[STM32F3] STM32L031F6 LL库硬件I2C使用,中断模式
1297|15
 楼主| 逢dududu必shu 发表于 2024-1-31 23:59 | 显示全部楼层 |阅读模式
最近用到了I2C,之前都是用软件模拟I2C,听说硬件I2C已经比之前好用了,这次决定尝试一下
代码和cube工程下载地址
stm32l053硬件i2c发送接收程序-C文档类资源-CSDN下载
一、创建测试工程I2C MASTER
配置上拉,串口用来查看调试信息
I2C模式使能中断
I2C模式使能中断
I2C模式使能中断
I2C模式使能中断
I2C模式使能中断
二、创建测试工程I2C SLAVE
配置上拉,串口用来查看调试信息,配置与MASTER相同即可,硬件I2C的2个IO口直连
三、 MASTER代码编写
master是主动请求,slave用中断处理所有操作,这里把主要代码贴出来
i2c.c
  * @file    i2c.c
  * @brief   This file provides code for the configuration
  *          of the I2C instances.
  * @attention
  * <h2><center>&copy; Copyright (c) 2022 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* Includes ------------------------------------------------------------------*/
#include "i2c.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
/* I2C1 init function */
void MX_I2C1_Init(void)
  /* USER CODE BEGIN I2C1_Init 0 */
  /* USER CODE END I2C1_Init 0 */
  LL_I2C_InitTypeDef I2C_InitStruct = {0};
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOA);
  /**I2C1 GPIO Configuration
  PA9   ------> I2C1_SCL
  PA10   ------> I2C1_SDA
  GPIO_InitStruct.Pin = LL_GPIO_PIN_9;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_OPENDRAIN;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_UP;
  GPIO_InitStruct.Alternate = LL_GPIO_AF_1;
  LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = LL_GPIO_PIN_10;
  /* Peripheral clock enable */
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_I2C1);
  /* I2C1 interrupt Init */
  NVIC_SetPriority(I2C1_IRQn, 0);
  NVIC_EnableIRQ(I2C1_IRQn);
  /* USER CODE BEGIN I2C1_Init 1 */
  /* USER CODE END I2C1_Init 1 */
  /** I2C Initialization
  LL_I2C_EnableAutoEndMode(I2C1);
  LL_I2C_DisableOwnAddress2(I2C1);
  LL_I2C_DisableGeneralCall(I2C1);
  LL_I2C_EnableClockStretching(I2C1);
  I2C_InitStruct.PeripheralMode = LL_I2C_MODE_I2C;
  I2C_InitStruct.Timing = 0x00000708;
  I2C_InitStruct.AnalogFilter = LL_I2C_ANALOGFILTER_ENABLE;
  I2C_InitStruct.DigitalFilter = 0;
  I2C_InitStruct.OwnAddress1 = 0x01;
  I2C_InitStruct.TypeAcknowledge = LL_I2C_ACK;
  I2C_InitStruct.OwnAddrSize = LL_I2C_OWNADDRESS1_7BIT;
  LL_I2C_Init(I2C1, &I2C_InitStruct);
  LL_I2C_SetOwnAddress2(I2C1, 0, LL_I2C_OWNADDRESS2_NOMASK);
  /* USER CODE BEGIN I2C1_Init 2 */
        LL_I2C_EnableSMBusAlert(I2C1);
        LL_I2C_EnableOwnAddress1(I2C1);         //
  LL_I2C_Enable(I2C1);
        /* Listen IT */
//  LL_I2C_EnableIT_ADDR(I2C1);
//  LL_I2C_EnableIT_NACK(I2C1);
//  LL_I2C_EnableIT_ERR(I2C1);
//  LL_I2C_EnableIT_STOP(I2C1);
  /* USER CODE END I2C1_Init 2 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
 楼主| 逢dududu必shu 发表于 2024-2-1 00:00 | 显示全部楼层
I2C模式使能中断
 楼主| 逢dududu必shu 发表于 2024-2-1 00:07 | 显示全部楼层
发送和读取i2c数据在主函数中,这里用的是软件停止位,同样可以使用自动停止位LL_I2C_MODE_AUTOEND,使用自动停止位不需要主动发送停止/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
/* USER CODE END Header */
#include "main.h"
#include "i2c.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include <stdio.h>
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
  * @brief  The application entry point.
