[其他ST产品]
adc中断进去之后无法出来
739|12
duo点|  楼主 | 2024-1-26 10:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//#include "keypad.h"
#include "1602(zhp)LT.h"
//#include"舵机.h"
#include"BoardConfig.h"
软件延时
//typedef unsigned int uint;
//typedef unsigned char uchar;
#define CPU_F ((double)8000000)
#define DELAY_US(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define DELAY_MS(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define num 20
unsigned char wan,qian,bai,shi,ge;
unsigned int results[num]={0};
unsigned char t=0;
unsigned int ave=0;
unsigned int filter[2];
void transform(unsigned int dat)
   wan=dat/10000+0x30;
   qian=dat%10000/1000+0x30;
   bai=dat%1000/100+0x30;
   shi=dat%100/10+0x30;
   ge=dat%10+0x30;
void main()
   WDTCTL = WDTPW+WDTHOLD;  //关闭看门狗
  BCSCTL1 &= ~XT2OFF;
   while(IFG1&OFIFG)
     IFG1&= ~OFIFG;
     DELAY_US(50);
   BCSCTL2 |= SELM_2+SELS+DIVS_3; //MCLK 8M,SMCLK 1M
   lcd_init1602 ();
   //keypad_init();
   //write1char1602(0,0,i/10+0x30);
   //BoardConfig(0xb8);//11111000
   //_EINT();
   WDTCTL=WDTPW+WDTHOLD;
   P6SEL|=BIT1;
   ADC12CTL0=ADC12ON+SHT0_8+SHT1_8+MSC;
   ADC12CTL1=SHP+CONSEQ_2+CSTARTADD_1;
   ADC12MCTL1=INCH_1;
   ADC12IE=BIT1;
   ADC12CTL0|=ENC;
   _EINT();
   ADC12CTL0|=ADC12SC;
   while(2);
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR()
   ADC12IFG=0X00;
   t++;
   filter[0]=ADC12MEM0;
   if(filter[0]-filter[1]>5)
     ave=ave+filter[1];
   else
     ave=ave+filter[0];
   if(t==11)
     t=0;
     ave=(unsigned int)(ave/11);
     transform(ave);
     write1char1602(0,0,wan);
     write1char1602(1,0,qian);
     write1char1602(2,0,bai);
     write1char1602(3,0,shi);
     write1char1602(4,0,ge);
     ave=0;
   filter[1]=filter[0];
我明明读了ADC12MEM啊,为什么还是不能清除ADC12IFG呢?
cr315| | 2024-1-27 12:21 | 只看该作者
清除中断标志位
两只袜子| | 2024-1-27 12:22 | 只看该作者
检查中断优先级和子优先级
未说出口的像你| | 2024-2-20 23:44 | 只看该作者
用库函数的版本搞ADC多好啊,这样的话还便于理解
我吃小朋友| | 2024-2-21 02:00 | 只看该作者
你这种如果进入ADC就出不来,可能是标记位没清理吧
将爱藏于深海| | 2024-2-21 04:00 | 只看该作者
仿真看看,程序怎么执行的呗
故意相遇| | 2024-2-21 06:00 | 只看该作者
我觉得可能是你ADC的标记没清吧
风凉| | 2024-2-21 08:00 | 只看该作者
还是用官方的ADCdemo搞一下吧,这样能好点,有错误也能知道
在曼谷的春| | 2024-2-21 12:00 | 只看该作者
话说,while(2)是啥?也是循环吗?
月亮一键变蓝| | 2024-2-21 14:00 | 只看该作者
可能是清理的不对?
她已醉| | 2024-2-21 16:00 | 只看该作者
你直接读取ADC,数据能读到不?
春日负喧| | 2024-2-21 20:00 | 只看该作者
建议还是用库函数写,这种寄存器的真心不好阅读
白马过平川| | 2024-2-21 23:00 | 只看该作者
应该是程序中断标志没清导致的出不来
