[N32G430] SPI硬件NSS无输出,空闲状态已经设置为高
829|1
 楼主| 地瓜ing 发表于 2023-12-13 23:21 | 显示全部楼层 |阅读模式
在调试SPI的过程中遇到使用硬件NSS时,对应的IO没有输出的问题,以下是相应代码
PA15作为SPI1的硬件NSS引脚一直输出低电平,AFIO中SPI1的NSS空闲状态已经设置为高电平了,还是一直输出低电平
以下是初始化程序
void Spi1GpioConfig()
    GPIO_InitType GPIO_InitStructure;
    /* Initialize GPIO_InitStructure */
    GPIO_Structure_Initialize(&GPIO_InitStructure);
    RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA|RCC_AHB_PERIPH_GPIOB);
    RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_AFIO);
    GPIO_InitStructure.Pin        = GPIO_PIN_3 | GPIO_PIN_4 ;//PB3->SCK,PB4->MISO
    GPIO_InitStructure.GPIO_Mode  = GPIO_MODE_AF_PP;
    GPIO_InitStructure.GPIO_Slew_Rate = GPIO_SLEW_RATE_FAST;
    GPIO_InitStructure.GPIO_Alternate = GPIO_AF2_SPI1;
    GPIO_Peripheral_Initialize(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.Pin        = GPIO_PIN_5 ;                                                //PB5->MOSI
    GPIO_InitStructure.GPIO_Alternate = GPIO_AF1_SPI1;
    GPIO_InitStructure.Pin                                = GPIO_PIN_15 ;                                                //PA15->NSS
    GPIO_Peripheral_Initialize(GPIOA, &GPIO_InitStructure);
    AFIO_SPI_NSS_Mode_Set(AFIO_SPI1_NSS, AFIO_SPI_NSS_High_LEVEL);//NSS空闲时的电平
void Spi1_Init ( void )
        SPI_InitType SPI_InitStructure;
        SPI_I2S_Reset(SPI1);
        Spi1GpioConfig();
        RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_SPI1);
/* SPI_MASTER configuration ------------------------------------------------------*/
  SPI_Initializes_Structure(&SPI_InitStructure);
  SPI_InitStructure.DataDirection = SPI_DIR_DOUBLELINE_FULLDUPLEX;
  SPI_InitStructure.SpiMode       = SPI_MODE_MASTER;
  SPI_InitStructure.DataLen       = SPI_DATA_SIZE_8BITS;
  SPI_InitStructure.CLKPOL        = SPI_CLKPOL_HIGH;
  SPI_InitStructure.CLKPHA        = SPI_CLKPHA_SECOND_EDGE;
  SPI_InitStructure.NSS           = SPI_NSS_HARD;
  /* It is recommended that the SPI master mode of the C version chips should not exceed 18MHz */
  SPI_InitStructure.BaudRatePres  = SPI_BR_PRESCALER_32;
  SPI_InitStructure.FirstBit      = SPI_FB_MSB;
  SPI_InitStructure.CRCPoly       = 7;
  SPI_Initializes(SPI1, &SPI_InitStructure);
  SPI_SS_Output_Enable(SPI1);
  SPI_ON(SPI1);
以下是主循环中的测试部分
        while(1)
                if(Task_TimeFlag_ms(1,100))
                        //100ms运行一次
                        Run();
//                  SPI_Set_Nss_Level(SPI1, SPI_NSS_LOW);
                        SPI_I2S_Data_Transmit(SPI1, 0x5A);
                        Delay_Us(100);
                        SPI_I2S_Data_Transmit(SPI1, 0xA5);
//                  SPI_Set_Nss_Level(SPI1, SPI_NSS_HIGH);
                        LED_TOGGLE;
 楼主| 地瓜ing 发表于 2023-12-14 21:17 | 显示全部楼层
有没有哪位大神帮忙分析一下问题呀
