[DemoCode下载]
M031单片机485接口使用示例
572|2
xinxianshi|  楼主 | 2023-12-26 11:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    Transmit and receive data in UART RS485 mode.
* SPDX-License-Identifier: Apache-2.0
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2017 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define PLL_CLOCK   FREQ_96MHZ
#define RXBUFSIZE 1024
#define IS_USE_RS485NMM   1      //1:Select NMM_Mode , 0:Select AAD_Mode
#define MATCH_ADDRSS1     0xC0
#define MATCH_ADDRSS2     0xA2
#define UNMATCH_ADDRSS1   0xB1
#define UNMATCH_ADDRSS2   0xD3
/* Global variables        */
uint8_t g_u8SendData[12] = {0};
/* Define functions prototype        */
void RS485_HANDLE(void);
void RS485_SendAddressByte(uint8_t u8data);
void RS485_SendDataByte(uint8_t *pu8TxBuf, uint32_t u32WriteBytes);
void RS485_9bitModeMaster(void);
void RS485_9bitModeSlave(void);
void RS485_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set both PCLK0 and PCLK1 as HCLK */
    CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV1 | CLK_PCLKDIV_APB1DIV_DIV1;
    /* Enable UART0 peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable UART1 peripheral clock */
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select IP clock source */
    /* Select UART0 clock source is HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Select UART1 clock source is HIRC */
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART1SEL_HIRC, CLK_CLKDIV0_UART1(1));
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk))    |       \
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set PA multi-function pins for UART1 TXD, RXD and RTS */
    SYS->GPA_MFPL = (SYS->GPA_MFPL & ~(SYS_GPA_MFPL_PA0MFP_Msk | SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk)) |   \
                    (SYS_GPA_MFPL_PA0MFP_UART1_nRTS | SYS_GPA_MFPL_PA2MFP_UART1_RXD | SYS_GPA_MFPL_PA3MFP_UART1_TXD);
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init()
    /* Init UART        */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 */
    UART1_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+------------------------+\n");
    printf("| RS485 function test     |\n");
    RS485_FunctionTest();
    while (1);
/* ISR to handle UART Channel 1 interrupt event                                                            */
void UART13_IRQHandler(void)
    RS485_HANDLE();
/* RS485 Callback function        */
void RS485_HANDLE()
    volatile uint32_t addr = 0;
    volatile uint32_t regRX = 0xFF;
    volatile uint32_t u32IntSts = UART1->INTSTS;
    if (UART_GET_INT_FLAG(UART1,UART_INTSTS_RLSINT_Msk ) && UART_GET_INT_FLAG(UART1, UART_INTSTS_RDAINT_Msk))       /* RLS INT & RDA INT */ //For RS485 Detect Address
        if (UART_RS485_GET_ADDR_FLAG(UART1))   /* ADD_IF, RS485 mode */
            addr = UART_READ(UART1);
            UART_RS485_CLEAR_ADDR_FLAG(UART1);        /* clear ADD_IF flag */
            printf("\nAddr=0x%x,Get:", addr);
#if (IS_USE_RS485NMM ==1) //RS485_NMM
            /* if address match, enable RX to receive data, otherwise to disable RX. */
            /* In NMM mode,user can decide multi-address filter. In AAD mode,only one address can set */
            if ((addr == MATCH_ADDRSS1) || (addr == MATCH_ADDRSS2))
                UART1->FIFO &= ~ UART_FIFO_RXOFF_Msk;  /* Enable RS485 RX */
            else
                UART1->FIFO |= UART_FIFO_RXOFF_Msk;      /* Disable RS485 RX */
                UART1->FIFO |= UART_FIFO_RXRST_Msk;      /* Clear data from RX FIFO */
                printf("\n");
#endif
    else if (UART_GET_INT_FLAG(UART1,UART_INTSTS_RDAINT_Msk ) || UART_GET_INT_FLAG(UART1,UART_INTSTS_RXTOINT_Msk ))     /* Rx Ready or Time-out INT*/
