[应用相关] STM32 GPIO
903|7
 楼主| tpgf 发表于 2024-7-20 17:05 | 显示全部楼层 |阅读模式
GPIO
面包板两端横向是相通的,内部是纵向相通
LED闪烁
main.c
#include "stm32f10x.h"                  // Device header
#include "Delay.h"
int main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        //第一步:使用RCC开启GPIO时钟
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        //第二步:使用GPIO_Init()初始化GPIO
        //GPIO_ResetBits(GPIOA,GPIO_Pin_0);//灯亮
        //GPIO_SetBits(GPIOA,GPIO_Pin_0);//灯灭
        //GPIO_WriteBit(GPIOA,GPIO_Pin_0,Bit_RESET);//灯亮
        //GPIO_WriteBit(GPIOA,GPIO_Pin_0,Bit_SET);//灯灭
        //第三步:使用输出或者输入的函数控制GPIO口
        while(1)
                Delay_ms(100);
                Delay_ms(100);
                Delay_ms(500);
                Delay_ms(500);
                GPIO_WriteBit(GPIOA,GPIO_Pin_0,(BitAction)0);
                Delay_ms(500);
                GPIO_WriteBit(GPIOA,GPIO_Pin_0,(BitAction)1);
                Delay_ms(500);
LED流水灯
main.c
#include "Delay.h"
int main(void)
        //第一步:使用RCC开启GPIO时钟
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;//初始化所有端口
        while(1)
//                GPIO_Write(GPIOA,~0x0001);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0002);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0004);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0008);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0010);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0020);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0040);
//                Delay_ms(500);
//                GPIO_Write(GPIOA,~0x0080);
//                Delay_ms(500);
                unsigned char i ;
                for( i = 0 ; i < 8 ;i++)
                        GPIO_Write(GPIOA,~(0x0001 << i));
                        Delay_ms(500);
蜂鸣器
main.c
#include "Delay.h"
int main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        //第一步:使用RCC开启GPIO时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//初始化12端口
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        while(1)
                GPIO_ResetBits(GPIOB,GPIO_Pin_12);
                Delay_ms(100);
                GPIO_SetBits(GPIOB,GPIO_Pin_12);
                Delay_ms(100);
                Delay_ms(100);
                Delay_ms(700);
按键控制LED
key.c
#include "Delay.h"
  * @brief  初始化位于PB1以及PB11按键
  * @param  无
  * @retval 无
void Key_Init(void)//配置按键
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//需要读取按键,设置上拉输入
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//输出速度,输入不影响
  * @brief  获取所按下的键值
  * @param  无
  * @retval KeyNum 按下的键值
uint8_t Key_GetNum(void)
        uint8_t KeyNum = 0;
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1) == 0)
                Delay_ms(20);
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1) == 0)
                //此时处于一直按下的状态
                Delay_ms(20);
                KeyNum = 1;
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11) == 0)
                Delay_ms(20);
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11) == 0)
                //此时处于一直按下的状态
                Delay_ms(20);
                KeyNum = 2;
        return KeyNum;
LED.c
  * @brief  打开GPIO时钟,并进行初始化
  * @param  无
  * @retval 无
void LED_Init(void)
        //第一步:使用RCC开启GPIO时钟
        GPIO_InitTypeDef  GPIO_InitStructure;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
