[其它产品/技术] TC397:CAN&CANFD
1243|4
 楼主| aoyi 发表于 2023-10-27 22:00 | 显示全部楼层 |阅读模式
AN, CAN, tc
调用函数:
(1)初始化函数  void initMcmcan(void):
(2)  关于: IfxCan_Can_sendMessage(&g_mcmcan.canSrcNode, &g_mcmcan.txMsg, &g_mcmcan.txData[0])
void transmitCanMessage(void)
    /* Initialization of the RX message with the default configuration */
    IfxCan_Can_initMessage(&g_mcmcan.rxMsg);
    /* Invalidation of the RX message data content */
    memset((void *)(&g_mcmcan.rxData[0]), INVALID_RX_DATA_VALUE, MAXIMUM_CAN_DATA_PAYLOAD * sizeof(uint32));
    /* Initialization of the TX message with the default configuration */
    IfxCan_Can_initMessage(&g_mcmcan.txMsg);
    /* Define the content of the data to be transmitted */
    g_mcmcan.txData[0] = TX_DATA_LOW_WORD;
    g_mcmcan.txData[1] = TX_DATA_HIGH_WORD;
    /* Set the message ID that is used during the receive acceptance phase */
    g_mcmcan.txMsg.messageId = CAN_MESSAGE_ID;
    /* Send the CAN message with the previously defined TX message content */
    while( IfxCan_Status_notSentBusy ==
           IfxCan_Can_sendMessage(&g_mcmcan.canSrcNode, &g_mcmcan.txMsg, &g_mcmcan.txData[0]) )
MCMCAN.C
* \file MCMCAN.c
* \copyright Copyright (C) Infineon Technologies AG 2020
* Use of this file is subject to the terms of use agreed between (i) you or the company in which ordinary course of
* business you are acting and (ii) Infineon Technologies AG or its licensees. If and as long as no such terms of use
* are agreed, use of this file is subject to following:
* Boost Software License - Version 1.0 - August 17th, 2003
* Permission is hereby granted, free of charge, to any person or organization obtaining a copy of the software and
* accompanying documentation covered by this license (the "Software") to use, reproduce, display, distribute, execute,
* and transmit the Software, and to prepare derivative works of the Software, and to permit third-parties to whom the
* Software is furnished to do so, all subject to the following:
* The copyright notices in the Software and this entire statement, including the above license grant, this restriction
* and the following disclaimer, must be included in all copies of the Software, in whole or in part, and all
* derivative works of the Software, unless such copies or derivative works are solely in the form of
* machine-executable object code generated by a source language processor.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
* WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE
* COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
* IN THE SOFTWARE.
/*-----------------------------------------------------Includes------------------------------------------------------*/
#include "MCMCAN.h"
/*-------------------------------------------------Global variables--------------------------------------------------*/
McmcanType                  g_mcmcan;                       /* Global MCMCAN configuration and control structure    */
IfxPort_Pin_Config          g_led1;                         /* Global LED1 configuration and control structure      */
IfxPort_Pin_Config          g_led2;                         /* Global LED2 configuration and control structure      */
/*---------------------------------------------Function Implementations----------------------------------------------*/
/* Macro to define Interrupt Service Routine.
* This macro:
* - defines linker section as .intvec_tc<vector number>_<interrupt priority>.
* - defines compiler specific attribute for the interrupt functions.
* - defines the Interrupt service routine as ISR function.
* IFX_INTERRUPT(isr, vectabNum, priority)
*  - isr: Name of the ISR function.
*  - vectabNum: Vector table number.
*  - priority: Interrupt priority. Refer Usage of Interrupt Macro for more details.
IFX_INTERRUPT(canIsrTxHandler, 0, ISR_PRIORITY_CAN_TX);
IFX_INTERRUPT(canIsrRxHandler, 0, ISR_PRIORITY_CAN_RX);
/* Interrupt Service Routine (ISR) called once the TX interrupt has been generated.
