[嵌入式linux] 奇怪问题求助:linux视频子系统,为什么ioctl出错?
4091|5
 楼主| yyplc 发表于 2012-5-9 21:15 | 显示全部楼层 |阅读模式
今天写一个应用程序测试linux 视频子系统frame buffer设备,发现ioctl竟然出错,均返回-1,不知到为什么?
更奇怪的是,在内核端fb_ioctl加入printk调式,竟然也没有输出,说明用户程序ioctl的时候,根本不会执行fbioctl!!!
求助达人,指点一下linux菜鸟!
static const struct file_operations fb_fops = {
        .owner =        THIS_MODULE,
        .read =                fb_read,
        .write =        fb_write,
        .unlocked_ioctl = fb_ioctl,
#ifdef CONFIG_COMPAT
        .compat_ioctl = fb_compat_ioctl,
#endif
        .mmap =                fb_mmap,
        .open =                fb_open,
        .release =        fb_release,
#ifdef HAVE_ARCH_FB_UNMAPPED_AREA
        .get_unmapped_area = get_fb_unmapped_area,
#endif
#ifdef CONFIG_FB_DEFERRED_IO
        .fsync =        fb_deferred_io_fsync,
#endif
用户程序如下:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
//#include <sys/types.h>
#include <fcntl.h>
#include <linux/fb.h>
#include <sys/mman.h>
struct fb_var_screeninfo vinfo;
struct fb_fix_screeninfo finfo;
int main(void)
        int fd;
        int fbsize;
        unsigned char *fbbuf;
           char buf[10];
        int i,res,adc_data;
        if ((fd = open("/dev/fb0",O_RDWR)) < 0) {
            printf("open fb0 failed\n"undefined;
             return 1;
          if((res = ioctl(fd,FBIOGET_FSCREENINFO,&finfo)) == -1)
                printf("ERROR reading fixed information.error = %d\n",res);
        if ((res = ioctl(fd, FBIOGET_VSCREENINFO, &vinfo)) ==-1) {
                printf("bad vscreeninfo ioctl.error = %d\n",res);
        fbsize = vinfo.xres * vinfo.yres * (vinfo.bits_per_pixel/undefined;
        printf("fbisze: %d",fbsize);
        if ((fbbuf = mmap(0, fbsize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0)) == (void*) -1)
                printf("map video error.\n"undefined;
        for (i = 0; i< fbsize; i++) {
                *(fbbuf+i) = 0x0;
        munmap(fbbuf, fbsize);
        close(fd);
        return 0;
 楼主| yyplc 发表于 2012-5-9 21:18 | 显示全部楼层
其中:
static long fb_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
struct inode *inode = file->f_path.dentry->d_inode;
int fbidx = iminor(inode);
struct fb_info *info = registered_fb[fbidx];
printk("fb_ioctl....\n"); //这里加printk,但根本不会执行到这里!
return do_fb_ioctl(info, cmd, arg);
用户端调用流程应该是这样的:
用户ioctl() -->vfs_ioctl() -->fb_fops.unlocked_ioctl()
照理分析:fb_fops.unlocked_ioctl就是fb_ioctl的呀,但是printk调试跟踪,竟然没有进去
不知道跑哪了?
ycz9999 发表于 2012-5-9 22:13 | 显示全部楼层
前辈:
菜鸟有个问题想请教下您:
在学习字符设备的ioctl实现时  记得ioctl的驱动实现函数原型是:
int (*ioctl) (struct inode *, struct file *, unsigned int, unsigned long);
前辈的ioctl实现中只有3个参数,这样实现可行的吗?
我在自己的字符设备的ioctl实现中,去掉了那个struct inode *参数,结果编译出错了,还请前辈可以指点下~~~
 楼主| yyplc 发表于 2012-5-9 23:03 | 显示全部楼层
你用的ioctl是老式的,参数是有4个,用unlocked_ioctl就只有3个了。
你可以去看file_operations 结构体
ycz9999 发表于 2012-5-10 11:35 | 显示全部楼层
4# yyplc 嗯  好的  感谢前辈指点  我再去看下那个结构体  : )
 楼主| yyplc 发表于 2012-5-10 17:34 | 显示全部楼层
解决了
犯了一个及其低级的错误!
楼主位的程序改正了
