- #include "ws281x.h"
 - #include "delay.h"
 - #include "timer.h"
- u16 pixelBuffer[PIXEL_NUM + RESET_NUM][24] = {0};
- void ws281x_show(void)
 -      DMA_SetCurrDataCounter(DMA1_Channel5,(PIXEL_NUM + RESET_NUM)* 24 );
 -             DMA_Cmd(DMA1_Channel5, ENABLE);
 -      TIM_Cmd(TIM4, ENABLE);
-             while(DMA_GetFlagStatus(DMA1_FLAG_TC5) !=SET);
 -      DMA_Cmd(DMA1_Channel5, DISABLE );
 -      DMA_ClearFlag(DMA1_FLAG_TC5);
 -      TIM_Cmd(TIM4, DISABLE);
- void ws281x_closeAll(void)
 -      uint16_t i;
 -      uint8_t j;
 -      for(i = 0; i < PIXEL_NUM; i++)
 -          for(j = 0; j < 24; j++)
 -               pixelBuffer[i][j] = WS_LOW;
 -                                         ws281x_show();
- uint32_t ws281x_color(uint8_t red, uint8_t green, uint8_t blue)
 -      return ((green << 16) | (red << 8) | blue);
- void ws281x_setPixelColor(uint16_t n ,uint32_t GRBcolor)
 -      uint8_t i;
 -                                         if(n < PIXEL_NUM)
 -           for(i = 0; i < 24; i++)
 -        pixelBuffer[n][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 - // level
 - //  8               08   09
 - //  7            07         10
 - //  6          06             11
 - //  5         05               12
 - //  4         04               13
 - //  3          03             14
 - //  2            02         15
 - //  1               01  16
 - //  0 off
 - void ws281x_setPixelColor_ringleds(uint16_t n ,uint32_t GRBcolor)            //PIXEL_NUM:12/16/2*n Ring leds
 -        uint8_t i,k,p;
 -        for(k = 0;(k < n) && (n <= (PIXEL_NUM / 2));k++)
 -        pixelBuffer[k][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 -        pixelBuffer[(PIXEL_NUM - 1) - k][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 -        for(p = n;(p < ( PIXEL_NUM - n)) && (n <= (PIXEL_NUM / 2)) ;p++)
 -        pixelBuffer[p][i]  =   WS_LOW;
- //  fill the dots one by one with a color on left and right sides at the same time
 - void ws281x_colorWipe_lr( uint32_t c, uint8_t num)
 -     uint16_t i;
 -                                 if(num > PIXEL_NUM / 2)
 -                                      num = PIXEL_NUM / 2;
 -     for(i = 0; i < (num + 1); i++)         //
 -        ws281x_setPixelColor_ringleds(i ,c);
 -                       ws281x_show();
 -         //delay_ms(wait);          //>        0.05ms                                will should be using timer
- //Freq rising or falling lights
 - void ws281x_colorWipe_freq(uint8_t type)
 -                  switch(type)
 -        case 1:
 -                         ws281x_colorWipe_lr(ws281x_color(50, 0, 0), ws281x_freq_num); // red
 -        break;
 -        case 2:
 -                         ws281x_colorWipe_lr(ws281x_color(0, 50, 0), ws281x_freq_num); // green
 -        break;
 -        case 3:
 -                         ws281x_colorWipe_lr(ws281x_color(0, 0, 50), ws281x_freq_num); // Blue
 -        break;
 -        case 4:
 -                         ws281x_colorWipe_lr(ws281x_color(50, 50, 50), ws281x_freq_num); // white
 -        break;
 -        default:
 -        break;
 - uint32_t ws281x_colorTran(uint8_t tran,uint8_t color_mode)  //The colour is a transition r/g/b back to r/g/b(color_mode:Red1,Green2,Blue3). space 3
 -      tran = 255 - tran;
 -      if(tran < 85)
 -                                              switch(color_mode)
 -        case 1:
 -                         return ws281x_color(tran * 3, 0, 0);
 -        case 2:
 -                         return ws281x_color(0, tran * 3, 0);
 -        case 3:
 -                         return ws281x_color(0, 0, tran * 3);
 -        default:
 -      if(tran < 170)
 -           tran -= 85;
 -        case 1:
 -                         return ws281x_color(255, 0, 0);
 -        case 2:
 -                         return ws281x_color(0,255, 0);
 -        case 3:
 -                         return ws281x_color(0, 0, 255);
 -        default:
 -      tran -= 170;
 -        case 1:
 -        return ws281x_color(255 - tran * 3, 0, 0);
 -        case 2:
 -        return ws281x_color(0, 255 - tran * 3, 0);
 -        case 3:
 -        return ws281x_color(0, 0, 255 - tran * 3);
 -        default:
- void ws281x_colorblnCtrl(uint8_t color_mode)   // ws281x_bln_num use timer,mode:red1/green2/blue3
 -      uint16_t i;
-        if( !(ws281x_bln_num == ws281x_bln_oldnum))
 -        ws281x_setPixelColor(i ,ws281x_colorTran(ws281x_bln_num,color_mode));
 -        ws281x_show();
 -        ws281x_bln_oldnum = ws281x_bln_num;
- void ws281x_setPixelColor_wheel_leds(uint16_t n ,uint32_t GRBcolor)            //n:0~15 whirling leds
 -        uint8_t i,k;
 -                   for(k = 0;k < PIXEL_NUM;k++)
 -        pixelBuffer[k][i]  =   WS_LOW;
 -        if( n < PIXEL_NUM/2)
 -        pixelBuffer[n + (PIXEL_NUM/2)][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 -        else
 -        pixelBuffer[n - (PIXEL_NUM/2)][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 -                                                         ws281x_show();
- void ws281x_display(void)
 -                                      if(ws281x_led_display_mode == 1)
 -        ws281x_colorblnCtrl(ws281x_bln_mode);
 -        if(ws281x_led_display_mode == 2)
 -        ws281x_colorWipe_freq(ws281x_freq_color_type);
 -        if(ws281x_led_display_mode == 3)
 -        ws281x_setPixelColor_wheel_leds(ws281x_whirl_index,
 -        ws281x_color(color_R[ws281x_whirl_colortran_index],
 -        color_G[ws281x_whirl_colortran_index],
 -        color_B[ws281x_whirl_colortran_index])) ;
 - void ws281x_setPixelColor_11x44leds(uint16_t n ,uint32_t GRBcolor)            //PIXEL_NUM:11x44 leds  n:0~10
 -        uint8_t i,k,p,q;
 -        for(k = 0;k < 44;k++)
 -        for(q = 0 ;q < (n +1);q++)
 -        pixelBuffer[q + k*11][i] = ((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW;
 -        for(p = 1;p < (10-n);p++)
 -        pixelBuffer[(n + p) + k*11][i]  =   WS_LOW;
