- /* Includes ------------------------------------------------------------------*/
- #include "fdcan.h"
- /* USER CODE BEGIN 0 */
- #include<stdio.h>
- #include<string.h>
- FDCAN_TxHeaderTypeDef fdcan_TxHeader;
- /* USER CODE END 0 */
- FDCAN_HandleTypeDef hfdcan1;
- FDCAN_HandleTypeDef hfdcan2;
- /* FDCAN1 init function */
- void MX_FDCAN1_Init(void)
- /* USER CODE BEGIN FDCAN1_Init 0 */
- /* USER CODE END FDCAN1_Init 0 */
- /* USER CODE BEGIN FDCAN1_Init 1 */
- /* USER CODE END FDCAN1_Init 1 */
- hfdcan1.Instance = FDCAN1;
- hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
- hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
- hfdcan1.Init.AutoRetransmission = DISABLE;
- hfdcan1.Init.TransmitPause = DISABLE;
- hfdcan1.Init.ProtocolException = DISABLE;
- hfdcan1.Init.NominalPrescaler = 1;
- hfdcan1.Init.NominalSyncJumpWidth = 1;
- hfdcan1.Init.NominalTimeSeg1 = 15;
- hfdcan1.Init.NominalTimeSeg2 = 4;
- hfdcan1.Init.DataPrescaler = 1;
- hfdcan1.Init.DataSyncJumpWidth = 1;
- hfdcan1.Init.DataTimeSeg1 = 0xF;
- hfdcan1.Init.DataTimeSeg2 = 0x4;
- hfdcan1.Init.MessageRAMOffset = 0;
- hfdcan1.Init.StdFiltersNbr = 1;
- hfdcan1.Init.ExtFiltersNbr = 0;
- hfdcan1.Init.RxFifo0ElmtsNbr = 32;
- hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
- hfdcan1.Init.RxFifo1ElmtsNbr = 0;
- hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
- hfdcan1.Init.RxBuffersNbr = 0;
- hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
- hfdcan1.Init.TxEventsNbr = 0;
- hfdcan1.Init.TxBuffersNbr = 0;
- hfdcan1.Init.TxFifoQueueElmtsNbr = 6;
- hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
- hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
- if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN FDCAN1_Init 2 */
- printf("%lx\r\n",SRAMCAN_BASE);
- printf("%x\r\n",hfdcan1.msgRam.EndAddress);
- FDCAN1_RX_Filter_Init();
- HAL_FDCAN_Start(&hfdcan1);
- /* USER CODE END FDCAN1_Init 2 */
- /* FDCAN2 init function */
- void MX_FDCAN2_Init(void)
- /* USER CODE BEGIN FDCAN2_Init 0 */
- /* USER CODE END FDCAN2_Init 0 */
- /* USER CODE BEGIN FDCAN2_Init 1 */
- /* USER CODE END FDCAN2_Init 1 */
- hfdcan2.Instance = FDCAN2;
- hfdcan2.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
- hfdcan2.Init.Mode = FDCAN_MODE_NORMAL;
- hfdcan2.Init.AutoRetransmission = DISABLE;
- hfdcan2.Init.TransmitPause = DISABLE;
- hfdcan2.Init.ProtocolException = DISABLE;
- hfdcan2.Init.NominalPrescaler = 1;
- hfdcan2.Init.NominalSyncJumpWidth = 1;
- hfdcan2.Init.NominalTimeSeg1 = 15;
