- * @file main.c
- * @version V1.00
- * $Revision: 9 $
- * $Date: 18/07/05 4:58p $
- * @brief Capture the PWM0 Channel 0 waveform by PWM0 Channel 2, and use PDMA to transfer captured data.
- Frequency of PWM Channel 0 is 1 MHz to test maximum input frequency
- for PWM Capture function.
- * SPDX-License-Identifier: Apache-2.0
- * @copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NuMicro.h"
- /* Macro, type and constant definitions */
- #define PLL_CLOCK 96000000
- /* Global variables */
- #define Transfer_Count 4
- uint16_t g_au16Count[Transfer_Count];
- volatile uint32_t g_u32IsTestOver = 0;
- * @brief PDMA IRQ Handler
- * @param None
- * @return None
- * @details ISR to handle PDMA interrupt event
- void PDMA_IRQHandler(void)
- uint32_t status = PDMA_GET_INT_STATUS(PDMA);
- if(status & 0x1) /* abort */
- if(PDMA_GET_ABORT_STS(PDMA) & 0x1)
- g_u32IsTestOver = 2;
- PDMA_CLR_ABORT_FLAG(PDMA, PDMA_ABTSTS_ABTIF0_Msk);
- else if(status & 0x2) /* done */
- if(PDMA_GET_TD_STS(PDMA) & 0x1)
- g_u32IsTestOver = 1;
- PDMA_CLR_TD_FLAG(PDMA, PDMA_TDSTS_TDIF0_Msk);
- else
- printf("unknown interrupt !!\n");
- /* Capture function to calculate the input waveform information */
- /* g_au16Count[4] : Keep the internal counter value when input signal rising / falling */
- /* happens */
- /* time A B C D */
- /* ___ ___ ___ ___ ___ ___ ___ ___ */
- /* ____| |_| |_| |_| |_| |_| |_| |_| |_____ */
- /* index 0 1 2 3 */
- /* The capture internal counter down count from 0xFFFF, and reload to 0xFFFF after */
- /* input signal falling happens (Time B/C/D) */
- void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch)
- uint16_t u16HighPeriod, u16LowPeriod, u16TotalPeriod;
- uint32_t u32TimeOutCount;
- /* setup timeout */
- u32TimeOutCount = SystemCoreClock;
- /* Wait PDMA interrupt (g_u32IsTestOver will be set at IRQ_Handler function) */
- while(g_u32IsTestOver == 0)
- if(u32TimeOutCount == 0)
- printf("\nSomething is wrong, please check if pin connection is correct. \n");
- while(1);
- u32TimeOutCount--;
- u16HighPeriod = g_au16Count[1] - g_au16Count[2] + 1;
- u16LowPeriod = 0xFFFF - g_au16Count[1];
- u16TotalPeriod = 0xFFFF - g_au16Count[2] + 1;
- printf("\nHigh Period = %d ns, Low Period = %d ns , Total Period = %d ns.\n",
- u16HighPeriod*1000/48, u16LowPeriod*1000/48, u16TotalPeriod*1000/48);
- printf("Frequency = %d Hz, Duty = %d %%.\n\n",
- 48000000/u16TotalPeriod, u16HighPeriod*100/u16TotalPeriod );
- void SYS_Init(void)
- /* Init System Clock */
- /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
- GPIO_SetMode(PF, BIT2 | BIT3, GPIO_MODE_INPUT);
- /* Enable HIRC clock */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Waiting for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Select HIRC as the clock source of UART0 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
- /* Set core clock as PLL_CLOCK from PLL (no PLL in rev. B & C) */
- // CLK_SetCoreClock(PLL_CLOCK);
- /* Waiting for PLL clock ready */
- // CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
- /* Enable UART peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* PWM clock frequency configuration */
- /* Select HCLK clock source as PLL and and HCLK clock divider as 2 */
- // CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
- /* PWM clock frequency can be set equal or double to HCLK by choosing case 1 or case 2 */
- /* case 1.PWM clock frequency is set equal to HCLK: select PWM module clock source as PCLK */
- CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL2_PWM0SEL_PCLK0, 0);
- /* case 2.PWM clock frequency is set double to HCLK: select PWM module clock source as PLL */
- // CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL2_PWM0SEL_PLL, 0);
- /* Enable PDMA module clock */
- CLK_EnableModuleClock(PDMA_MODULE);
- /* Enable PWM0 module clock */
- CLK_EnableModuleClock(PWM0_MODULE);
- /* Reset PWM0 module */
- SYS_ResetModule(PWM0_RST);