  * @retval int
int main(void)
        uint16_t i = 0;
        int timeOut = 0;
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SYSCFG);
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_PWR);
  /* System interrupt init*/
  /* SysTick_IRQn interrupt configuration */
  NVIC_SetPriority(SysTick_IRQn, 3);
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_LPUART1_UART_Init();
  /* USER CODE BEGIN 2 */
        LL_LPUART_Enable(LPUART1);
        printf("Init Ok!\r\n");
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
                LL_mDelay(5000);
                LL_I2C_HandleTransfer(I2C1, 0x10, LL_I2C_ADDRSLAVE_7BIT, 10, LL_I2C_MODE_SOFTEND, LL_I2C_GENERATE_START_WRITE);
                printf("I2C Send Data:\t");
                for(i=0;i<10;i++)
                        LL_mDelay(1);
                        while(!LL_I2C_IsActiveFlag_TXIS(I2C1))
                                LL_mDelay(1);
                                timeOut++;
                                if(timeOut>100)
                                        timeOut = 0;
                                        break;
                        LL_I2C_TransmitData8(I2C1,(uint8_t)i);
                        printf("%x\t",(uint8_t)i);
          printf("\r\nI2C Recv Data:\t");
          LL_mDelay(10);
                LL_I2C_HandleTransfer(I2C1, 0x10, LL_I2C_ADDRSLAVE_7BIT, 0, LL_I2C_MODE_SOFTEND,LL_I2C_GENERATE_STOP);
                LL_mDelay(50);
                LL_I2C_HandleTransfer(I2C1, 0x10, LL_I2C_ADDRSLAVE_7BIT, 10, LL_I2C_MODE_SOFTEND,LL_I2C_GENERATE_START_READ);
                for(i=0;i<10;i++)
                        LL_mDelay(1);
                        while(!LL_I2C_IsActiveFlag_RXNE(I2C1))
                                LL_mDelay(1);
                                timeOut++;
                                if(timeOut>100)
                                        timeOut = 0;
                                        break;
                        printf("%x\t",LL_I2C_ReceiveData8(I2C1));
                printf("\r\n");
                LL_mDelay(10);
//                LL_I2C_HandleTransfer(I2C1, 0x00, LL_I2C_ADDRSLAVE_7BIT, 2, LL_I2C_MODE_AUTOEND, LL_I2C_GENERATE_START_WRITE);
//                while(!LL_I2C_IsActiveFlag_TXIS(I2C1))
//                LL_I2C_TransmitData8(I2C1,0x01);
//                LL_I2C_TransmitData8(I2C1,0x1f);
//                LL_I2C_HandleTransfer(I2C1, 0x00, LL_I2C_ADDRSLAVE_7BIT, 1, LL_I2C_MODE_AUTOEND,LL_I2C_GENERATE_START_READ);
//                while(!LL_I2C_IsActiveFlag_RXNE(I2C1))
//                printf("%x\r\n",LL_I2C_ReceiveData8(I2C1));
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  LL_FLASH_SetLatency(LL_FLASH_LATENCY_0);
  while(LL_FLASH_GetLatency()!= LL_FLASH_LATENCY_0)
  LL_PWR_SetRegulVoltageScaling(LL_PWR_REGU_VOLTAGE_SCALE1);
  LL_RCC_MSI_Enable();
   /* Wait till MSI is ready */
  while(LL_RCC_MSI_IsReady() != 1)
  LL_RCC_MSI_SetRange(LL_RCC_MSIRANGE_5);
  LL_RCC_MSI_SetCalibTrimming(0);
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_MSI);
   /* Wait till System clock is ready */
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_MSI)
  LL_Init1msTick(2097000);
  LL_SetSystemCoreClock(2097000);
  LL_RCC_SetLPUARTClockSource(LL_RCC_LPUART1_CLKSOURCE_PCLK1);
  LL_RCC_SetI2CClockSource(LL_RCC_I2C1_CLKSOURCE_PCLK1);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
四、 SLAVE代码编写
配置代码/**
  * @file    i2c.c
  * @attention
#include "i2c.h"
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  I2C_InitStruct.OwnAddress1 = 0x10;
        /* Listen IT */
主函数里啥也没有int main(void)
  MX_GPIO_Init();
  MX_I2C1_Init();
  /* Infinite loop */
  while (1)
                LL_mDelay(1000);
中断函数/* USER CODE BEGIN Header */
  * @file    stm32l0xx_it.c
  * @brief   Interrupt Service Routines.
  * @attention
#include "main.h"
#include "stm32l0xx_it.h"
#include "usart.h"
/* USER CODE BEGIN TD */
/* USER CODE END TD */
/* External variables --------------------------------------------------------*/
/* USER CODE BEGIN EV */
int ubReceiveIndex=0;
int ubSendIndex=0;
uint8_t aReceiveBuffer[256];
void Slave_Reception_Callback(void)
        uint8_t recvData = LL_I2C_ReceiveData8(I2C1);
        printf("ubReceiveIndex:%x,LL_I2C_ReceiveData8:%x\r\n",ubReceiveIndex,recvData);
  /* Read character in Receive Data register. RXNE flag is cleared by reading data in RXDR register */
  aReceiveBuffer[ubReceiveIndex++] = recvData;
void Error_Callback()
        uint8_t i=0;
        uint8_t data =0;
        printf("Error_Callback:");
        /* Clear NACKF Flag */
        LL_I2C_ClearFlag_NACK(I2C1);
        /* Clear STOP Flag */
        LL_I2C_ClearFlag_STOP(I2C1);
        /* Clear Configuration Register 2, */
        I2C1->CR2 &= (uint32_t)~((uint32_t)(I2C_CR2_SADD | I2C_CR2_HEAD10R | I2C_CR2_NBYTES | I2C_CR2_RELOAD | I2C_CR2_RD_WRN));
//        for(i=0;i<200;i++)
//                data = LL_I2C_ReceiveData8(I2C1);
//                printf("%x\t",data);
//                if(data == 0x00)
//                        break;
        printf("\r\n");
void Slave_Complete_Callback()
        uint16_t i=0;
        printf("I2C Slave Recv Data\r\n");
        for(i=0;i<ubReceiveIndex;i++)
                printf("%x\t",aReceiveBuffer[i]);
        printf("\r\n");
/* USER CODE END EV */
/*           Cortex-M0+ Processor Interruption and Exception Handlers          */
  * @brief This function handles Non maskable Interrupt.
