if (PDMA_GET_ABORT_STS(PDMA) & PDMA_ABTSTS_ABTIF1_Msk)
            g_u32IsTestOver = 2;
        /* Clear abort flag of channel 1 */
        PDMA_CLR_ABORT_FLAG(PDMA, PDMA_ABTSTS_ABTIF1_Msk);
    else if (status & PDMA_INTSTS_TDIF_Msk)     /* done */
        /* Check transmission of channel 1 has been transfer done */
        if (PDMA_GET_TD_STS(PDMA) & PDMA_TDSTS_TDIF1_Msk)
            g_u32IsTestOver = 1;
        /* Clear transfer done flag of channel 1 */
        PDMA_CLR_TD_FLAG(PDMA, PDMA_TDSTS_TDIF1_Msk);
    else
        printf("unknown interrupt !!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable UART0 clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable PDMA clock */
    CLK_EnableModuleClock(PDMA_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.6 and TXD=PB.4 */
    SYS->GPB_MFP1 = (SYS->GPB_MFP1 & ~(SYS_GPB_MFP1_PB4MFP_Msk | SYS_GPB_MFP1_PB6MFP_Msk)) |
                    (SYS_GPB_MFP1_PB4MFP_UART0_TXD | SYS_GPB_MFP1_PB6MFP_UART0_RXD);
int main()
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("+------------------------------------------------------+ \n");
    printf("|    PDMA Memory to Memory Driver Sample Code          | \n");
                         au8SrcArray                         au8DestArray
                       /| [0]  | [1]  |  [2] |  [3] |       | [0]  | [1]  |  [2] |  [3] |\
       PDMA_TEST_LENGTH |            ...            |       |            ...            | PDMA_TEST_LENGTH
                       \| [60] | [61] | [62] | [63] |       | [60] | [61] | [62] | [63] |/
                               32bits(one word)                     32bits(one word)
      PDMA transfer configuration:
        Channel = 1
        Operation mode = basic mode
        Request source = PDMA_MEM(memory to memory)
        transfer done and table empty interrupt = enable
        Transfer count = PDMA_TEST_LENGTH
        Transfer width = 32 bits(one word)
        Source address = au8SrcArray
        Source address increment size = 32 bits(one word)
        Destination address = au8DestArray
        Destination address increment size = 32 bits(one word)
        Transfer type = burst transfer
        Total transfer length = PDMA_TEST_LENGTH * 32 bits
    /* Open Channel 1 */
    PDMA_Open(PDMA, 1 << PDMA_CH);
    /* Transfer count is PDMA_TEST_LENGTH, transfer width is 32 bits(one word) */
    PDMA_SetTransferCnt(PDMA, PDMA_CH, PDMA_WIDTH_32, PDMA_TEST_LENGTH);
    /* Set source address is au8SrcArray, destination address is au8DestArray, Source/Destination increment size is 32 bits(one word) */
    PDMA_SetTransferAddr(PDMA, PDMA_CH, (uint32_t)au8SrcArray, PDMA_SAR_INC, (uint32_t)au8DestArray, PDMA_DAR_INC);
    /* Request source is memory to memory */
    PDMA_SetTransferMode(PDMA, PDMA_CH, PDMA_MEM, FALSE, 0);
    /* Transfer type is burst transfer and burst size is 4 */
    PDMA_SetBurstType(PDMA, PDMA_CH, PDMA_REQ_BURST, PDMA_BURST_4);
    /* Enable interrupt */
    PDMA_EnableInt(PDMA, PDMA_CH, PDMA_INT_TRANS_DONE);
    /* Enable NVIC for PDMA */
    NVIC_EnableIRQ(PDMA_IRQn);
    /* Generate a software request to trigger transfer with PDMA channel 1  */
    PDMA_Trigger(PDMA, PDMA_CH);
    /* Waiting for transfer done */
    while (g_u32IsTestOver == 0);
    /* Check transfer result */
    if (g_u32IsTestOver == 1)
        printf("test done...\n");
    else if (g_u32IsTestOver == 2)
        printf("target abort...\n");
    /* Close channel 1 */
    PDMA_Close(PDMA);
    while (1);
/*** (C) COPYRIGHT 2020 Nuvoton Technology Corp. ***/
mintspring|  楼主 | 2023-9-24 20:38 | 只看该作者
你知道吗,单片机有一个东东叫DMA,可以搬运数据,这样就可以腾出CPU做专业的事情了,对于简单的搬砖工作交给DMA即可。
mintspring|  楼主 | 2023-9-24 20:41 | 只看该作者
传输单个宽度该例子设置的是PDMA_WIDTH_32,其实还可以设置为16,8.
该例子中传输的变量是256个8BIT字节符,所以按32BIT传输单位那就是64个。
如果改成16BITPDMA宽度,那么就要128个宽度了。
mintspring|  楼主 | 2023-9-24 20:42 | 只看该作者
编译后可以定位参数的位置,查看其他可用的参数。
mintspring|  楼主 | 2023-9-24 20:44 | 只看该作者
对于下次传输的地址是否增加还是固定不变也有参数设置PDMA_SAR_INC
/*  Address Attribute Constant Definitions        */
#define PDMA_SAR_INC        0x00000000UL            /*!<DMA SAR increment  \hideinitializer */
#define PDMA_SAR_FIX        0x00000300UL            /*!<DMA SAR fix address  \hideinitializer */
#define PDMA_DAR_INC        0x00000000UL            /*!<DMA DAR increment  \hideinitializer */
#define PDMA_DAR_FIX        0x00000C00UL            /*!<DMA DAR fix address  \hideinitializer */