- hfdcan2.Init.NominalTimeSeg2 = 4;
- hfdcan2.Init.DataPrescaler = 1;
- hfdcan2.Init.DataSyncJumpWidth = 1;
- hfdcan2.Init.DataTimeSeg1 = 15;
- hfdcan2.Init.DataTimeSeg2 = 4;
- hfdcan2.Init.MessageRAMOffset = 0x406;
- hfdcan2.Init.StdFiltersNbr = 1;
- hfdcan2.Init.ExtFiltersNbr = 0;
- hfdcan2.Init.RxFifo0ElmtsNbr = 0;
- hfdcan2.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
- hfdcan2.Init.RxFifo1ElmtsNbr = 32;
- hfdcan2.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
- hfdcan2.Init.RxBuffersNbr = 0;
- hfdcan2.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
- hfdcan2.Init.TxEventsNbr = 0;
- hfdcan2.Init.TxBuffersNbr = 0;
- hfdcan2.Init.TxFifoQueueElmtsNbr = 6;
- hfdcan2.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
- hfdcan2.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
- if (HAL_FDCAN_Init(&hfdcan2) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN FDCAN2_Init 2 */
- FDCAN2_RX_Filter_Init();
- HAL_FDCAN_Start(&hfdcan2);
- /* USER CODE END FDCAN2_Init 2 */
- static uint32_t HAL_RCC_FDCAN_CLK_ENABLED=0;
- void HAL_FDCAN_MspInit(FDCAN_HandleTypeDef* fdcanHandle)
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- if(fdcanHandle->Instance==FDCAN1)
- /* USER CODE BEGIN FDCAN1_MspInit 0 */
- /* USER CODE END FDCAN1_MspInit 0 */
- /* FDCAN1 clock enable */
- HAL_RCC_FDCAN_CLK_ENABLED++;
- if(HAL_RCC_FDCAN_CLK_ENABLED==1){
- __HAL_RCC_FDCAN_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /**FDCAN1 GPIO Configuration
- PA11 ------> FDCAN1_RX
- PA12 ------> FDCAN1_TX
- GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN1;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /* FDCAN1 interrupt Init */
- HAL_NVIC_SetPriority(FDCAN1_IT0_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(FDCAN1_IT0_IRQn);
- /* USER CODE BEGIN FDCAN1_MspInit 1 */
- /* USER CODE END FDCAN1_MspInit 1 */
- else if(fdcanHandle->Instance==FDCAN2)
- /* USER CODE BEGIN FDCAN2_MspInit 0 */
- /* USER CODE END FDCAN2_MspInit 0 */
- /* FDCAN2 clock enable */
- __HAL_RCC_GPIOB_CLK_ENABLE();
- /**FDCAN2 GPIO Configuration
- PB12 ------> FDCAN2_RX
- PB6 ------> FDCAN2_TX
- GPIO_InitStruct.Pin = GPIO_PIN_12;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN2;
- HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = GPIO_PIN_6;
- /* FDCAN2 interrupt Init */
- HAL_NVIC_SetPriority(FDCAN2_IT0_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(FDCAN2_IT0_IRQn);
- /* USER CODE BEGIN FDCAN2_MspInit 1 */
- /* USER CODE END FDCAN2_MspInit 1 */