void NMI_Handler(void)
  /* USER CODE BEGIN NonMaskableInt_IRQn 0 */
  /* USER CODE END NonMaskableInt_IRQn 0 */
  /* USER CODE BEGIN NonMaskableInt_IRQn 1 */
  while (1)
  /* USER CODE END NonMaskableInt_IRQn 1 */
  * @brief This function handles Hard fault interrupt.
void HardFault_Handler(void)
  /* USER CODE BEGIN HardFault_IRQn 0 */
  /* USER CODE END HardFault_IRQn 0 */
  while (1)
    /* USER CODE BEGIN W1_HardFault_IRQn 0 */
    /* USER CODE END W1_HardFault_IRQn 0 */
  * @brief This function handles System service call via SWI instruction.
void SVC_Handler(void)
  /* USER CODE BEGIN SVC_IRQn 0 */
  /* USER CODE END SVC_IRQn 0 */
  /* USER CODE BEGIN SVC_IRQn 1 */
  /* USER CODE END SVC_IRQn 1 */
  * @brief This function handles Pendable request for system service.
void PendSV_Handler(void)
  /* USER CODE BEGIN PendSV_IRQn 0 */
  /* USER CODE END PendSV_IRQn 0 */
  /* USER CODE BEGIN PendSV_IRQn 1 */
  /* USER CODE END PendSV_IRQn 1 */
  * @brief This function handles System tick timer.
void SysTick_Handler(void)
  /* USER CODE BEGIN SysTick_IRQn 0 */
  /* USER CODE END SysTick_IRQn 0 */
  /* USER CODE BEGIN SysTick_IRQn 1 */
  /* USER CODE END SysTick_IRQn 1 */
/* STM32L0xx Peripheral Interrupt Handlers                                    */
/* Add here the Interrupt Handlers for the used peripherals.                  */
/* For the available peripheral interrupt handler names,                      */
/* please refer to the startup file (startup_stm32l0xx.s).                    */
  * @brief This function handles I2C1 event global interrupt / I2C1 wake-up interrupt through EXTI line 23.
void I2C1_IRQHandler(void)
  /* USER CODE BEGIN I2C1_IRQn 0 */
  if(LL_I2C_IsActiveFlag_ADDR(I2C1))
    /* Verify the Address Match with the OWN Slave address */
    if(LL_I2C_GetAddressMatchCode(I2C1) == 0x10)
      /* Verify the transfer direction, a write direction, Slave enters receiver mode */
      if(LL_I2C_GetTransferDirection(I2C1) == LL_I2C_DIRECTION_WRITE)
        /* Clear ADDR flag value in ISR register */
        LL_I2C_ClearFlag_ADDR(I2C1);
        /* Enable Receive Interrupt */
        LL_I2C_EnableIT_RX(I2C1);
      else
                                LL_I2C_ClearFlag_TXE(I2C1);
                                LL_I2C_EnableIT_TX(I2C1);
    else
      /* Call Error function */
      Error_Callback();
  /* Check RXNE flag value in ISR register */
  else if(LL_I2C_IsActiveFlag_TXIS(I2C1))
                LL_I2C_TransmitData8(I2C1, aReceiveBuffer[ubSendIndex++]);
                //printf("%x\t%x\r\n",aReceiveBuffer[0],aReceiveBuffer[1]);
  else if(LL_I2C_IsActiveFlag_RXNE(I2C1))
    /* Call function Slave Reception Callback */
    Slave_Reception_Callback();
  /* Check STOP flag value in ISR register */
  else if(LL_I2C_IsActiveFlag_STOP(I2C1))
    /* End of Transfer */
    /* Call function Slave Complete Callback */
    Slave_Complete_Callback();
                ubReceiveIndex =0;
                ubSendIndex = 0;
  else
    Error_Callback();
  /* USER CODE END I2C1_IRQn 0 */
  /* USER CODE BEGIN I2C1_IRQn 1 */
  /* USER CODE END I2C1_IRQn 1 */
