求助:GD32E230F8 timer16 dma 变脉宽无法生效问题
670|0
 楼主| 杨文天 发表于 2023-10-8 12:20 | 显示全部楼层 |阅读模式
源代码如下:
#include "gd32e23x.h"
#include <stdio.h>
#include "gd32e230c_eval.h"
#define TIMER16_CH0CV                   ((uint32_t)0x40014834)
uint16_t TX_buffer[3];
void dma_config(void)
    dma_parameter_struct dma_init_struct;
    rcu_periph_clock_enable(RCU_DMA);
    syscfg_dma_remap_enable(SYSCFG_DMA_REMAP_TIMER16);
    /* initialize DMA channel1 */
    dma_deinit(DMA_CH1);
    /* DMA channel4 initialize */
    dma_init_struct.periph_addr  = (uint32_t)TIMER16_CH0CV;
    dma_init_struct.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.memory_addr  = (uint32_t)TX_buffer;
    dma_init_struct.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_16BIT;
    dma_init_struct.direction    = DMA_MEMORY_TO_PERIPHERAL;
    dma_init_struct.number       = 3;
    dma_init_struct.priority     = DMA_PRIORITY_HIGH;
    dma_init( DMA_CH1, &dma_init_struct);
                //dma_memory_to_memory_disable(DMA_CH1);  // 关闭内存到内存模式
    /* enable DMA circulation mode */
    dma_circulation_enable(DMA_CH1);
    /* enable DMA channel4 */
    dma_channel_enable(DMA_CH1);
        //        nvic_irq_enable(DMA_Channel3_4_IRQn, 1);
void timer_config(void)
    uint16_t period = (72000/TX_Frequency_KHZ)-1;
    timer_oc_parameter_struct timer_ocinitpara;
    timer_parameter_struct timer_initpara;
    /* enable TIMER clock */
    rcu_periph_clock_enable(RCU_TIMER16);
    timer_deinit(TIMER16);
    /* initialize TIMER init parameter struct */
    timer_struct_para_init(&timer_initpara);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 0;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = period;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 5;
    timer_init(TIMER16, &timer_initpara);
    /* initialize TIMER channel output parameter struct */
    timer_channel_output_struct_para_init(&timer_ocinitpara);
    /* CH0 configuration in PWM1 mode */
    timer_ocinitpara.outputstate  = TIMER_CCX_ENABLE;
    //timer_ocinitpara.outputnstate = TIMER_CCXN_DISABLE;
    timer_ocinitpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
  //  timer_ocinitpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocinitpara.ocidlestate  = TIMER_OC_IDLE_STATE_HIGH;
   // timer_ocinitpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER16, TIMER_CH_0, &timer_ocinitpara);
    /* configure TIMER channel output pulse value */
    timer_channel_output_pulse_value_config(TIMER16, TIMER_CH_0, period>>1);
    /* configure TIMER channel output compare mode */
    timer_channel_output_mode_config(TIMER16, TIMER_CH_0, TIMER_OC_MODE_PWM0);
    /* disable TIMER channel output shadow function */
    timer_channel_output_shadow_config(TIMER16, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
    /* TIMER0 primary output enable */
    timer_primary_output_config(TIMER16, ENABLE);
    /* TIMER0 update DMA request enable */
    timer_dma_enable(TIMER16, TIMER_DMA_UPD);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER16);
    /* TIMER0 counter enable */
    timer_enable(TIMER16);
int main(void)
    uint16_t period = 500;
    TX_buffer[0] = 250;
    TX_buffer[1] = 100;
    TX_buffer[2] = 50;
    rcu_periph_clock_enable(RCU_GPIOA);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_7);
    gpio_af_set(GPIOA, GPIO_AF_5, GPIO_PIN_7);
    /* configure the DMA peripheral */
    dma_config();
    /* configure the TIMER peripheral */
    timer_config();
    while (1);