* Turns on the LED1 to indicate successful CAN message transmission.
void canIsrTxHandler(void)
    /* Clear the "Transmission Completed" interrupt flag */
    IfxCan_Node_clearInterruptFlag(g_mcmcan.canSrcNode.node, IfxCan_Interrupt_transmissionCompleted);
    /* Just to indicate that the CAN message has been transmitted by turning on LED1 */
    IfxPort_setPinLow(g_led1.port, g_led1.pinIndex);
/* Interrupt Service Routine (ISR) called once the RX interrupt has been generated.
* Compares the content of the received CAN message with the content of the transmitted CAN message
* and in case of success, turns on the LED2 to indicate successful CAN message reception.
void canIsrRxHandler(void)
    /* Clear the "Message stored to Dedicated RX Buffer" interrupt flag */
    IfxCan_Node_clearInterruptFlag(g_mcmcan.canDstNode.node, IfxCan_Interrupt_messageStoredToDedicatedRxBuffer);
    /* Read the received CAN message */
    IfxCan_Can_readMessage(&g_mcmcan.canDstNode, &g_mcmcan.rxMsg, g_mcmcan.rxData);
    /* Check if the received data matches with the transmitted one */
    if( ( g_mcmcan.rxData[0] == g_mcmcan.txData[0] ) &&
        ( g_mcmcan.rxData[1] == g_mcmcan.txData[1] ) &&
        ( g_mcmcan.rxMsg.messageId == g_mcmcan.txMsg.messageId ) )
        /* Turn on the LED2 to indicate correctness of the received message */
        IfxPort_setPinLow(g_led2.port, g_led2.pinIndex);
/* Function to initialize MCMCAN module and nodes related for this application use case */
     * CAN module configuration and initialization:
     *  - load default CAN module configuration into configuration structure
     *  - initialize CAN module with the default configuration
    IfxCan_Can_initModuleConfig(&g_mcmcan.canConfig, &MODULE_CAN0);
    IfxCan_Can_initModule(&g_mcmcan.canModule, &g_mcmcan.canConfig);
     * Source CAN node configuration and initialization:
     *  - load default CAN node configuration into configuration structure
     *  - set source CAN node in the "Loop-Back" mode (no external pins are used)
     *  - assign source CAN node to CAN node 0
     *  - define the frame to be the transmitting one
     *  - once the transmission is completed, raise the interrupt
     *  - define the transmission complete interrupt priority
     *  - assign the interrupt line 0 to the transmission complete interrupt
     *  - transmission complete interrupt service routine should be serviced by the CPU0
     *  - initialize the source CAN node with the modified configuration
    IfxCan_Can_initNodeConfig(&g_mcmcan.canNodeConfig, &g_mcmcan.canModule);
    g_mcmcan.canNodeConfig.busLoopbackEnabled = TRUE;
    g_mcmcan.canNodeConfig.nodeId = IfxCan_NodeId_0;
    g_mcmcan.canNodeConfig.frame.type = IfxCan_FrameType_transmit;
    g_mcmcan.canNodeConfig.interruptConfig.transmissionCompletedEnabled = TRUE;
    g_mcmcan.canNodeConfig.interruptConfig.traco.priority = ISR_PRIORITY_CAN_TX;
    g_mcmcan.canNodeConfig.interruptConfig.traco.interruptLine = IfxCan_InterruptLine_0;
    g_mcmcan.canNodeConfig.interruptConfig.traco.typeOfService = IfxSrc_Tos_cpu0;
    IfxCan_Can_initNode(&g_mcmcan.canSrcNode, &g_mcmcan.canNodeConfig);
     * Destination CAN node configuration and initialization:
     *  - set destination CAN node in the "Loop-Back" mode (no external pins are used)
     *  - assign destination CAN node to CAN node 1
     *  - define the frame to be the receiving one
     *  - once the message is stored in the dedicated RX buffer, raise the interrupt
