[STM32F0]
请问stm32f0可不可以直接用i2c向外面按照协议格式一直发数据
396|10
jcky001|  楼主 | 2023-11-20 14:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
可不可以直接用i2c向外面按照协议格式一直发数据,需要有什么方面的配置。为什么我的配置之后只能发送地址信息,然后就结束了。。。。。小白求帮助。
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t TimingDelay;
RCC_ClocksTypeDef RCC_Clocks;
__IO uint16_t  sEEAddress = 0x44;
//__IO uint32_t  sEETimeout = sEE_LONG_TIMEOUT;
__IO uint16_t  sEEDataNum;
__IO uint32_t sEETimeout;
__IO uint32_t sEETrials = 0;
#define sEE_WRITE_ADDRESS1        0x00
#define sEE_READ_ADDRESS1         0x00
#define BUFFER_SIZE1             256
#define BUFFER_SIZE2             256
#define sEE_WRITE_ADDRESS2       (sEE_WRITE_ADDRESS1 + BUFFER_SIZE1)
#define sEE_READ_ADDRESS2        (sEE_READ_ADDRESS1 + BUFFER_SIZE1)
//状态变量
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void main(void)
  uint8_t senddata=0xa0;
  I2C_InitTypeDef I2C_InitStruct;
  // 配置I2C始终资源
  RCC_I2CCLKConfig(RCC_I2C1CLK_HSI);
  //GPIO使能
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  //IIC使能
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  //GPIO管脚配置
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_1);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_1;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOB,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_5;
                /* I2C configuration */
  I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStruct.I2C_AnalogFilter = I2C_AnalogFilter_Enable;
  I2C_InitStruct.I2C_DigitalFilter = 0x00;
  I2C_InitStruct.I2C_OwnAddress1 =0x00;
//  I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStruct.I2C_Ack = I2C_Ack_Disable;
  I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStruct.I2C_Timing =0x00210507;//100Kbits
  I2C_Init(I2C1, &I2C_InitStruct);
  //I2C_SMBusAlertCmd(I2C1,ENABLE);
  I2C_Cmd(I2C1, ENABLE);
while(1)
  I2C_TransferHandling(I2C1, sEEAddress, 2, I2C_Reload_Mode, I2C_Generate_Start_Write);
  I2C_SendData(I2C1,senddata);
  * @brief  Inserts a delay time.
  * @param  nTime: specifies the delay time length, in 10 ms.
  * @retval None
void Delay(__IO uint32_t nTime)
  TimingDelay = nTime;
  while(TimingDelay != 0);
  * @brief  Decrements the TimingDelay variable.
  * @param  None
  * @retval None
void TimingDelay_Decrement(void)
  if (TimingDelay != 0x00)
    TimingDelay--;
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
未说出口的像你| | 2023-12-18 15:20 | 只看该作者
就是你的I2C想当个主机?
我吃小朋友| | 2023-12-18 18:00 | 只看该作者
正常来说是可以输出数据的啊,用I2C
月亮一键变蓝| | 2023-12-18 20:00 | 只看该作者
没啥问题,直接使用就可以了
她已醉| | 2023-12-18 22:00 | 只看该作者
我觉得发数据没问题,主要是注意时序的
春日负喧| | 2023-12-19 02:00 | 只看该作者
能发送地址信息,之后是不是哪里配置错啦
一只眠羊| | 2023-12-19 04:00 | 只看该作者
看看你的那几个数据引脚,看看其状态,是什么
故意相遇| | 2023-12-19 06:00 | 只看该作者
你用逻辑分析仪抓一下波形就好了,好知道怎么回事
西洲| | 2023-12-19 08:00 | 只看该作者
那说明你的时序还是错的
捧一束彼岸花| | 2023-12-19 10:00 | 只看该作者
你用的是硬件I2C,不应该出现时序错误的
白马过平川| | 2023-12-19 15:00 | 只看该作者
建议还是看看你的I2C配置,还有你是不是应答也要配置OK啊
