[STM32F4]
STM32F407内部温度偏差太大
1670|17
jcky001|  楼主 | 2024-1-26 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求高手指点…
代码如下:
static void        AdcPinComInit(void)
        GPIO_InitTypeDef                                GPIO_InitStructure;
        ADC_CommonInitTypeDef                ADC_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        ADC_InitStructure.ADC_Mode = ADC_DualMode_RegSimult;
        ADC_InitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
        ADC_InitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
        ADC_InitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_10Cycles;
        ADC_CommonInit(&ADC_InitStructure);
static void        AdcDmaInit(void)
        DMA_InitTypeDef                DMA_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)AdcSampDmaBuf;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CCR_ADDRESS;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = ADC_DMA_BUF_LEN;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        ////
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;          ////
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
static void Adc1ChxConfig(void)
  ADC_InitTypeDef ADC_InitStructure;
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 3;
  ADC_Init(ADC1, &ADC_InitStructure);
  //// ADC1 regular channels configuration
  ADC_RegularChannelConfig(ADC1, ADC_Channel_TempSensor, 1, ADC_SampleTime_15Cycles);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_15Cycles);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 3, ADC_SampleTime_15Cycles);
static void Adc2ChxConfig(void)
  ADC_Init(ADC2, &ADC_InitStructure);
  //// ADC2 regular channels configuration
  ADC_RegularChannelConfig(ADC2, ADC_Channel_2, 1, ADC_SampleTime_15Cycles);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_4, 2, ADC_SampleTime_15Cycles);
tpgf| | 2024-2-5 14:52 | 只看该作者
单片机内置的温度传感器的误差本来误差就非常大
keaibukelian| | 2024-2-5 15:25 | 只看该作者
手册上应该给了这个内置的温度传感器的精度了
heimaojingzhang| | 2024-2-5 16:09 | 只看该作者
楼主是不是感觉adc采集的有偏差呢
elephant00| | 2024-2-5 16:20 | 只看该作者
校准传感器
两只袜子| | 2024-2-5 16:21 | 只看该作者
电路板周围的环境温度变化较大?
cr315| | 2024-2-5 16:21 | 只看该作者
优化电路板布局和布线
renzheshengui| | 2024-2-6 08:31 | 只看该作者
楼主得到的实际数据是多少 和理论数据差多少呢
远山寻你| | 2024-2-20 12:19 | 只看该作者
内部温差大不是正常的么,内部的ADC好像是10位的吧
淡漠安然| | 2024-2-20 14:30 | 只看该作者
对于STM32F407内部温度传感器的偏差较大,这可能是由于芯片本身的特性或者环境因素导致的
别乱了阵脚| | 2024-2-20 16:30 | 只看该作者
其实可以进行温度校准可以帮助你了解传感器的实际偏差,并在软件中进行补偿
一秒落纱| | 2024-2-20 18:30 | 只看该作者
尽量将芯片放置在稳定的温度环境中,避免温度变化对测量结果的影响
冰春彩落下| | 2024-2-20 20:30 | 只看该作者
考虑使用外部温度传感器,通过外部传感器来获取更准确的温度数据。
三生万物| | 2024-2-20 22:30 | 只看该作者
这个就是多采集,取平均值就好了
暖了夏天蓝了海| | 2024-2-21 02:00 | 只看该作者
一般也不会很大吧,毕竟在MCU内部,它接触MCU最近了
夜阑风雨| | 2024-2-21 04:00 | 只看该作者
我觉得还行,是不是你环境的温度变化很大啊?
光辉梦境| | 2024-2-21 06:00 | 只看该作者
我记得内部温度传感器应该有校准功能
江河千里| | 2024-2-21 12:00 | 只看该作者
这个跟你处理方式有关系,滤波取平均值就能好一些的