- /* Reset PDMA module */
- SYS_ResetModule(PDMA_RST);
- /* Update System Core Clock */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
- SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
- (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
- /* Set PB multi-function pins for PWM0 Channel 0 and 2 */
- SYS->GPB_MFPL = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB5MFP_Msk)) |
- SYS_GPB_MFPL_PB5MFP_PWM0_CH0;
- SYS->GPB_MFPL = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB3MFP_Msk)) |
- SYS_GPB_MFPL_PB3MFP_PWM0_CH2;
- void UART0_Init()
- /* Init UART */
- /* Reset UART module */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 baud rate */
- UART_Open(UART0, 115200);
- /* Main Function */
- int32_t main(void)
- uint8_t u8Option;
- /* Init System, IP clock and multi-function I/O
- In the end of SYS_Init() will issue SYS_LockReg()
- to lock protected register. If user want to write
- protected register, please issue SYS_UnlockReg()
- to unlock protected register if necessary */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART to 115200-8n1 for print message */
- UART0_Init();
- printf("\n\nCPU @ %dHz(PLL@ %dHz)\n", SystemCoreClock, PllClock);
- printf("PWM0 clock is from %s\n", (CLK->CLKSEL2 & CLK_CLKSEL2_PWM0SEL_Msk) ? "CPU" : "PLL");
- printf("+------------------------------------------------------------------------+\n");
- printf("| PWM Capture Sample Code |\n");
- printf("| |\n");
- printf(" This sample code will use PWM0 channel 2 to capture the signal from PWM0 channel 0.\n");
- printf(" And the captured data is transferred by PDMA channel 0.\n");
- printf(" PWM0 channel 0 is 1 MHz, duty is 50 %%.\n");
- printf(" PWM0 channel 2 counter period is about 20.8(1/48,000,000) ns\n");
- printf(" I/O configuration:\n");
- printf(" PWM0 channel 2(PB.3) <--> PWM0 channel 0(PB.5)\n\n");
- printf("Use PWM0 Channel 2(PB.3) to capture the PWM0 Channel 0(PB.5) Waveform\n");
- /* Set the PWM0 Channel 0 as PWM output function. */
- /* Assume PWM output frequency is 1 MHz and duty ratio is 50%, user can calculate PWM settings by follows.
- duty ratio = CMR+/(CNR+1)
- cycle time = CNR+1
- High level = CMR
- PWM clock source frequency from HIRC is 48,000,000
- (CNR+1) = PWM clock source frequency/prescaler/PWM output frequency
- = 48,000,000/1/48 = 1,000,000
- (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
- CNR = 47
- duty ratio = 50% ==> CMR/(CNR+1) = 50%
- CMR = 24
- Prescale value is 0 : prescaler = 1
- /* PWM0 channel 0 frequency prescaler to 1 */
- PWM_SET_PRESCALER(PWM0, 0, 1-1);
- /* PWM0 channel 0 frequency period to 47 */
- PWM_SET_CNR(PWM0, 0, 47);
- /* PWM0 channel 0 frequency comparator to 24 */
- PWM_SET_CMR(PWM0, 0, 24);
- /* PWM0 channel 0 is edge-aligned and down counter type */
- PWM_SET_ALIGNED_TYPE(PWM0, BIT0, PWM_EDGE_ALIGNED);
- /* ZeroLevel: Low, CmpUpLevel: nothing, PeriodLevel: nothing, CmpDownLevel: High */
- PWM_SET_OUTPUT_LEVEL(PWM0, PWM_CH_0_MASK, PWM_OUTPUT_LOW, PWM_OUTPUT_HIGH, PWM_OUTPUT_NOTHING, PWM_OUTPUT_HIGH);
- /* Enable PWM Output path for PWM0 channel 0 */
- PWM_EnableOutput(PWM0, PWM_CH_0_MASK);
- /* Enable Timer for PWM0 channel 0 */
- PWM_Start(PWM0, PWM_CH_0_MASK);
- /* Configure PDMA peripheral mode form PWM to memory */
- /* Open Channel 0 */
- PDMA_Open(PDMA, BIT0);
- /* Set source address as PWM capture channel PDMA register(no increment) and destination address as g_au16Count array(increment) */
- PDMA_SetTransferAddr(PDMA, 0, (uint32_t)&PWM0->PDMACAP2_3, PDMA_SAR_FIX, (uint32_t)&g_au16Count[0], PDMA_DAR_INC);
- /* Set PDMA as single request type for PWM */
- PDMA_SetBurstType(PDMA, 0, PDMA_REQ_SINGLE, PDMA_BURST_4);
- PDMA_EnableInt(PDMA, 0, PDMA_INT_TRANS_DONE);
- NVIC_EnableIRQ(PDMA_IRQn);
- /* Set the PWM0 channel 2 for capture function */
- /* (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
- CNR = 0xFFFF
- (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.)