        /* Handle received data */
        while (!UART_GET_RX_EMPTY(UART1))
            printf("%2d,", UART_READ(UART1));
    else if (UART_GET_INT_FLAG(UART1,UART_INTSTS_BUFERRINT_Msk ))     /* Buffer Error INT */
        printf("\nBuffer Error...\n");
        UART_ClearIntFlag(UART1, UART_INTSTS_BUFERRINT_Msk);
/*  RS485 Transmit Control  (Address Byte: Parity Bit =1 , Data Byte:Parity Bit =0)                        */
    UART_SetLine_Config(UART1, 0, UART_WORD_LEN_8, UART_PARITY_MARK, UART_STOP_BIT_1);
    UART_WRITE(UART1, u8data);
    UART_SetLine_Config(UART1, 0, UART_WORD_LEN_8, UART_PARITY_SPACE, UART_STOP_BIT_1);
    UART_Write(UART1, pu8TxBuf, u32WriteBytes);
/*  RS485 Transmit Test        */
void RS485_9bitModeMaster()
    int32_t i32;
    uint8_t g_u8SendDataGroup1[10] = {0};
    uint8_t g_u8SendDataGroup2[10] = {0};
    uint8_t g_u8SendDataGroup3[10] = {0};
    uint8_t g_u8SendDataGroup4[10] = {0};
    printf("\n\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|               RS485 9-bit Master Test                     |\n");
    printf("| The function will send different address with 10 data bytes|\n");
    printf("| to test RS485 9-bit mode. Please connect TX/RX to another |\n");
    printf("| board and wait its ready to receive.                      |\n");
    printf("| Press any key to start...                                 |\n");
    printf("+-----------------------------------------------------------+\n\n");
    getchar();
    /* Set RS485-Master as AUD mode*/
    UART_SelectRS485Mode(UART1, UART_ALTCTL_RS485AUD_Msk, 0);
    UART1->MODEM &= ~UART_MODEM_RTSACTLV_Msk;
    /* Prepare Data to transmit*/
    for (i32 = 0; i32 < 10; i32++)
        g_u8SendDataGroup1[i32] = i32;
        g_u8SendDataGroup2[i32] = i32 + 10;
        g_u8SendDataGroup3[i32] = i32 + 20;
        g_u8SendDataGroup4[i32] = i32 + 30;
    /* Send For different Address and data for test */
    printf("Send Address %x and data 0~9\n", MATCH_ADDRSS1);
    RS485_SendAddressByte(MATCH_ADDRSS1);
    RS485_SendDataByte(g_u8SendDataGroup1, 10);
    // getchar();
    printf("Send Address %x and data 10~19\n", UNMATCH_ADDRSS1);
    RS485_SendAddressByte(UNMATCH_ADDRSS1);
    RS485_SendDataByte(g_u8SendDataGroup2, 10);
    // getchar();
    printf("Send Address %x and data 20~29\n", MATCH_ADDRSS2);
    RS485_SendAddressByte(MATCH_ADDRSS2);
    RS485_SendDataByte(g_u8SendDataGroup3, 10);
    //  getchar();
    printf("Send Address %x and data 30~39\n", UNMATCH_ADDRSS2);
    RS485_SendAddressByte(UNMATCH_ADDRSS2);
    RS485_SendDataByte(g_u8SendDataGroup4, 10);
    printf("Transfer Done\n");
/*  RS485 Receive Test  (IS_USE_RS485NMM: 0:AAD  1:NMM)                                                    */
void RS485_9bitModeSlave()
    /* Set Data Format*/ /* Only need parity enable whenever parity ODD/EVEN */
    UART_SetLine_Config(UART1, 0, UART_WORD_LEN_8, UART_PARITY_EVEN, UART_STOP_BIT_1);
    /* Set RX Trigger Level = 1 */
    UART1->FIFO &= ~UART_FIFO_RFITL_Msk;
    UART1->FIFO |= UART_FIFO_RFITL_1BYTE;
    /* Set RTS pin active level as High level active */
    UART1->MODEM |= UART_RTS_IS_HIGH_LEV_ACTIVE;
#if(IS_USE_RS485NMM == 1)
    printf("|    Normal Multidrop Operation Mode                        |\n");
    printf("| The function is used to test 9-bit slave mode.            |\n");
    printf("| Only Address %2x and %2x,data can receive                  |\n", MATCH_ADDRSS1, MATCH_ADDRSS2);
    /* Set RX_DIS enable before set RS485-NMM mode */
    /* Set RS485-NMM Mode */
    UART_SelectRS485Mode(UART1, UART_ALTCTL_RS485NMM_Msk | UART_ALTCTL_ADDRDEN_Msk | UART_ALTCTL_RS485AUD_Msk, 0);