     *  - define the receive interrupt priority
     *  - assign the interrupt line 1 to the receive interrupt
     *  - receive interrupt service routine should be serviced by the CPU0
     *  - initialize the destination CAN node with the modified configuration
    g_mcmcan.canNodeConfig.nodeId = IfxCan_NodeId_1;
    g_mcmcan.canNodeConfig.frame.type = IfxCan_FrameType_receive;
    g_mcmcan.canNodeConfig.interruptConfig.messageStoredToDedicatedRxBufferEnabled = TRUE;
    g_mcmcan.canNodeConfig.interruptConfig.reint.priority = ISR_PRIORITY_CAN_RX;
    g_mcmcan.canNodeConfig.interruptConfig.reint.interruptLine = IfxCan_InterruptLine_1;
    g_mcmcan.canNodeConfig.interruptConfig.reint.typeOfService = IfxSrc_Tos_cpu0;
    IfxCan_Can_initNode(&g_mcmcan.canDstNode, &g_mcmcan.canNodeConfig);
     * CAN filter configuration and initialization:
     *  - filter configuration is stored under the filter element number 0
     *  - store received frame in a dedicated RX Buffer
     *  - define the same message ID as defined for the TX message
     *  - assign the filter to the dedicated RX Buffer (RxBuffer0 in this case)
     *  - initialize the standard filter with the modified configuration
    g_mcmcan.canFilter.number = 0;
    g_mcmcan.canFilter.elementConfiguration = IfxCan_FilterElementConfiguration_storeInRxBuffer;
    g_mcmcan.canFilter.id1 = CAN_MESSAGE_ID;
    g_mcmcan.canFilter.rxBufferOffset = IfxCan_RxBufferId_0;
    IfxCan_Can_setStandardFilter(&g_mcmcan.canDstNode, &g_mcmcan.canFilter);
/* Function to initialize both TX and RX messages with the default data values.
* After initialization of the messages, the TX message is transmitted.
/* Function to initialize the LEDs */
void initLeds(void)
     * Configuration of the pins connected to the LEDs:
     *  - define the GPIO port
     *  - define the GPIO pin that is connected to the LED
     *  - define the general GPIO pin usage (no alternate function used)
     *  - define the pad driver strength
    g_led1.port      = &MODULE_P13;
    g_led1.pinIndex  = PIN0;
    g_led1.mode      = IfxPort_OutputIdx_general;
    g_led1.padDriver = IfxPort_PadDriver_cmosAutomotiveSpeed1;
    g_led2.port      = &MODULE_P13;
    g_led2.pinIndex  = PIN1;
    g_led2.mode      = IfxPort_OutputIdx_general;
    g_led2.padDriver = IfxPort_PadDriver_cmosAutomotiveSpeed1;
    /* Initialize the pins connected to LEDs to level "HIGH", which keep the LEDs turned off as default state */
    IfxPort_setPinHigh(g_led1.port, g_led1.pinIndex);
    IfxPort_setPinHigh(g_led2.port, g_led2.pinIndex);
    /* Set the pin input/output mode for both pins connected to the LEDs */
    IfxPort_setPinModeOutput(g_led1.port, g_led1.pinIndex, IfxPort_OutputMode_pushPull, g_led1.mode);
    IfxPort_setPinModeOutput(g_led2.port, g_led2.pinIndex, IfxPort_OutputMode_pushPull, g_led2.mode);
    /* Set the pad driver mode for both pins connected to the LEDs */
    IfxPort_setPinPadDriver(g_led1.port, g_led1.pinIndex, g_led1.padDriver);
    IfxPort_setPinPadDriver(g_led2.port, g_led2.pinIndex, g_led2.padDriver);
MCMCAN.h
* \file MCMCAN.h
* \copyright Copyright (C) Infineon Technologies AG 2019
版权声明:本文为CSDN博主「IOT-Power」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/a15236617777/article/details/131760947
tpgf 发表于 2024-1-19 18:11 | 显示全部楼层
现在大部分的芯片是不是都支持canfd了啊
heimaojingzhang 发表于 2024-1-19 18:47 | 显示全部楼层
如果芯片既有can也有canfd,那么如何确定使用的是哪种呢
guanjiaer 发表于 2024-1-19 21:01 | 显示全部楼层
二者之间的通讯速度相差多少呢
呈兴 发表于 2024-2-29 14:51 | 显示全部楼层
两个都可以用还是只能用这种呢?