- Capture unit time = 1/Capture clock source frequency/prescaler
- 20.8ns = 1/48,000,000/1
- /* Set PWM0 channel 2 capture configuration */
- PWM_ConfigCaptureChannel(PWM0, 2, 20, 0);
- /* Enable falling capture reload */
- PWM0->CAPCTL |= PWM_CAPCTL_FCRLDEN2_Msk;
- while(1)
- g_u32IsTestOver = 0;
- printf("[0] Trigger PWM0 Channel 2 capture function\n");
- printf("[Other] Exit \n");
- printf("Please input key:");
- u8Option = getchar();
- if(u8Option != '0')
- printf("Exit\n");
- break;
- /* Configure PDMA transfer count and enable PDMA function */
- /* Select PDMA request source as PWM RX(PWM0 channel 2 should be PWM0 pair 2) */
- PDMA_SetTransferMode(PDMA, 0, PDMA_PWM0_P2_RX, FALSE, 0);
- /* Transfer width is half word(16 bit) and transfer count is 4 */
- PDMA_SetTransferCnt(PDMA, 0, PDMA_WIDTH_16, Transfer_Count);
- /* Enable Capture Function for PWM0 channel 2 */
- PWM_EnableCapture(PWM0, PWM_CH_2_MASK);
- /* Enable Timer for PWM0 channel 2 */
- PWM_Start(PWM0, PWM_CH_2_MASK);
- /* Enable PDMA for PWM0 channel 2 capture function, and set capture order as falling first, */
- /* And select capture mode as both rising and falling to do PDMA transfer. */
- PWM_EnablePDMA(PWM0, 2, FALSE, PWM_CAPTURE_PDMA_RISING_FALLING_LATCH);
- /* Capture the Input Waveform Data */
- CalPeriodTime(PWM0, 2);
- /* Set loaded value as 0 for PWM0 channel 2 */
- PWM_Stop(PWM0, PWM_CH_2_MASK);
- /* Clear Capture Interrupt flag for PWM0 channel 2 */
- PWM_ClearCaptureIntFlag(PWM0, 2, PWM_CAPTURE_INT_FALLING_LATCH);
- /* Disable PDMA for PWM0 channel 2 capture function */
- PWM_DisablePDMA(PWM0, 2);
- /* Stop PWM0 channel 2 (Recommended procedure method 1) */
- /* Set PWM Timer loaded value(Period) as 0. When PWM internal counter(CNT) reaches to 0, disable PWM Timer */
- /* Disable Timer for PWM0 channel 2 */
- PWM_ForceStop(PWM0, PWM_CH_2_MASK);
- /* Stop PWM counter */
- PWM_Stop(PWM0, PWM_CH_0_MASK);
- /* Disable output of PWM0 channel 0 */
- PWM_DisableOutput(PWM0, PWM_CH_0_MASK);
- PDMA_Close(PDMA);
- while(1);
