[应用相关] STM32之TIM3_PWM程序
307|0
 楼主| duo点 发表于 2023-10-12 09:49 | 显示全部楼层 |阅读模式
原理图:
调PB5的亮度
头文件及完整例程下载:http://www.51hei.com/f/stm32标准例程库函数.rar
程序分析:
int main(void)
        unsigned char a=0;
        TIM_OCInitTypeDef  TIM3_OCInitStructure;
          RCC_Configuration();
          time_ini();
    SysTick_Config(72000);           //配置SYSTICK时钟节拍为1ms一次
          while(1){
                  Delay(1);                  //延时1ms
                TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                                           //PWM模式2
                  TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;                   //输出禁止
                  TIM3_OCInitStructure.TIM_Pulse = CCR2_Val;                                                           //确定占空比
                  TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
                  TIM_OC2Init(TIM3, &TIM3_OCInitStructure);
                  /*调整CCR2_Val的值来改变占空比,逐步的控制LED1的亮度, 占空比大过一定值时,
                亮度的变化就不明显了,所以CCR2_VAL最大设定到17000*/
                if(a==0) CCR2_Val=CCR2_Val+10;
                else CCR2_Val=CCR2_Val-10;
                if(CCR2_Val>17000){ CCR2_Val=17000; a=1;}
                else if(CCR2_Val<200){ CCR2_Val=200; a=0;}
时钟初始化打开RCC_APB2Periph_AFIO ,RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOCD| RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE
void RCC_Configuration(void){
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                                                  | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE , ENABLE);
配置初始化,初始化PB5为复用输出,TIM3部分映射到PB5,设置PWM的时钟为72M/(3*2400)=10K,初始化TIM3时钟,
占空比为
CCR2_Val /(TIM_Period  +1)
void time_ini(void){
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                                                //PB5复用为TIM3的通道2
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /*TIM3局部复用功能开启         在TIM3的局部复用开启时,PB5会被复用为TIM3_CH2*/
  GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3 , ENABLE);        //TIM3部分映射到PB5
  TIM3CLK=72MHz  预分频系数Prescaler=2 经过分频 定时器时钟为24MHz
  根据公式 通道输出占空比=TIM3_CCR2/(TIM_Period+1),可以得到TIM_Pulse的计数值
  捕获/比较寄存器2 TIM3_CCR2= CCR2_Val
  TIM3_TimeBaseStructure.TIM_Prescaler = 2;                                                    //预分频器TIM3_PSC=3                 24M
  TIM3_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                //计数器向上计数模式 TIM3_CR1[4]=0
  TIM3_TimeBaseStructure.TIM_Period =2399;                                            //自动重装载寄存器TIM3_APR  确定频率为10KHz
  TIM3_TimeBaseStructure.TIM_ClockDivision = 0x0;                                        //时钟分频因子 TIM3_CR1[9:8]=00
  TIM3_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseInit(TIM3,&TIM3_TimeBaseStructure);                                        //写TIM3各寄存器参数
  TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                             //PWM模式2 TIM3_CCMR1[14:12]=111 在向上计数时,
        //一旦TIMx_CNT<TIMx_CCR1时通道1为无效电平,否则为有效电平
  TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;    //输入/捕获2输出允许  OC2信号输出到对应的输出引脚PB5
  TIM3_OCInitStructure.TIM_Pulse = CCR2_Val;                                             //确定占空比,这个值决定了有效电平的时间。
  TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;             //输出极性  低电平有效 TIM3_CCER[5]=1;
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_Cmd(TIM3,ENABLE);        //启动定时器3 TIM3_CR1[0]=1;
        while(1){
                  Delay(1);                  //延时1ms