- void HAL_FDCAN_MspDeInit(FDCAN_HandleTypeDef* fdcanHandle)
- /* USER CODE BEGIN FDCAN1_MspDeInit 0 */
- /* USER CODE END FDCAN1_MspDeInit 0 */
- /* Peripheral clock disable */
- HAL_RCC_FDCAN_CLK_ENABLED--;
- if(HAL_RCC_FDCAN_CLK_ENABLED==0){
- __HAL_RCC_FDCAN_CLK_DISABLE();
- HAL_GPIO_DeInit(GPIOA, GPIO_PIN_11|GPIO_PIN_12);
- /* FDCAN1 interrupt Deinit */
- HAL_NVIC_DisableIRQ(FDCAN1_IT0_IRQn);
- /* USER CODE BEGIN FDCAN1_MspDeInit 1 */
- /* USER CODE END FDCAN1_MspDeInit 1 */
- /* USER CODE BEGIN FDCAN2_MspDeInit 0 */
- /* USER CODE END FDCAN2_MspDeInit 0 */
- HAL_GPIO_DeInit(GPIOB, GPIO_PIN_12|GPIO_PIN_6);
- /* FDCAN2 interrupt Deinit */
- HAL_NVIC_DisableIRQ(FDCAN2_IT0_IRQn);
- /* USER CODE BEGIN FDCAN2_MspDeInit 1 */
- /* USER CODE END FDCAN2_MspDeInit 1 */
- /* USER CODE BEGIN 1 */
- * 函数功能: 设置并初始化滤波器0,供FDCAN1使用
- * 输入参数: void
- * 返回值: void
- void FDCAN1_RX_Filter_Init(void)
- FDCAN_FilterTypeDef hfdcan1_RX_Filter; /* FDCAN1滤波器0对象句柄 */
- hfdcan1_RX_Filter.IdType = FDCAN_STANDARD_ID; /* 只接收标准帧ID */
- hfdcan1_RX_Filter.FilterIndex = 0; /* 滤波器索引0 */
- hfdcan1_RX_Filter.FilterType = FDCAN_FILTER_MASK; /* 滤波器类型 */
- hfdcan1_RX_Filter.FilterConfig = FDCAN_FILTER_TO_RXFIFO0; /* 滤波器关联到RXFIFO0 */
- hfdcan1_RX_Filter.FilterID1 = 0x111; /* 滤波ID1: 0x00 */
- hfdcan1_RX_Filter.FilterID2 = 0x7FF; /* 滤波ID2: 0x00 */
- HAL_FDCAN_ConfigFilter(&hfdcan1,&hfdcan1_RX_Filter); /* 看看滤波器有没有创建成功 */
- /* HAL_FDCAN_ConfigGlobalFilter()
- * 参数2:设置标准帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收(没有匹配上时,可以选择放入FIFO0或者FIFO1)。
- * 参数3:设置拓展帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收。
- * 参数4:设置是否拒绝远程标准帧,ENABLE代表拒绝接收。
- * 参数5:设置是否拒绝远程拓展帧,ENABLE代表拒绝接收。
- HAL_FDCAN_ConfigGlobalFilter(&hfdcan1,FDCAN_REJECT,FDCAN_REJECT,DISABLE,ENABLE); /* 设置FDCAN1滤波器0全局配置 */
- HAL_FDCAN_ActivateNotification(&hfdcan1,FDCAN_IT_RX_FIFO0_NEW_MESSAGE,0);
- * 函数功能: 设置并初始化滤波器1,供FDCAN2使用
- * 输入参数: void
- * 返回值: void
- void FDCAN2_RX_Filter_Init(void)
- FDCAN_FilterTypeDef hfdcan2_RX_Filter; /* FDCAN2滤波器0对象句柄 */
- hfdcan2_RX_Filter.IdType = FDCAN_STANDARD_ID; /* 只接收标准帧ID */
- hfdcan2_RX_Filter.FilterIndex = 0; /* 滤波器索引0 */
- hfdcan2_RX_Filter.FilterType = FDCAN_FILTER_MASK; /* 滤波器类型(允许接收报文的ID范围是FilterID1至FilterID2 */
- hfdcan2_RX_Filter.FilterConfig = FDCAN_FILTER_TO_RXFIFO1; /* 滤波器关联到RXFIFO1 */
- hfdcan2_RX_Filter.FilterID1 = 0x111; /* 滤波ID1: 0x00 */
- hfdcan2_RX_Filter.FilterID2 = 0x7FF; /* 滤波ID2: 0x00 */
- HAL_FDCAN_ConfigFilter(&hfdcan2,&hfdcan2_RX_Filter); /* 看看滤波器有没有创建成功 */
