[DemoCode下载] CRC使用库函数很容易
435|1
 楼主| 643757107 发表于 2023-12-24 22:31 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 2 $
  5. * $Date: 20/05/28 4:41p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Implement CRC in CRC-8 mode and get the CRC checksum result.
  7. *
  8. * SPDX-License-Identifier: Apache-2.0
  9. * Copyright (C) 2020 Nuvoton Technology Corp. All rights reserved.
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "NuMicro.h"
  13. void SYS_Init(void)
  14. {
  15.     /* Unlock protected registers */
  16.     SYS_UnlockReg();
  17.     /* Enable HIRC clock */
  18.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  19.     /* Waiting for HIRC clock ready */
  20.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  21.     /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
  22.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  23.     /* Enable UART0 clock */
  24.     CLK_EnableModuleClock(UART0_MODULE);
  25.     /* Switch UART0 clock source to HIRC */
  26.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
  27.     /* Enable CRC clock */
  28.     CLK_EnableModuleClock(CRC_MODULE);
  29.     /* Update System Core Clock */
  30.     SystemCoreClockUpdate();
  31.     /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
  32.     SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk))
  33.                     |(SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  34.     /* Lock protected registers */
  35.     SYS_LockReg();
  36. }
  37. /*---------------------------------------------------------------------------------------------------------*/
  38. /*  MAIN function        */
  39. /*---------------------------------------------------------------------------------------------------------*/
  40. int main(void)
  41. {
  42.     const uint8_t acCRCSrcPattern[] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
  43.     uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
  44.     /* Unlock protected registers */
  45.     SYS_UnlockReg();
  46.     /* Init System, peripheral clock and multi-function I/O */
  47.     SYS_Init();
  48.     /* Lock protected registers */
  49.     SYS_LockReg();
  50.     /* Init UART0 to 115200-8n1 for print message */
  51.     UART_Open(UART0, 115200);
  52.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  53.     printf("+-----------------------------------------+\n");
  54.     printf("|    CRC-8 Polynomial Mode Sample Code    |\n");
  55.     printf("+-----------------------------------------+\n\n");
  56.     printf("# Calculate [0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39] CRC-8 checksum value.\n");
  57.     printf("    - Seed value is 0x5A             \n");
  58.     printf("    - CPU write data length is 8-bit \n");
  59.     printf("    - Checksum complement disable    \n");
  60.     printf("    - Checksum reverse disable       \n");
  61.     printf("    - Write data complement disable  \n");
  62.     printf("    - Write data reverse disable     \n");
  63.     printf("    - Checksum should be 0x%X        \n\n", u32TargetChecksum);
  64.     /* Configure CRC controller for CRC-8 CPU mode */
  65.     CRC_Open(CRC_8, 0, 0x5A, CRC_WDATA_8);
  66.     /* Start to execute CRC-8 CPU operation */
  67.     for(i = 0; i < sizeof(acCRCSrcPattern); i++)
  68.     {
  69.         CRC_WRITE_DATA(acCRCSrcPattern[i]);
  70.     }
  71.     /* Get CRC-8 checksum value */
  72.     u32CalChecksum = CRC_GetChecksum();
  73.     printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
  74.     /* Disable CRC function */
  75.     CLK_DisableModuleClock(CRC_MODULE);
  76.     while(1);
  77. }
  78. /*** (C) COPYRIGHT 2020 Nuvoton Technology Corp. ***/
 楼主| 643757107 发表于 2023-12-24 22:32 | 显示全部楼层
使用库函数不用纠结背后的秘密。