//        GPIO_SetBits(GPIOA,GPIO_Pin_1 | GPIO_Pin_2);
  * @brief  将位于PA1端口电平置零
  * @param  无
  * @retval 无
void LED1_On(void)
        GPIO_ResetBits(GPIOA,GPIO_Pin_1);
  * @brief  将位于PA1端口电平置一
  * @param  无
  * @retval 无
void LED1_Off(void)
        GPIO_SetBits(GPIOA,GPIO_Pin_1);
  * @brief  查看PA1端口电平并将其翻转
  * @param  无
  * @retval 无
void LED1_Turn(void)
        if(GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_1) == 0)//查看当前端口输出
                GPIO_SetBits(GPIOA,GPIO_Pin_1);//将其置一
        else
                GPIO_ResetBits(GPIOA,GPIO_Pin_1);//将其置零
  * @brief  将位于PA2端口电平置零
  * @param  无
  * @retval 无
void LED2_On(void)
        GPIO_ResetBits(GPIOA,GPIO_Pin_2);
  * @param  无
  * @retval 无
void LED2_Off(void)
        GPIO_SetBits(GPIOA,GPIO_Pin_2);
  * @brief  查看PA2端口电平并将其翻转
  * @param  无
  * @retval 无
void LED2_Turn(void)
        if(GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_2) == 0)//查看当前端口输出
                GPIO_SetBits(GPIOA,GPIO_Pin_2);//将其置一
        else
                GPIO_ResetBits(GPIOA,GPIO_Pin_2);//将其置零
main.c
#include "Delay.h"
#include "LED.h"
#include "Key.h"
uint8_t KeyNum;
int main(void)
        LED_Init();
        Key_Init();
        while(1)
                KeyNum = Key_GetNum();//获取键值
                if(KeyNum == 1)//如果键1按下,则翻转LED1电平
                        LED1_Turn();
                if(KeyNum == 2)//如果键2按下,则翻转LED1电平
                        LED2_Turn();
光敏传感器控制蜂鸣器
LightSensor.c
  * @brief  初始化端口在PB^13光敏传感器
  * @param  无
  * @retval 无
void LightSensor_Init(void)
        //第一步:使用RCC开启GPIO时钟
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//上拉输入
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  * @brief  获得当前光敏传感器输入电平
  * @param  无
  * @retval 返回周围光线情况
uint8_t LightSensor_Get(void)
        return GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_13);
        //周围暗的时候输入1;亮的时候输入0
        //周围暗的时候输出0;亮的时候输出1
Buzzer.c
  * @param  无
  * @retval 无
void Buzzer_Init(void)
        //第一步:使用RCC开启GPIO时钟
  * @brief  将位于PB12端口电平置零
  * @param  无
  * @retval 无
void Buzzer_On(void)
  * @brief  将位于PB12端口电平置一
  * @param  无
  * @retval 无
void Buzzer_Off(void)
  * @brief  查看PB12端口电平并将其翻转
  * @param  无
  * @retval 无
void Buzzer_Turn(void)
        if(GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_12) == 0)//查看当前端口输出
                GPIO_SetBits(GPIOB,GPIO_Pin_12);//将其置一
        else
                GPIO_ResetBits(GPIOB,GPIO_Pin_12);//将其置零
main.c
#include "Delay.h"
#include "Buzzer.h"
#include "LightSensor.h"
int main(void)
        Buzzer_Init();
        LightSensor_Init();
        while(1)
                if(LightSensor_Get() == 1)//比较暗的时候
                        Buzzer_On();
                else{
                        Buzzer_Off();
原文链接:https://blog.csdn.net/qq_45981247/article/details/135852319
kzlzqi 发表于 2024-7-29 15:27 | 显示全部楼层
延时模块
Delay模块用于实现简单的延时功能。
Delay.h
c
#ifndef __DELAY_H
#define __DELAY_H
void Delay_ms(uint16_t ms);
#endif
Delay.c
c
#include "Delay.h"
    uint32_t i;
    for(i = 0; i < ms * 8000; i++)
        __NOP();  // 空操作,耗时
范德萨发额 发表于 2024-7-29 15:42 | 显示全部楼层
LED 控制模块
LED模块用于控制两个LED的开关和翻转。
LED.h
c
#ifndef __LED_H
#define __LED_H
void LED_Init(void);
void LED1_On(void);
void LED1_Off(void);
void LED1_Turn(void);
void LED2_On(void);
void LED2_Off(void);
void LED2_Turn(void);
#endif
申小林一号 发表于 2024-7-29 22:38 | 显示全部楼层
感谢分享
