[技术问答] Winbond W25Q256FV无法擦除写入
426|1
 楼主| 两只袜子 发表于 2023-12-21 15:54 | 显示全部楼层 |阅读模式
riplay 发表于 2023-12-25 09:51 | 显示全部楼层
通过读取status register2 判断是否CMP被设置为1
UINT8 usiStatus2Read()
    uint8_t volatile u8Val;
    QSPI_ClearRxFIFO(QSPI_FLASH_PORT);
    // /CS: active
    QSPI_SET_SS_LOW(QSPI_FLASH_PORT);
    // send Command: 0x05, Read status register
    QSPI_WRITE_TX(QSPI_FLASH_PORT, 0x35);
    // wait tx finish
    usiActive();
    // read status
    QSPI_WRITE_TX(QSPI_FLASH_PORT, 0x00);
    // wait tx finish
    usiActive();
    // /CS: de-active
    QSPI_SET_SS_HIGH(QSPI_FLASH_PORT);
    // skip first rx data
    u8Val = QSPI_READ_RX(QSPI_FLASH_PORT);
    return u8Val;
若设置为1,通过指令改写status register 2
int usiStatusWrite(UINT8 data)
    // Write enable
    usiWriteEnable();
    // /CS: active
    // send Command: 0x01, Write status register
    QSPI_WRITE_TX(QSPI_FLASH_PORT, 0x01);
    // wait tx finish
    usiActive();
    // write status
    QSPI_WRITE_TX(QSPI_FLASH_PORT, data);
    // wait tx finish
    usiActive();
  // write status 2
    QSPI_WRITE_TX(QSPI_FLASH_PORT, 0x02);
    // wait tx finish
    usiActive();
    // /CS: de-active
    return Successful;
