[N32WBxxx] 蓝牙模式下的ADC问题
865|1
 楼主| EdenLiu 发表于 2023-11-20 09:32 | 显示全部楼层 |阅读模式
蓝牙用的是rdtss例程,然后ADC部分参考的是\ADC\ADC_DMA例程。
描述:在“APP_BLE_OS_READY”之后初始化ADC,然后循环ns_timer_create一个20ms的任务,在里面打印ADC的值,发现打印的一直是0x0026,不会变化。
void RCC_Configuration_ADC(void)
    /* Enable peripheral clocks */
        RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_DMA, ENABLE);
    /* Enable GPIOB clocks */
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    /* Enable ADC clocks */
    RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_ADC, ENABLE);
    RCC_ConfigAdcClk(RCC_ADCCLK_SRC_HSE_DIV8);
* @brief  Configures the different GPIO ports.
void GPIO_Configuration_ADC(void)
    GPIO_InitType GPIO_InitStructure;
    GPIO_InitStruct(&GPIO_InitStructure);
    GPIO_InitStructure.Pin       = GPIO_PIN_8;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_ANALOG;
    GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
* @brief  DMA channel1 configuration
void DMA_Configuration_ADC(void)
        /* DMA channel1 configuration ----------------------------------------------*/
    DMA_DeInit(DMA_CH1);
    DMA_InitStructure.PeriphAddr     = (uint32_t)&ADC->DAT;
    DMA_InitStructure.MemAddr        = (uint32_t)&ADCConvertedValue;
    DMA_InitStructure.Direction      = DMA_DIR_PERIPH_SRC;
    DMA_InitStructure.BufSize        = 1;
    DMA_InitStructure.PeriphInc      = DMA_PERIPH_INC_DISABLE;
    DMA_InitStructure.DMA_MemoryInc  = DMA_MEM_INC_DISABLE;
    DMA_InitStructure.PeriphDataSize = DMA_PERIPH_DATA_SIZE_HALFWORD;
    DMA_InitStructure.MemDataSize    = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.CircularMode   = DMA_MODE_CIRCULAR;
    DMA_InitStructure.Priority       = DMA_PRIORITY_HIGH;
    DMA_InitStructure.Mem2Mem        = DMA_M2M_DISABLE;
    DMA_Init(DMA_CH1, &DMA_InitStructure);
        DMA_RequestRemap(DMA_REMAP_ADC, DMA, DMA_CH1, ENABLE);
    /* Enable DMA channel1 */
    DMA_EnableChannel(DMA_CH1, ENABLE);
        ADC_EnableBypassFilter(ADC, ENABLE);
        ADC_ConfigChannel(ADC, ADC_CTRL_CH_3);
        ADC_ConfigContinuousMode(ADC, ENABLE);
        ADC_EnableDMA(ADC, ENABLE);
        ADC_Enable(ADC, ENABLE);
void ADC_Configuration(void)
    RCC_Configuration_ADC();
    GPIO_Configuration_ADC();
    DMA_Configuration_ADC();
//20ms任务:采集一次ADC值、电量检测也一起放在这里
void APP_20MS_ADC_callback(void)
        uint8_t sdata[4];
        if(BLE_Connect_status == 1)
                sdata[0] = (uint8_t)(ADCConvertedValue[0]>>8);
                sdata[1] = (uint8_t)ADCConvertedValue[0];
                sdata[2] = 0x0d;
                sdata[3] = 0x0a;
                usart_tx_dma_send(sdata,4);
        ns_timer_create(20,APP_20MS_ADC_callback); //反复调用
 楼主| EdenLiu 发表于 2023-11-20 15:09 | 显示全部楼层
屏蔽了ns_sleep()也还是一样的效果
