ADC怎么用?
538|0
 楼主| 34af9uc 发表于 2023-12-4 23:36 | 显示全部楼层 |阅读模式
unsigned int cewen()
unsigned int cewen_a1;
GO                =1;
NOP();
NOP();
while(nDONE){NOP();NOP();}
NOP();NOP();NOP();
NOP();NOP();NOP();
NOP();NOP();NOP();
cewen_a1                =ADRESH;
cewen_a1                <<=8;
cewen_a1                |=ADRESL;
return cewen_a1;
void cewen_chushihua()
TRISA7                =1;                        //PA7输入模式
ANSELA                =1<<4;                //第四路
//ADRESL                        //ADC 转换结果低有效位 (LSB)
//ADRESH                        //ADC 转换结果高有效位 (MSB)
ADCEN                =1;                //ADC 模块时钟
CHS2                =1;                //100 = AN4
CHS1                =0;
CHS0                =0;
ADEX                =0;                //由指令置位 GO/DONE (软件触发)
//GO/DONE                        //启动 A/D 转换
ADON                =1;                //ADC 使能
ADFM                =1;                //右对齐
ADCS2                =1;                //100 = SysClk/4
ADCS1                =0;
ADCS0                =0;
ADNREF1                =0;                //负参考电压01 = GND
ADNREF0                =1;
ADPREF1                =0;                //正参考电01 = VDD
ADPREF0                =1;
ADPREF1                =0;                //正参考电压00 = 内部 V ADC-REF
ADPREF0                =0;
ADINTREF1        =1;                //10 = 3.0V
ADINTREF0        =0;
319