#else
    printf("Auto Address Match Operation Mode\n");
    printf("|    Auto Address Match Operation Mode                      |\n");
    printf("|Only Address %2x,data can receive                          |\n", MATCH_ADDRSS1);
    /* Set RS485-AAD Mode and address match is 0xC0 */
    UART_SelectRS485Mode(UART1, UART_ALTCTL_RS485AAD_Msk | UART_ALTCTL_ADDRDEN_Msk | UART_ALTCTL_RS485AUD_Msk, MATCH_ADDRSS1);
#endif
    /* Enable RDA\RLS\Time-out Interrupt  */
    UART_ENABLE_INT(UART1, (UART_INTEN_RDAIEN_Msk | UART_INTEN_RLSIEN_Msk | UART_INTEN_RXTOIEN_Msk));
    NVIC_EnableIRQ(UART13_IRQn);
    printf("Ready to receive data...(Press any key to stop test)\n");
    getchar();
    /* Flush FIFO */
    while (UART_GET_RX_EMPTY(UART1) == 0)
        UART_READ(UART1);
    UART_DISABLE_INT(UART1, (UART_INTEN_RDAIEN_Msk | UART_INTEN_RLSIEN_Msk | UART_INTEN_RXTOIEN_Msk));
    /* Set UART Function */
    printf("\n\nEnd test\n");
/*  RS485 Function Test        */
void RS485_FunctionTest()
    uint32_t u32Item;
    printf("\n\n");
    printf("+-------------------------------------------------------------+\n");
    printf("|            IO Setting                                       |\n");
    printf("|  ______                                 _______             |\n");
    printf("| |      |                               |       |            |\n");
    printf("| |Master|---TXD(PB.3) <===> RXD(PA.2)---| Slave |            |\n");
    printf("| |      |---RTS(PA.0) <===> RTS(PA.0)---|       |            |\n");
    printf("| |______|                               |_______|            |\n");
    printf("|                                                             |\n");
    printf("+-------------------------------------------------------------+\n\n");
    printf("|       RS485 Function Test                                   |\n");
    printf("|  Please select Master or Slave test                         |\n");
    printf("|  [0] Master    [1] Slave                                    |\n");
    u32Item = getchar();
        The sample code is used to test RS485 9-bit mode and needs
        two Module test board to complete the test.
        Master:
            1.Set AUD mode and HW will control RTS pin. LEV_RTS is set to '0'.
            2.Master will send four different address with 10 bytes data to test Slave.
            3.Address bytes : the parity bit should be '1'. (Set UA_LCR = 0x2B)
            4.Data bytes : the parity bit should be '0'. (Set UA_LCR = 0x3B)
            5.RTS pin is low in idle state. When master is sending,
              RTS pin will be pull high.
        Slave:
            1.Set AAD and AUD mode firstly. LEV_RTS is set to '0'.
            2.The received byte, parity bit is '1' , is considered "ADDRESS".
            3.The received byte, parity bit is '0' , is considered "DATA".  (Default)
            4.AAD: The slave will ignore any data until ADDRESS match ADDR_MATCH value.
              When RLS and RDA interrupt is happened,it means the ADDRESS is received.
              Check if RS485_ADD_DETF is set and read UA_RBR to clear ADDRESS stored in rx_fifo.
              NMM: The slave will ignore data byte until disable RX_DIS.
              Check the ADDRESS is match or not by user in UART_IRQHandler.
              If the ADDRESS is match,clear RX_DIS bit to receive data byte.
              If the ADDRESS is not match,set RX_DIS bit to avoid data byte stored in FIFO.
    if (u32Item == '0')
        RS485_9bitModeMaster();
    else
        RS485_9bitModeSlave();
/*** (C) COPYRIGHT 2017 Nuvoton Technology Corp. ***/
xinxianshi|  楼主 | 2023-12-26 11:34 | 只看该作者
485接口通信一般供电多少?
电平电压有没有什么规范呢?