- HAL_FDCAN_ConfigGlobalFilter(&hfdcan2,FDCAN_REJECT,FDCAN_REJECT,DISABLE,ENABLE); /* 设置FDCAN1滤波器1全局配置 */
- HAL_FDCAN_ActivateNotification(&hfdcan2,FDCAN_IT_RX_FIFO1_NEW_MESSAGE,0);
- * 函数功能: FDCAN2启动
- * 输入参数: uint8_t canordernumber CAN1 为1 CAN2为2
- * 输入参数: uint8_t sendcanid 发送数据的canid
- * 输入参数: uint8_t* msg 发送数据的数组
- * 输入参数: uint32_t len 发送数据的长度
- * 返回值: uint8_t 成功返回数据1 失败返回数据0
- * 说明:
- uint8_t FDCAN_Send_Msg(uint8_t canordernumber,uint32_t sendcanid,uint8_t* msg,uint32_t len)
- static uint8_t msgdata[10]={0};
- memcpy(msgdata,msg,len);
- fdcan_TxHeader.Identifier=sendcanid; //32位ID
- fdcan_TxHeader.IdType=FDCAN_STANDARD_ID; //标准ID
- fdcan_TxHeader.TxFrameType=FDCAN_DATA_FRAME; //数据帧
- fdcan_TxHeader.DataLength=FDCAN_DLC_BYTES_8; //数据长度
- fdcan_TxHeader.ErrorStateIndicator=FDCAN_ESI_ACTIVE;
- fdcan_TxHeader.BitRateSwitch=FDCAN_BRS_OFF; //关闭速率切换
- fdcan_TxHeader.FDFormat=FDCAN_CLASSIC_CAN; //传统的CAN模式
- fdcan_TxHeader.TxEventFifoControl=FDCAN_NO_TX_EVENTS; //无发送事件
- fdcan_TxHeader.MessageMarker=0;
- if(canordernumber==1)
- if(HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan1,&fdcan_TxHeader,msgdata)!=HAL_OK) return 1;//发送
- else if(canordernumber==2)
- if(HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan2,&fdcan_TxHeader,msgdata)!=HAL_OK) return 1;//发送
- return 0;
- * 函数功能: FIFO0的接收中断回调函数
- * 输入参数: RxFifo0ITs:返回标志位
- * 返回值: void
- * 说明:
- * 1.FDCAN1使用RXFIFO0
- void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs)
- uint8_t i=0;
- uint8_t rxdata[8];
- FDCAN_RxHeaderTypeDef FDCAN1_RxHeader;
- if((RxFifo0ITs&FDCAN_IT_RX_FIFO0_NEW_MESSAGE)!=RESET) //FIFO0新数据中断
- //提取FIFO0中接收到的数据
- HAL_FDCAN_GetRxMessage(hfdcan,FDCAN_RX_FIFO0,&FDCAN1_RxHeader,rxdata);
- printf("id:%#x\r\n",FDCAN1_RxHeader.Identifier);
- printf("len:%d\r\n",FDCAN1_RxHeader.DataLength>>16);
- for(i=0;i<8;i++)
- printf("rxdata[%d]:%d\r\n",i,rxdata[i]);
- FDCAN_Send_Msg(1,FDCAN1_RxHeader.Identifier,rxdata,8);
- * 函数功能: FIFO1的接收中断回调函数
- * 返回值: void
- * 说明:
- * 1、FDCAN2使用RXFIFO1
- void HAL_FDCAN_RxFifo1Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo1ITs)
- uint8_t i=0;
- FDCAN_RxHeaderTypeDef FDCAN2_RxHeader;
- if((RxFifo1ITs&FDCAN_IT_RX_FIFO1_NEW_MESSAGE)!=RESET) //FIFO1新数据中断
- //提取FIFO0中接收到的数据
- HAL_FDCAN_GetRxMessage(hfdcan,FDCAN_RX_FIFO1,&FDCAN2_RxHeader,rxdata);
- printf("id:%#x\r\n",FDCAN2_RxHeader.Identifier);
- printf("len:%d\r\n",FDCAN2_RxHeader.DataLength>>16);
- for(i=0;i<8;i++)
- FDCAN_Send_Msg(2,FDCAN2_RxHeader.Identifier,rxdata,8);
- /* USER CODE END 1 */
